Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
map sensor question people
Old Jan 8, 2004 | 10:34 PM
RSCossieGaz's Avatar
RSCossieGaz
Default map sensor question people
whats the difference between or the benifits between a 3 bar map sensor and a 5 bar map sensor?
info please guys
Old Jan 9, 2004 | 09:47 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the only difference as stated is that one will measure to 3 bar (absolute pressure = approx. 2 bar above atmospheric pressure) and the other up to 5 bar.
generally, map sensors are supplied with a voltage (say 5V) and then their resistance changes with pressure so that the voltage measured across them varies, say from near enough 0V (0.25V) (very high resistance) at near enough 0 bar absolute (which is a vacuum, so created by the sucking of the engine against a closed throttle) to 5V (4.75V) at 3 or 5 bar (very low resistance).
so for a 3 bar sensor, you have a scale of 5/3 = 1.67 V / bar
and for a 5 bar sensor, you have a scale of 5/5 = 1 V / bar
your ecu is a digital device and needs to convert this device into a digital signal made up of 1's and 0's. this is done by a digital to analogue (d/a) converter, and depending on the ecu, this converter has a certain resolution, e.g. 16 bit. this resolution means how many 1's and 0's the digital number can be made up of. 1 bit can be either 1 or 0, 2 bit can be 00, 01, 10 or 11, etc.
therefore for a 2 bit d/a converter, you can see that the voltage signal can only be divided into 4 numbers so it cannot really see the difference between the 1V (approximately 1 bar on a 5 bar / 5V) and 1.2 bar / V or whatever.
therefore if you are only running 2 bar boost on a 5 bar sensor, the resolution of the d/a converter means what you are trying to measure will not be as accurate as if you were using a 3 bar sensor.
so it should be clear that you should use a sensor appropriate to the boost range that you are running.
having said that, i don't know what the resolution of the d/a converter is in a ford or marelli ecu. if it's 16 bit, you can see that the range can be divided into 2^16 (over 65,000) so it shouldn't make a lot of difference what sensor you use. if it's just 8 bit, this goes down to just 256 (still just 0.02 V or 0.02 bar on a 5 bar sensor which is still good enough). 4 bit is just 16, so 0.3 bar which is not really good enough.
hope this helps. if any mistakes spotted by anyone, please feel free to correct me (values used are not totally accurate, just to give an idea), and voltage values do not necessarily apply to any particular car, just an otline of the principle.
Old Jan 9, 2004 | 10:02 AM
Stu @ M Developments's Avatar
PassionFords Creator
Fantastic essay
When Gaz is happy with hsi response, il add it to Tech essays or FAQ
Old Jan 9, 2004 | 11:03 AM
agreed, bloody good essay but wait, oh no ive gone cross-eyed!
Old Jan 9, 2004 | 08:18 PM
ML's Avatar
ML
Originally Posted by Stu @ M Developments
Fantastic essay
Old Jan 16, 2004 | 08:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i'll add it to Tech essays or FAQ
BTTT to be moved
Old Jan 16, 2004 | 10:41 AM
And moved it is.
Old Jan 16, 2004 | 05:48 PM
RSCossieGaz
sweet
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Tim Wharton
Aug 30, 2015 05:46 PM
Tim Wharton
Aug 28, 2015 08:26 PM
costina
18
Aug 25, 2015 06:02 PM
