Amal Valve Operation and Adjustment
ok lets see if we can get some info on this for the techie room or Q&A Room or essay room etc
the only post i could find on the BB about drilling out restrictors etc was this one
http://passionford.webheberg.com/for...ic.php?t=19287
and i thought that mark was slightly wrong on what he was saying (ie run the car with no actuator pipe connected) seemed a little weird to me...
ok so on an amal valve you have 3 pipes right...
C which is your input
W which is your output
R which is your bleed
the way i understand it when the valve is in position 0 then C goes straight to W therefore it works as if there is no amal there and bleeds nothing so you will hit the boost that your actuator is set to
when the valve is in position 1 it will open the valve so that some of the air is bled via port R so as an example half of the air might be released via port R and so only half will leave by port W so your actuator will only see half the boost (in this example i'm assuming you have the restrictor on port R drilled out to bleed half the boost)
am i right sofar?
ok so then you need to go fiddling with your restrictors as you want to bleed more/less air out of the amal valve and also affect the way the boost comes in...
as i understand it if you increase the hole in port R you get more boost (in high mode) if you decrease the hole you get less boost
ok, so what about restrictions elsewhere. the valve i have has no restriction in port W but has a restrictor with a TINY hole in port C
from what i rememebr on threads from ages ago (ie not much!) this restrictor affects the reaction time. therefore a smaller restriction will mean the wastegate stays stuf for longer which will make the boost come in with more of a bang. it would also make the boost peak to a high figure and then drop right down to your decent held figure... right? (hence the peak n held boost a lot of people refer to)
so if you were to remove this restrictor completely it would make little or no difference to your overall held boost reading, but it would mean that you do not peak n then drop back... right?
so this is what you would want to do on a car that you intend to run boost very close to the Chip's Overboost function (ie if the overboost kicks in at 10psi you want it to peak 9 and hold 9 rather than peak 12 and hold 9 or peak 9 and hold 6)
are you following me sofar?
the amal valve i have here at the moment has NO restrictor in port W, a restrictor with a TINY hole in port C and a restrictor with a medium sized hole in port R.
since my car is one of those mentioned above with the overboost functionality, that would mean i want to remove the restrictor in port C does it not? and then adjust the size of port R untill i hit my desired boost setting... right?
ok, if i'm right (unlikely) this would be a good essay, but just needs all the questions removed from it so it looks like i know what i'm talking about... lol
am i right sofar?
lol karl.
can you just tell me if i'm right or not mate.
its what youve taught me (indirectly) in the past that this is based on, but ive got a bad memory and the posts where you told us on RSBB have been lost so cant re-read em
Jim, I dont usually advise on specific jettings because each car is different depending on actuator type and preload.
However as a very basic guide, you must always run a restrictor in the compressor union of the amal of around 2.5mm (or smaller if you require increased boost).
You can then alter the size of bleed restrictor to obtain the desired boost, a small restrictor in the bleed giving the smallest boost rise, where as leaving the bleed union totally unrestricted will give the maximum boost rise. (This is the same effect as unscrewing a bleed valve further, i.e. we make the bleed larger)
also i understand why u dont want advise on what to do on my car
the restrictor in port C on this smal i have is TINY, about 1mm ish? ive never examined a 100% std valve so dunno if this one ive got off mike is standard or not.
also the restrictor in port R is about 3mm and looks like its been drilled
(ps im talkin diameters)
oh ok.
looking at this valve the tiny restrictor in port C is a threaded bit of metal and i can unscrew it (how cool is that!) is this standard or has mike modded it? (i await the "ask him!" reply)
will the 1mm restrictor in port C be BAD in my case.
i intent to run half hole on the actuator (should give me about 3-4psi going on previous experience) and then use the smal to acheive a max of 9 but it cant peak any higher than 9 as if it hits 10psi it'll overboost n kill the ignition
PassionFords Creator
They are plastic as std, thats a shonky old carburettor jet jim
Get some std restrisctors and start from there.
Until you tell us what "you" want it to do, we cant tell you how to do it now, can we?
Originally Posted by Stu @ M Developments
Reason 1 Jim,
The sudden boost spike blows the fooker apart without a restrictor.
Mine has no restrictor at all in the C port and the R port is almost fully opened up. Airbox is obviously drilled too.
so u recon those sizes of restrictor i allready have in there are sufficient?
what u mean tell me what i want stu?
i want to run 9psi on high boost
i dont want it to ever hit 10psi
whatever i get in low mode i dont really care to be honest
thats all my requirements really TBH
i'll edit this post tonight to turn it into a mini-essay for the FAQ section methinks
Jim Galbally,
Stu @ M Developments,
Then stu reads the post properly.......
Guinnless,
The other issue with the C Jet is slowing the mass of airs passage to the actuator, to bring her on boost harder and faster by effectively keeping the signal pipe depressurised a little longer...
The topic can go on... complex little things really if ya know what to do with em
Bringing this post back from the dead as it was the best I could find on the operation of the amalvalve.
Am I correct in thinking that the bleed through the R determines how high the boost can be. But the boost doesn't necessarily go that that value, as the chip will determine at what pressure the amalvalve will close the R port?
So for instance if the restrictor in R is quite small, the boost might not be able to go above 1.2 bar, even though the chip is good for 2.0 bar. On the other hand if the restrictor has a bigger hole (or is even missing), the boost might go to 2.5 bar, but the chip will limit it to 2.0 bar (if that is the maximum for that chip)?
Or should you match the restrictor in the R port so that the maximum boost possible by the amalvalve matches the maximum boost allowed by the chip to prevent it doesn't boost too high?
Hi,
The way I read it from the training manual is the valve bleeds boost off to delay the actuator operating.
So if you set the actuator to open at 10psi, if piped directly, then the amal bleeds off boost to prevent it opening until you reach 20.
The only reason I can think of for altering the amal is if you fit a really strong actuator to run higher boost and the amal won't flow enough to open it?
Cheers,
Gavin
Cheers,
Gavin
Hi,
Cheers,
Gavin
Cheers,
Gavin
Martin
Hi,
Is it not possible to change the characteristics of the amal by using the amal table in the ECU? Reading above it all seems a complicated way to do things when there's a table to adjust it in the ECU?
Cheers,
Gavin
Cheers,
Gavin
