Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Technical discussion on building a bottom end.
Old Nov 26, 2005 | 01:15 PM
  #41
ronf42's Avatar
ronf42
having read this thread it has opened up my eyes to what is involved in engine building. I can now appreciate the time , skill and effort that goes into making a top performing engine. In turn it is fair to say that when people are quoted prices, we can see why.
I still want to have a bash at building an engine, in time i will have a go.
keep up the informative posts on this and many other tech subjects, it does make some interesting reading and can only benefit our fellow enthusiasts
Old Nov 26, 2005 | 01:21 PM
  #42
RS2000CUSTOM's Avatar
RS2000CUSTOM
Fantastic pictures, espeically of the work to the crank
Shame you havent got a before picture as well!
Crank was a standard 4x4 Cozzy item
Not got a pic though
Suppose any 4x4 Cozzy crank pic could be used for comparison
Old Nov 26, 2005 | 01:23 PM
  #43
Stu @ M Developments's Avatar
PassionFords Creator
Heres one but not a closeup
Old Nov 28, 2005 | 09:20 AM
  #44
Stu, thats still good enough for people to see the difference in the other one, especially the knife edging
Old Nov 29, 2005 | 09:38 AM
  #45
Red16's Avatar
Red16
what sort of price should i be expecting to pay to have a bottom end balanced with knife edged crank?
Old Nov 29, 2005 | 10:24 AM
  #46
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Good thread Chip mate. Will have a proper read when i get time
Old Nov 29, 2005 | 11:31 AM
  #47
Garage19's Avatar
Garage19
Very good thread chip.
Just like to add i usually use some graphite based assembly lube.
I'm not usually sure how long it will be between build and running so prefer this to engine oil.
Are you going to cover running in practises after this? Makes sense and always generates some good discussion!
Old Nov 29, 2005 | 11:58 AM
  #48
Im not mate, you are, in the new thread you are about to start
No excuses!
Old Nov 29, 2005 | 12:12 PM
  #49
Porkie's Avatar
Porkie
Soooooo over my head!!! my its threads like these that make this site sooo much better than other the other dross.
Old Nov 29, 2005 | 12:24 PM
  #50
davidreader5's Avatar
davidreader5
HI, All,
Chip good topic, only thing i can add is to also fit thrust washers & correct way round, also with the main caps fit in the correct location in the
block in relation to the front of the engine 12345, order,
and fit the pistons to rod's the correct way around, with the rings also in the correct order ie comp rings at the top of piston and oil ring at the bottom spaced around the piston before fitting into cylinder bore, keep rods & bigend caps also in order of removal,or if buying aftermarket rod's keep in order. some of this may seem obvious, but to other's a lerning curve which this topic is all about.
DAVE R.
Old Nov 29, 2005 | 12:31 PM
  #51
People may be interested in this CVH build topic i did some time ago, not very technical but very pictorial.
https://passionford.com/forum/viewtopic.php?t=99889
Old Nov 29, 2005 | 12:36 PM
  #52
Garage19's Avatar
Garage19
No excuses!
Ok, give me an hour and I'll see what i can do. No work this avo then!
Old Nov 29, 2005 | 12:47 PM
  #53
DaveR, i will cover most of that in the later chapters anyway mate, but yes those are all good valid points
Old Nov 29, 2005 | 01:59 PM
  #54
MONSTER's Avatar
MONSTER
another good read
Old Nov 29, 2005 | 06:37 PM
  #55
RS2000CUSTOM
http://www.wdbltd.co.uk
They are based in Halesowen - West Mids
Crank, Flywheel, Clutch Cover, Rods, Pistons, Con Rod Pins, Front Pulley and Crank Bolt.
All the above items are needed as all go towards final balancing.
Crank knife edged, all other components are lightened and weight matched.
ISO/BS Certificate issued "balanced @ 8000rpm"
This company also balances turbine rotors and are Rolls Royce approved.
Hopefully my picture shows their quality !
Cost for a Pinto/Cozzy bottom end balance and knife edge apprx £300
Old Nov 30, 2005 | 07:22 AM
  #56
Red16's Avatar
Red16
RS2000CUSTOM thanks a lot
Old Nov 30, 2005 | 05:40 PM
  #57
RS2000CUSTOM
No probs mate
Their works appears to be spot on
BUT
Only when engine is running can I pass a final opinion on how good they are
I am confident though !!
Old Nov 30, 2005 | 05:48 PM
  #58
Red16's Avatar
Red16
No probs mate
BUT
that sounds fair enough any idea when you will have the engine running?
Old Dec 13, 2006 | 06:43 PM
  #59
bud-weis's Avatar
bud-weis
Football Cwazy
wow,just remembered this thread,was a good time when we had the technical threads going
this one in particular goes to show why YB builds done properly cost what they do. there may be less than £2k of parts,but it takes hours and hours to properly measure,balance,prepare,weigh etc etc and then every nut and bolt needs to be torqued and loctite'd up.
if you think a companies price is really cheap,then it usually is for a reason no names mentioned
i loved building my old engine up, i didn't enjoy removing it and stripping it when it was covered in oil though
Old Dec 14, 2006 | 11:13 AM
  #60
Fudgey's Avatar
Fudgey
Baby Cheesus
got me worried now chip i have only done the assembly of my engine (built a few zetecs before with no probs)
i gave the block, pistons, rods and crank to the machine shop, so i hope they done all the neccessary measurements as then specced the bearings and bored the block!
i decided to go 0.5mm oversize on the pistons, so the block had to be bored to suit. the machine shop measured and numbered the pistons to go in the appropriately bored cylinder
and then the block was honed so the piston rings will bed in
they also polished the crank
and got the bearings, heavy duty big ends (left), and std mains (right)
didnt take too many pics of the build unfortunatly
pistons on rods
bearings and crank installed - the black stuff is graphogen grease
pistons and rods installed
head gasket, oil pump gasket and bolts etc
siemans 680cc injectors
piper cam kit
ported/polished and big valve head
head on
thats all the pics i have at the mo uploaded, ill try and find the ones of the cam kit installed, and the timing belt and pums etc on, but will take a while to find.
lightened billit flywheel, its a cosworth style one with a zetec bolt pattern to allow the use of a T5 gearbox
Old Dec 28, 2006 | 03:02 PM
  #61
AX Cossie's Avatar
AX Cossie
Great read!
Is there any difference or different recommendations for building a boosted engine rather than an NA one?
Old Dec 29, 2006 | 08:44 PM
  #62
Rs1's Avatar
Rs1
No differance in build practice but the clearances will be totally different from NA to forced induction.....mainly just in the piston to bore and ring gaps. The clearance will differ with each piston make(material) and will finally be determined by how the engine is to be used in terms of heat ranges,ultimate power figure and depending if you like a sniff of nitrous or not.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
