Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Ways to combat detonation?
Old Nov 14, 2005 | 02:20 PM
Garage19's Avatar
Garage19
Default Ways to combat detonation?
What are the best ways of combating detonation?
Mapping a friends engine at the mo, but have had to remove alot of ignition advance to get rid of the detonation.
Down to about 13 deg @ 0.5 bar under load.
I think most of this is due to the poor chamber design he now has after fitting a decomp plate (no more squish).
I know that backing off the advance moves the ignition event back in the cycle and lowers the post ignition cylinder pressures which in turn prevents post ignition gases from igniting on their own after the spark.
I was just wondering if there are any other methods of reducing det that i could use?*
The ACTs are already pretty low and the engine also runs at a decent temp.
Would water injection give me any det protection other than cooling the charge?
I realise stu might not want to give away his secrets, so one for the home mappers really.
Any suggestions welcome.
Cheers,
DC.
* bar removing the plate and rebuilding with some dished pistons and/or careful enlarging of combustion chamber. Not my engine so can't open it up.
Old Nov 14, 2005 | 02:36 PM
What AFR are you running?
Fuel is a pretty good Det surpressant!
Old Nov 14, 2005 | 02:46 PM
AlexF's Avatar
AlexF
your options are:
a bit more fuel...
lower the boost....
drop the act....
back off the ignition.
Its best to run as much ign as you can even if it means dropping the boost.
Alex
Old Nov 14, 2005 | 03:02 PM
Garage19's Avatar
Garage19
Currently running 12:1 at that point in the map.
Old Nov 14, 2005 | 03:20 PM
Pretty much forget about running any more fuel then!
Looks like the options are pretty minimal!
What CR is it?
Can you do anything about that?
Old Nov 14, 2005 | 03:25 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I would not recommend using WI as a det suppressent, as if / when water runs out / jet gets blocked - engine goes BANG.
Old Nov 14, 2005 | 03:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
could say same about fuel injectors tho surely? and idve thought, providing you got a decent setup, no greater risk?
Old Nov 14, 2005 | 03:30 PM
Itsmeagain, its ok if there is some sort of warning i guess?
But most people with WI dont know its run out!
Old Nov 14, 2005 | 03:35 PM
Garage19's Avatar
Garage19
CR is a knats cock under 8.7:1.
Would like to be running 10psi in the end. I have dialed out all the det so far at 7 psi but it just seemed like quite a low advance figure for that boost/cr setup.
Do you think the lack of squish makes that much difference?
Not sure that shed loads of fuel is the best way to combat det / run an engine. Our local so called tuner once showed me a RR printout of his cossie running 9:1 afr and seemed to think it was fueling great!
Old Nov 14, 2005 | 03:39 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
8.7:1 isnt exactly high compression, so thats lil strange.
GTST skylines are 9.5:1 as standard and ive seen them running 1.5bar no problems on pump fuel
Gotta be down to huge squish area surely? Prob would work better without the decomp plate!
Garage19's Avatar
Garage19
Ok... aprt from the running out aspect, does it do anything to help suppress det apart from cool the charge?
I have monitored the ACTs on this engine and as far as i can remember they were pretty good.
Old Nov 14, 2005 | 03:45 PM
Garage19's Avatar
Garage19
Thats what i mean. Would love to see an ignition map from a car that spec.
Think it must be the lack of squish that encourages the det?
Old Nov 14, 2005 | 04:01 PM
Jasesapphy's Avatar
Jasesapphy
I run 11psi on a 10.5:1 engine, that has cast pistons
Old Nov 14, 2005 | 04:39 PM
AlexF's Avatar
AlexF
I know its obvious...
but what engine is this?
Alex
Old Nov 14, 2005 | 06:19 PM
Billabong's Avatar
Billabong
I'll wager that Mike means you shouldn't really utilise WI as a normal means to reduce det' when mapping - ideally, WI should be the last resort, a safeguard to combat high charge air temp's (yes that's CAT's not ACT's ).
I.e. WI shouldn't be kicking in whilst driving around normally.....
Another option is higher octane fuel, but again this is a compromise, unless you have easy access to run it all the time (or dual maps)
If you can't reduce det' to an acceptable level, then something is amiss (as you've already said) - do you really want to map a 'compromised' engine??
Old Nov 14, 2005 | 10:37 PM
GARETH T's Avatar
GARETH T
how old is the fuel in the tank?
Old Nov 15, 2005 | 09:01 AM
Garage19's Avatar
Garage19
Fresh optimax, so not that.
Old Nov 15, 2005 | 09:04 AM
Billabong's Avatar
Billabong
What engine and what management?
Old Nov 15, 2005 | 09:30 AM
Garage19's Avatar
Garage19
BMW 318 is
Megasquirt!
Old Nov 15, 2005 | 09:39 AM
Billabong's Avatar
Billabong
There's a knowledgable chap who knows his BMW's on here and a couple of users with Megasquirt experience also. Maybe edit the post title and add BMW 318 & Megasquirt.
Old Nov 15, 2005 | 09:58 AM
Garage19's Avatar
Garage19
Cheers Billabong.
This is my fourth MS install/mapping. So pretty familiar with the MS kit.
But being my fourth engine to map, still on a steep learning curve where mapping is concerned!
Old Nov 15, 2005 | 01:49 PM
AlexF's Avatar
AlexF
I know both systems
Its not an ideal engine to turbocharge, your porbably finding the limits of the combustion design.
Alex
Old Nov 15, 2005 | 01:50 PM
AlexF's Avatar
AlexF
can you upload the maps?
Old Nov 15, 2005 | 01:53 PM
Stu @ M Developments's Avatar
PassionFords Creator
You have changed the spark plug heat range havent you?
Old Nov 15, 2005 | 02:40 PM
Stu, that sounds MUCH more likely than chamber design and squish at such low levels of boost!
Old Nov 16, 2005 | 10:36 AM
Garage19's Avatar
Garage19
Stu,
So what your saying is the plug electrodes are running too hot and in turn causing the detonation?
So simply trying a cooler running plug may help?
Will give this a try at the weekend. Dial some of the advance back in and let you know the results.
Thanks,
DC.
Old Nov 16, 2005 | 10:37 AM
Keep us posted, very interesting topic
Old Nov 16, 2005 | 10:45 AM
Garage19's Avatar
Garage19
Will do. Should have a chance to re map on sat.
Chap is putting a new clutch in it as we speak. Last mapping session, as we started pulling the fuelling map closer to ideal the worn clutch started deciding it couldn't cope with the new found torque!
Old Nov 16, 2005 | 11:35 AM
Garage19's Avatar
Garage19
New plugs puchased! Gone from NGK 7s to 9s.
Two steps cooler. Hope it works.
Old Nov 16, 2005 | 11:47 AM
NGK 7s on 7psi at 10.5:1.... Detonation or not, that could have killed her stone dead.
Old Nov 16, 2005 | 11:48 AM
Smit's Avatar
Smit
The 60ft Launch King
Keep going Doug
Silly question but who's beemer is it?
Stu - Thought Doug said it was around 8.7:1
Old Nov 16, 2005 | 11:56 AM
Garage19's Avatar
Garage19
Smit,
A friend of mine. Not sure you know him.
If you are down the pub (sorry, truck stop ) next Wed i will try and bring it along. Will take you for a spin if yer fancy it?
Yep 8.7:1, but been doing some research i think Stu is right about the heat range of the old plugs. Way out!
Old Nov 16, 2005 | 11:59 AM
Doh.... didnt read deeply enough to realise it was decompressed
Old Nov 16, 2005 | 12:04 PM
Garage19's Avatar
Garage19
Eye, but with an aluminium plate!
Chap bought it from Ferriday. I was a bit worried about it so had a chat with Mike something un pronouncable from ferriday and he seemed to think it should work as an extension of the head and hold the cylinder pressures ok.
Seems to be holding up ok so far...
Still loose any decent squish the piston/head design had though!
DC.
Old Nov 16, 2005 | 12:18 PM
Smit's Avatar
Smit
I'm on nights next week Doug so won't be up the trucky
Be there the week after though as i'm on 2-10
Got a picture of the turbo conversion, sounds kinda funky
Old Nov 16, 2005 | 12:20 PM
Squish is of course very important, but its not the end of the world at those power levels.
Lots of people on big (well ish relative to cossies!) power vauxhall engines use 1.9mm gaskets to lower the CR and seem to get away with it just fine.
Obvously taking some metal out without ruining the squish would be better, but i personally dont think its that causing the problem.
Old Nov 16, 2005 | 12:21 PM
Is it using a eurpean 323 TD manifold?
Old Nov 17, 2005 | 09:21 AM
Garage19's Avatar
Garage19
Nope. Custom tubular exhaust manifold and modided stock inlet.
Surely a 323 would be a six pot? Or did Europe get a four pot version?
Old Nov 17, 2005 | 11:40 AM
AlexF's Avatar
AlexF
Alex
I havent quoted myself before....
A decomression plate is a bodge!
Thats why your getting det, very bad combustion chamber design. You've change the attributes of the CChamber completely, things like squish, flame front and end gasses are now completely different to the original design.
Alex
Old Nov 17, 2005 | 11:41 AM
sorry mate, wasnt paying attention, thought it was a 6 pot engine, i just saw bmw and my mind refused to admit any less number of cylinders
