Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
-31 and -34 actuators, what's the real difference?
Old Dec 2, 2003 | 01:31 PM
  #41
Rob M666SCC's Avatar
Rob M666SCC
Originally Posted by dingy
springs....lol...
-34 better
-31 is shat. LOL
AROFLMFAO
What a muppet
PON on Rob's log in
Old Dec 2, 2003 | 02:04 PM
  #42
SapphyMike's Avatar
SapphyMike
so to run 22psi held. is a -31 or a -34 a better Actuator, as this is confusing LOL
Old Dec 2, 2003 | 03:02 PM
  #43
James Raby's Avatar
James Raby
I read it as being a -34 is better for high boost (over 15psi) applications
  #44
Stu @ M Developments's Avatar
PassionFords Creator
Well im glad someone read it
Old Dec 2, 2003 | 03:06 PM
  #45
Oranoco's Avatar
Oranoco
Now I'm totally confused
Good essay though Stu mate. Dunno what it means but it sounded good so I'll give you an A for it.
Old Dec 2, 2003 | 03:11 PM
  #46
SapphyMike's Avatar
SapphyMike
i did read it stu, but to me it reads that you can bleed off 10psi and set the -31 to 10psi, which by your essay looks like it cant be done because the -31 can only to 8psi?
Old Dec 2, 2003 | 03:53 PM
  #47
Mike Gurney's Avatar
Mike Gurney
what about using the 31 with a different sized restrictor
Old Nov 23, 2005 | 10:58 PM
  #48
bttt
Old Sep 21, 2006 | 01:18 PM
  #49
g4ost's Avatar
g4ost
Just got my -34 through the door this morning from yourself stu and now i think i understand a bit more
Great info, even if it is a couple of years old
Old Jan 23, 2008 | 03:41 PM
  #50
Diamonds.'s Avatar
Diamonds.
well i know what im gonna be putting on my turbo now for sure
Old Oct 8, 2008 | 11:54 PM
  #51
Smartdj.'s Avatar
Smartdj.
after reading this im going for da -34 im thinking...good thread
Old Feb 23, 2009 | 08:49 PM
  #52
Jimbo's Cossie's Avatar
Jimbo's Cossie
Originally Posted by Stu @ M Developments
IE:
We want to run 20.
So we load the -31 to say.. 10, and we bleed 10psi off via amal or bleed control, so the actuator ONLY gets to see 10psi.
When you say you load the -31, in what way do you mean? sorry to sound stupid, double checking somthing(thinking preload)
Old Feb 24, 2009 | 05:02 PM
  #53
JTECH James's Avatar
JTECH James
Passion for Fords!
yes preload
Old Feb 25, 2009 | 10:12 PM
  #54
Jimbo's Cossie
ah somthing james f knows all about judging by the actuators an rods he has destroryied.
Old Feb 25, 2009 | 10:14 PM
  #55
JTECH James
Passion for Fords!
i dont know why tho, i was running 36psi on my t34, and never broke a rod or actuator in over 60k miles
infact the same actuator is now on my t4...
has he jetted the amal?
Old Feb 28, 2009 | 02:24 PM
  #56
Jimbo's Cossie
not using it to my knowledge. bleed valve job.
Old Mar 1, 2009 | 02:20 AM
  #57
The T34 has a harmonic frequency problem on many YB's that cause it to sheer the shaft clean in two just where the locknut locks up the adjustable rod end.
This is why Garret redesigned the rod end for the T34 and made a much longer one. Ive no idea why it doesnt afflict all engines.
Old May 10, 2009 | 10:57 AM
  #58
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Seems like i need a -34 then
Best ask Stu before ordering it as my car was set up on a -31 by him.
Steve
Old May 12, 2009 | 11:04 PM
  #59
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
So right let me get this straight.
Another newb here so be gentle.
My escort RS turbo make's 19psi but the atuator is stock looking i know they do stock looking -31's but would i need a -34?
Old May 14, 2009 | 05:41 PM
  #60
Karlos G's Avatar
Karlos G
Balls Deep!
If your wanting to hold 19psi then you could use a -31 preload set to 10psi and bleed 9psi off, or you could use a -34 preload at 15psi and bleed off 4psi.
Or there abouts!
wowk
Mar 30, 2021 07:49 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
