Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Ways to combat detonation?
Old Nov 18, 2005 | 08:20 AM
  #41
Stu @ M Developments's Avatar
PassionFords Creator
Any updates on this problem?
Old Nov 18, 2005 | 09:00 AM
  #42
Garage19's Avatar
Garage19
All that garbage about grammar has gone!
New plugs are in. Installation of new clutch should be finished today.
Should be able to have a good mapping session on sat morning.
Depending on how the mapping goes we should be able to get on a set of rollers @ LPS for a power run at lunch time.
If we do i will try and post up a copy of the run with some screen shots of the fuel and ign maps and maybe datalogs. Prob be like putting myself in front of a firing sqaud, but any advice (as long as it is constructive) will be most welcome.
Stu, I will let you know what difference the plug change makes to the amount of advance i can run. I think it was a wise safety mod that i had overlooked even if i can't run any more advance. Cheers.
Doug.
Old Nov 18, 2005 | 09:03 AM
  #43
Anyone with nothing constructive to say can be deleted from the thread, fook em pal.
Your welcome, pleased to help.
Old Nov 18, 2005 | 09:09 AM
  #44
Top stuff, keep us posted
Old Nov 18, 2005 | 09:14 AM
  #45
AlexF's Avatar
AlexF
How thick is the decomp plate?
I've got the same engine down stairs in pieces, I could have have a look at wether its going to make an obvious problem if you like.
alex
Old Nov 18, 2005 | 09:20 AM
  #46
Garage19's Avatar
Garage19
Cheers, will up date sat and post up all the data in works time on monday!
Old Nov 19, 2005 | 05:21 PM
  #47
AlexF's Avatar
AlexF
any updates?
Alex
Old Nov 21, 2005 | 08:06 AM
  #48
Garage19's Avatar
Garage19
Right,
Here goes for an update.
After changing the plugs and the new clutch being fitted we decided to crack on with an early morning mapping session on sat.
How early? The MAT sensor was reading 1 degree C at about 0700 hours!
Still, at least alowed us to do a bit of work on the cold start enrichments
We also re set the temp that the closed loop kicked in.
We took it out for a spin. Everything was going well running on the previous ignition map. This was the one with low advance figures but no det.
The sensible thing to do at this point would have been to map in some more advance to test the effects of the colder plugs but......
knowing that there was a chance off a rr run at lunch we decided to chase numbers and go for some more boost!
Actuator was adjusted and we went from 7 to 11 psi (176kpa).
The ignition map only needed the slightest tweek at a couple of high load/low rpm sites to have no det at 11psi so maybe the colder plugs were helping?
At this point we went for a huuuge (8 quid each) fry up breakfast and then headed for the rollers.
When we turned up at LPS there were a couple of Loti there, an Exige and an Esprit.
The Esprit was just having a run on the rollers. It was a citrine yellow/green L reg 300GT. Apperently something to do with a le-mans car and they only made 64? The last four pot turbo esprit. Had huge 315 tyres on the back.
Owner looked very chuffed when it made 298bhp with a bar of boost.
So we loaded our car on the rollers.
At this point i must confess to telling a small fib The engine in qustion is a S14 and not a 318is.
Here is a picture of the lump ready to go.
To cut a long story short, she made 296.5bhp on 11psi. Lotus owner who had been looking down his nose at a shonky old D reg BMW was very supprised
I thought it was running to rich so i backed some fuel off at the top end but it mad no difference to the figures so we left it rich.
Dyno graph and ignition map and fuel map will follow shortly.
Doug.
Old Nov 21, 2005 | 08:21 AM
  #49
Congratulations
Old Nov 21, 2005 | 09:19 AM
  #50
Fudgey's Avatar
Fudgey
Baby Cheesus
well done doug, shold be right little stormer!
Old Nov 21, 2005 | 09:32 AM
  #51
Jasesapphy's Avatar
Jasesapphy
Intesting read as im running a high compresssion engine with a turbo. time for some development maybe
Old Nov 21, 2005 | 10:02 AM
  #52
Garage19's Avatar
Garage19
Thanks,
Still got a bit of work to do. Struggling to get the accel fueling perfect. Still get the occasional bit of bogging when you stamp on the pedal in certain situations.
The old girl does fly. Tramped past another older Esprit (must have been a club meet?) whilst mapping earlier that morning at an indicated 150mph.
I was too busy looking at the laptop and listening to the det cans to be worried until I glanced over at the speedo.
Old Nov 21, 2005 | 12:38 PM
  #53
rsnissan's Avatar
rsnissan
sweet conversion
i love those M3's it was between one of them and the cossie and i am still toying with the idea of getting one
Old Nov 21, 2005 | 05:41 PM
  #54
Billabong's Avatar
Billabong
Cool, glad you made good progress
Old Nov 21, 2005 | 06:41 PM
  #55
Fiecos Dan's Avatar
Fiecos Dan
good topic,
Originally Posted by Garage19
Right,
Doug.
wot fuelin did you change from and too?
Old Nov 21, 2005 | 08:15 PM
  #56
M K's Avatar
M K
lovely looking bmw doug,,,,,,,,,,
well done on the home mapping skills mate,,,,,
hows your kit car coming along mate
marc
Old Nov 21, 2005 | 08:16 PM
  #57
Smit's Avatar
Smit
The 60ft Launch King
1.8 my hairy arse you fibber
Awesome results
Old Nov 22, 2005 | 10:36 AM
  #58
Garage19's Avatar
Garage19
marc
Not much work on the kit car recently.... too busy working on this biggers BMW and trying to keep up with the flocking.
When is the fiesta going to be on the road?
Old Nov 22, 2005 | 10:37 AM
  #59
Garage19's Avatar
Garage19
Awesome results
Cheers Smit. How did you know i had a hairy arse????
Old Nov 22, 2005 | 10:42 AM
  #60
Garage19's Avatar
Garage19
Greg, who runs Hanger 111, the Lotus shop at LPS just e-mailed me these photos.
How much of a plum do i look!
And the dyno sheet from the run.
Will try and post a copy of fuel/ign maps when i figure out how to capture a screen shot and turn it into a jpeg????
Old Nov 22, 2005 | 11:07 AM
  #61
Fudgey's Avatar
Fudgey
Baby Cheesus
sweet
nice earmuffs, was it a bit chilly?
Old Nov 22, 2005 | 12:53 PM
  #62
AlexF's Avatar
AlexF
looks great
Why did you keep us in the dark over the engine types thou
Old Nov 22, 2005 | 01:20 PM
  #63
Jim Galbally's Avatar
Jim Galbally
why has nobody mentioned using castrol RS to prevent the detonation
Old Nov 22, 2005 | 02:24 PM
  #64
Garage19's Avatar
Garage19
Eh?
Old Nov 22, 2005 | 02:35 PM
  #65
The fooking pain
You had to be there...........
Old Nov 22, 2005 | 02:39 PM
  #66
Eh?
<- real rears at "USL"
Old Nov 22, 2005 | 02:50 PM
  #67
Garage19's Avatar
Garage19
Ok, here is the ignition map we are running in the BMW.
Note the low advance figures at mid rpm high load.
Load figures are in kpa. For those not used to working in kpa a quick explanation:
< 100 = vacum
100 = atmosphere
200 = 1 bar of boost
At the moment we are not running any more than 175 kpa (11psi).
Any comments welcome.
Cheers,
Doug.
Old Nov 22, 2005 | 03:03 PM
  #68
Sorry Doug, what compression is this motor? Engine CC and Turbine Ratio.
These figures are all looking quite high initially for a quite high compression Turbo motor.
Old Nov 22, 2005 | 03:06 PM
  #69
GARETH T's Avatar
GARETH T
maybe zero degrees isnt zero?
Old Nov 22, 2005 | 03:18 PM
  #70
Garage19's Avatar
Garage19
Stu,
CR is 8.7 engine is 2300cc.
Not exactly sure what you mean by turbine ratio. Can you explain?
It has a .63 exaust housing with a stock 4x4 turbine wheel if that helps?
Other things that you night want to know:
The engine has quite an oversquare bore/stroke ratio and runs a fairly large 93.5ish mm bore.
It once was NA of course so still has NA cams with loads of overlap. Chain driven cams so vernier wheels are expensive/rare/tricky for us to make.
I think the NA cams might contribute to a relativly low dynamic CR?
Cheers.
Engine has quite a high
Old Nov 22, 2005 | 03:24 PM
  #71
Garage19's Avatar
Garage19
Good point. But i have checked the idle figures with a stobe and am sure they are right +- 1 degree.
Old Nov 22, 2005 | 03:27 PM
  #72
Yeah looks possible
  #73
GARETH T's Avatar
GARETH T
thats the way i do it aswell mate
Old Nov 22, 2005 | 03:30 PM
  #74
The map looks fine, other than a lack of progression in the lower speed advance maps. All that will cost you is low down torque.
The figures still look higher than i expected you would get away with though, but if they work they work, like you say, the overlap may mean your not filling the cylinders as well as the specs suggest.
Job welldone if its all working
Old Nov 22, 2005 | 03:32 PM
  #75
Garage19's Avatar
Garage19
Yeah looks possible
Really, out which way? unless I've muddled the timing marks on the crank pulley by a mile Don't think it is out but will double check too be sure.
Old Nov 22, 2005 | 03:47 PM
  #76
Well providing you are keeping the PCP late enough (ie no det) it MUST be all ok mate, TBH even if the sensor was misreading slightly it wouldnt matter anyway as its not like you are going to drop the map onto another car!
Old Nov 22, 2005 | 03:48 PM
  #77
Garage19's Avatar
Garage19
Right at the top of the rpm 6300+ it just seemed to want more advance. I had lower figures but it just seemed to stop it revving.
There was no det up there and it revved out a lot better with some more advance.
Cheers Stu. Thanks for all your advice. The plug rating was a good catch that could of turned nasty I'm still on the really steep bit of that learning curve
Old Nov 22, 2005 | 03:51 PM
  #78
There are a few golden rules to follow, but they may be best added to my mapping essay to keep it topical and interesting... perhaps you should copy your map over there and we can discuss it further if you like.
Old Nov 22, 2005 | 03:56 PM
  #79
Garage19's Avatar
Garage19
That would be cool. See you in the other topic.
Old Nov 22, 2005 | 07:08 PM
  #80
Smit's Avatar
Smit
Nice ear muffs
