3dr door sierra cosworth rep - zetec turbo
Hi guys aint been on here for a while, am half way through my latest project and is when I like to start a thread so here goes.
I bought a 3dr shell (red one in pics below) and was the cleanest one I found. I then found a full genuine 3dr cosworth kit , bumpers,arches,skirts and spoiler.
I had my eye on a few bonnets but they were silly money so I bought another 4x4 sierra as it had a genuine bonnet (over the top I know) I sold the engine out of it which almost coverd the amount for the car so was happy with that. I also got 2 of the mintest front seats I had seen and the dash was really tidy. I took the 4x4 front subframe setup as had all been polybushed so turned out good buying a whole car just for a bonnet
Cutting the rest short all my bits sat around for a year or so as didn't have the space to do it but moved into a bigger workshop 6 months ago so work started on the red shell straight away.
I go to classic ford every year and have always taken an old ford and I'm trying my best not to let the 2014 show be any different.
On with the pics
I spent a few weeks going round the outside sorting the bodywork as I wanted it in primer asap, I cant find any earlier pictures as I lost my phone, some work had already been done
I spent a while carefully unpicking the front wing of the 4x4 as it was mint
This was the heart of the workshop keeping us nice and toasty, waste oil burner
Then I put abit of black base over everything for rubbing down purposes
This is the next day and pushed outside
I took everything from underneath of the 4x4 and used them so I spares and Had my rear beam, trailing arms and other bits sand blasted then gave them a couple of heavy coats of 2pac primer then 2 heavy coats of 2 pac black
Gave them a couple of days then started to fit things back together
Everything was stripped from underneath ready for cleaning and painting, couldn't help but offer the kit up
I then had a bad couple of weeks and just decided fuckit the underneath is getting done in black shutz not a heavy thick coat just a light dusting. I actually like it as the car is never going to be concourse and it will always be just a rep. I didn't get any pics of that but I then got on with building up the rear end
Lsd diff from the 4x4
I'll up load more pics tomorrow as still got plenty.
will also give full details of engine spec and power I'm aiming for.
Not the best of pictures so far but so much hard work has got it this far and I'm happy with the results
Any comments welcome. thanks
On with the pics
I rolled the front end from the 4x4 outside for a clean off and ready to go back on as was all either new or mint with polybushes
A few days later I started fitting the engine bay back up with nice shiney clean parts
A few more bits back from being blasted and painted
had a 2.0l zetec flywheel skimmed flat then cosworth clutch cover bolts drilled and tapped into it, new cosworth paddle clutch so no slippy slippy
The next night I got carried away and something happened
2.0l zetec with focus rs pistons and rods
I had to make engine mount up (spent a while getting the engine sat right)
Also made my own alternator bracket so it cleared my inlet manifold
Was waiting for my heavy duty valve springs to arrive and couldn't wait so rested the head in place and with 2 other bits, T4 turbo sat on a 200sx tubular manifold I modded the bottom half of a rover inlet with 100mm square box section and the edges machined down to make it look less boxy, 80mm throttle body with fiesta turbo tps mounted on the side.
Then back to the paint booth and painted the tank
few bits arrived with the posty
rs500 clocks that I've been saving for a few years
started making a few bits (water pipes etc)
oh nice
Then these arrived
saw this on facebook thought it was funny
This will be 2nd in charge controlling things, ms2 v3
along with these emptying the tank
siemens deka 650cc injectors
oh nice
Then these arrived
I then fitted my new valve springs, got head skimmed then bolted it down
I fitted everything else on the engine and wired in the ecu and yes the bloody thing didn't start I spent a few days going over it and found a broken wire at the main ecu plug and it fired straight up, I was a very happy bunny
small crap vid - runs abit ruff but it will do till I can get it mapped
Can anyone recommend somewhere to get megasquirt mapped on the rollers? am in south kent but I WILL TRAVEL ANYWHERE cos I'm dedicated in getting this done for classic ford oh and my sanity as this car has taken so much time and effot as have done most of it on my own I need to have it done before it kills me lol
Then thought I'd drive it out of the workshop for the very first time, I even had an audience then realised my mis match of clutch wasn't right the pinto clutch bearing needed a spacer so I walked down a few workshops and I asked my engineer friend to make up a 15mm spacer, I carefully welded the spacer to the blearing without overheating it
After fitting the spacer the clutch worked an absolute treat was really happy and theres no way its going to slip on boost as its got the typical paddle judder when pulling away but if your seeing that then pulling away like a pussy
But to fit the spacer I had to do this
while the engine was back out I gave my home made remote thermostat housing a tweak and now works perfect with the water return for the heater matrix and my threaded nut for temp sensor
Theres probably a whole day of thinking chopping and welding just on this one piece
fancy stainless clips
custom 3" downpipe I made, going to be heat wrapped
genuine ford timing belt
I've got a few more bits I want to do tomorrow so will keep you all updated step by step
Oh and plans are, I want 350hp out of this at maybe just over a bar of boost (shouldn't be a problem with my setup right?)then next winter i'll take it out and put some shiney strong internals in it.
Thanks for any comments its what keeps a man like me sane as the misses couldn't care less and thats why I understand that picture of the bird tied up further up ^^ lol
TT T38 Power
Get yourself along to this meet
https://passionford.com/forum/south-...april-3rd.html
Steve
Ben
Awesome! I'd go for base spec looks though, proper sleeper!
I have problems remembering what I done yesterday let alone 4 or 5 years ago lol
Steve
Steve
Thanks I was on your thread the last time I was on here and that's where I got a rough power estimate from for mine
Am using a 1.8 cvh sierra starter on an mt75 box and works perfect.
Thanks to all for comments
Hi guys it's been a while, as I'm sure you can guess it never made it classic ford last year I ended up taking a pink mk4 escort cab .
Classic ford 2015 is less than 2 months away and I have been a busy bee. The long overdue update is here. Pictures...
New purchases
A very pretty new sump as wernt to keen on the cvh one
Little bits.. I'm going to replace the Cosworth part of the decal with a zetec sticker in the same font. Shinny new wheel nuts and SARD fuel pressure regulator.
Then the pictures you been waiting for I finally got some colour on it. I spent a long time blocking the primer down and it's perfectly straight and I'm really happy with the outcome.
I'm a little bit further than this I will upload more pictures of how far I am tomorrow.
Comments welcome
Thanks for looking
New purchases
Comments welcome
Thanks for looking
Looking good.
Coming along nicely
Coming along nicely
