crankshaft shells?? tech help
Old Mar 4, 2006 | 09:47 PM
G420 DEL's Avatar
G420 DEL
Default crankshaft shells?? tech help
just had crankshaft ground and piked it up with some new shells, noticed that all the new shells have grooves in them where the old was half and half, 5 grooved 5 smooth.
am i rite in buildin bak up with these new shells or should i find some that are smooth like the old ones were???
old:
new:
Old Mar 5, 2006 | 04:35 AM
2001ode's Avatar
2001ode
Hi
IMO, I think your new shells are better than old, because oil can circulate easely around ground crank.
Regards
Claude
Old Mar 5, 2006 | 09:55 AM
Avinitlarge's Avatar
Avinitlarge
When ever ive reshelled an engine, the new mains have always had a groove all the way round
Old Mar 5, 2006 | 10:11 AM
G420 DEL's Avatar
G420 DEL
nice one, cheers for the advice
Old Mar 5, 2006 | 10:15 AM
SafeChav's Avatar
SafeChav
I agree as above, and notice how all your old smooth ones have very bad signs of wear on them aswell.........while the grooved ones are like new!!!!
Old Mar 5, 2006 | 02:10 PM
velocity's Avatar
velocity
gentelmen i dont think the all around groove is correct.the shell with groove and the oil hole is to allow good flow into the bearings.the plain shell is located in the bearing cap where the max load is transfered to the bearing from the crank shaft due to the conrod driving downwards.
the grooved shell in cap will have less surface area
although it may work fine, i dont think it is correct
if plains are fitted in the caps from manufacture then they should be fitted in rebuild .
Old Mar 5, 2006 | 04:47 PM
Avinitlarge
Thats right but isnt the pic showing mains shells, Big end shells dont usually have a groove on either side, New Mains shells usually have both shells grooved
Old Mar 5, 2006 | 05:59 PM
nik t's Avatar
nik t
im sure the one half grooved bearings are 2wd.
and the all grooved bearings are 4x4.
different oil pump set ups.
Old Mar 5, 2006 | 06:10 PM
G420 DEL's Avatar
G420 DEL
well if it helps its a fiesta turbo,
reason they prob look so fuked is the car had oil pump issues thast why we've had crank ground,
good old haynes says smooth in the block and grooved in the cap.
Old Mar 5, 2006 | 06:13 PM
SafeChav's Avatar
SafeChav
To the best of my knowledge i thought they were all grooved for the main bearings and smooth for the conrods
Old Mar 5, 2006 | 06:31 PM
excursion's Avatar
excursion
Bulletin Board User
That's what I'd go with aswell, the axial groove bearings for oil supply on the top of the crank (least loaded bearings). Also there can't be much need for axial groove journals in the bearing caps as the oil supply is coming in from the block.
Old Mar 5, 2006 | 06:45 PM
SafeChav's Avatar
SafeChav
I see what u mean about the haynes manual...but then if u read the escort haynes manual it has no mention of this. The fiesta one does state CVH/PTE so im wondering if theres a mix up on that because a FRST and ERST engine are near on identical.
Old Mar 5, 2006 | 08:16 PM
Mr Shannon's Avatar
Mr Shannon
Dont have a erst manuel to compair unfortunatly, its my engine btw..
Looks like I'll have to get me some plains
Old Mar 5, 2006 | 08:18 PM
SafeChav's Avatar
SafeChav
Get in touch with the place that sold you the shells and query them on it.......
Old Mar 5, 2006 | 08:33 PM
Mr Shannon's Avatar
Mr Shannon
First thing on my list todo for monday.
Old Mar 5, 2006 | 10:37 PM
G420 DEL's Avatar
G420 DEL
then at last we can start the rebuild
Old Mar 5, 2006 | 11:05 PM
Mr Shannon's Avatar
Mr Shannon
Old Mar 6, 2006 | 10:33 AM
Mr Shannon's Avatar
Mr Shannon
Spoke to the machine shop this morning and aparantly, "so long as the holes are in the right place they will be fine"..
Old Mar 6, 2006 | 12:32 PM
SafeChav's Avatar
SafeChav
Well, ask for that in writing, and if it doesn't work out you can sue their asses
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
