Rosso red Rs turbo build and progress.
#161
What gearbox are you using?
#163
300+
Spoke to a James wills @ Auto Dynamix about making me a plug and play loom for the Link G4 Storm management I have ive just got to make some measurements and a little diagram and get them back to him along with the ECU for bench testing ..ive just ordered a new electronic boost controller that relays with the ECU ..i just need to figure out what sensors and positions I need and then its all systems go once the engines in ..
#165
I doubt if you get a manifold off Gary the turbo will sit there. More than likely be over to the gearbox side abit. That's a bad manifold witch I don't think is designed for a cvh.
#167
300+
Well the cars getting moved via flatbed from Sheffield to Wales so I can start getting everything ready for the new engine drop ..and then start fitting all the supporting mods
#176
Lovely looking car this and very tasteful mods
Rsmat (11-11-2017)
#178
300+
Got message Sunday just gone the other crank I supplied (s2) was not standard size on all ..one needed to be .25 ..so I contacted the seller and he's exchanged it for another std size crank ..just waiting back from engineer to confirm ..fingers crossed .
Testing my patience now this engine build !
rs220bhp (22-11-2017)
#180
300+
Got message from AL developments today ..std size crank is spot on..so it's going to be a blue printed build now ..winters set in here so I'm in no rush ..fingers crossed it's going to be a epic CVH build now ...cant thank Andrew enough .
Rsmat (26-11-2017)
#182
300+
Yea there actually a really good engine once you start squaring and preventing the problems they ran ..the heads the week point so all mine as been paid attention to solve that and the oil pressure issues they run ( no more worn cams hopefully ) ..and the inlet and exhaust are going to a more efficient item as my builds going to be as efficient as possible ..so we can run good power with less boost and less stress that's the idea about blue printing and balancing the engine so it's nice free flowing ..so fingers crossed it all works out mate .
#183
look forward to seeing what power this puts down, i still have a fully balanced bottom end and a stg3 head on my escort was somewhat limited by the MFI, used to spool nice and pull like a train.
Tempted to put rods and pistons with my management see how it preforms.
#184
300+
Tbh mate ive no power figure in mind anything between 270 and 300 would be fine for me ..been told it will do 300 with ease ..it will be what it will be ...and you're spec sounds great get some rods and pistons in and will go well on managment .
#185
i was 187 at the wheels 14-15 psi but like it safe i have a set of rods and management just require pistons.
300 would be a very nice figure TBH i would be delighted if my ST engine made that.
keep up the good work.
Rsmat (28-11-2017)
#190
Got to agree I’m on my 3rd set
Rsmat (01-12-2017)
#192
Get pics up once fitted...
#194
This is shaping up to be a monster spec car. Any engine news pal?
#196
Wheels are gorgeous
Rsmat (08-12-2017)
#198
300+
On Sunday the car will be moved again to my premises where I will fit the wheels and brakes and start by removing the engine and strip a lot of stuff off ..as I'm going to machine polish under the bonnet and spruce it up a little more ..then wait for the new engine to arrive ready to drop .
#200
300+
Cheers westy mate ..it broke my heart to lose the rs7's but I need the braking power and they was crap for fitting brakes under .
