Ford 100e ST
Old Oct 22, 2011 | 08:53 PM
  #81
rizla's Avatar
rizla
What a first class job
Old Oct 23, 2011 | 03:33 PM
  #82
surrey_100e's Avatar
surrey_100e
Originally Posted by orangepeel
hey, top class work!!!!!! im thinking of puting the 2.5 st engine in my cortina. is it a tall engine, have you dry sumped it for that reason?
does the mazda bellhousing also fit?
keep up the top work
niall
cheers
yeah its a pretty big engine, i can give you dimensions if you want so you can get a rough idea, and yes the dry sump is the only reason otherwise it would foul on crossmember and steering rack, ive had to recess the bulkhead loads too for the depth.
As far as im aware the mazda wont fit, its all a mix of volvo and custom parts, and lots of r&d.
Old Oct 23, 2011 | 07:03 PM
  #83
RST's Avatar
RST
Looks a mad project, and to an amazing standard love it
Old Oct 24, 2011 | 01:08 PM
  #84
orangepeel's Avatar
orangepeel
Originally Posted by surrey_100e
cheers
sent you a pm mate
Old Oct 31, 2011 | 05:39 PM
  #85
oxb1l's Avatar
oxb1l
Fantastic !
Should be awesome when you've finished
Bill
Old Nov 14, 2011 | 07:16 PM
  #86
surrey_100e
small brief update on some recent purchases
input shaft bearing to sit in the crank, fits spot on
new rs flywheel bolts and clutch bolts
ap cosworth 6 paddle clutch plate
volvo 850r heavy duty cover plate
t5 hydraulic clutch kit
got the exhaust all tig welded up Name:  IMG_1050.jpg
new exhaust bolts and gaskets, may as well have walked in with my trousers down for these
also finished the door panels, just got the rear firewall to do and finish the carpet
..... Name:  empty-wallet1.jpg
:sad3:
also going to hopefully have the gearbox rebuilt next week and get the prop made to suite so its getting there. Still lots ive got to get, the last install of the year will be all the water and boost hoses, that will be it for this year, come january/feb all the oil and fuel system will be purchased and march/ april i should be able to afford the vipec v88 ecu and custom loom... hmmmm sounds so easy when you say it like that
Old Nov 14, 2011 | 07:28 PM
  #87
hogdog's Avatar
hogdog
Great project!
Who did the exhaust parts? They're a work of art.
Old Nov 14, 2011 | 07:31 PM
  #88
surrey_100e
Originally Posted by hogdog
Great project!
cheers buddy, i made them myself and tack welded it all together and got a local company to fully tig it
Old Nov 14, 2011 | 07:37 PM
  #89
RichieST's Avatar
RichieST
Nice selection of bits there mate! I bought a downpipe gasket and bolts a couple of weeks back, proper expensive aren't they!
Old Dec 24, 2011 | 12:04 PM
  #90
surrey_100e
small update, finished all the interior panels now, had the gearbox rebuilt, it needed new 3rd and 4th syncro, new bearings and input shaft, also got them to fit the hydraulic clutch kit.
Had a heavy duty 3" prop made too. With christmas n the cold weather haven't really had the motivation to work on the car but just brought a loom and ecu so that will give me something to work on.
Old Dec 24, 2011 | 12:28 PM
  #91
The Youth.'s Avatar
The Youth.
Coming on very well m8, nice to see a different engine fitted than the usual ones like mine!
Ste
Old Dec 24, 2011 | 12:48 PM
  #92
LIMITLESS's Avatar
LIMITLESS
Just read this thread from start to finish, awesome build mate
Old Dec 24, 2011 | 01:18 PM
  #93
turnover's Avatar
turnover
i like that looks quality ,keep up the good work
Old Jan 7, 2012 | 03:46 PM
  #94
surrey_100e
so ive started work on the loom, just a few more things left to sort out like fuse box and gauges etc but the engine loom is all complete
have made this mount that goes on the crank pulley to drive the dry sump pump, had to overcome a few obstacles with this as its a nut that goes on the crank not a bolt and the nut couldnt be altered so had to work round that.
Size:  120.7 KBName:  IMG_1424.jpg
also got a mocal 19 row oil cooler, just making some mounts for this at the moment, it will be mounted vertically with the oil entering the top and exiting the bottom
Old Jan 7, 2012 | 03:52 PM
  #95
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
most origional project ive seen in a long time
Fresh idea away from the norm
Old Jan 7, 2012 | 03:54 PM
  #96
RichieST's Avatar
RichieST
Excellent build mate, looking forward to seeing this progress
Old Jan 7, 2012 | 04:12 PM
  #97
Quality project this
Old Jan 7, 2012 | 08:58 PM
  #98
focus 4x4's Avatar
focus 4x4
Thats Talent!!!!
Old Jan 7, 2012 | 09:19 PM
  #99
jay's Avatar
jay
Well done mate that is spot on!!
Old Jan 8, 2012 | 01:41 AM
  #100
Paul_RS's Avatar
Paul_RS
Amazing priject
Old Jan 8, 2012 | 12:07 PM
  #101
gjh's Avatar
gjh
Awsome stuff. If your not working in the engineering or motorsport trade then to be honest your going to waste.
Old Jan 8, 2012 | 12:47 PM
  #102
105Ian's Avatar
105Ian
Fantastic project , and some very well thought out and neat soultions
Old Jan 8, 2012 | 01:31 PM
  #103
Garethw1986's Avatar
Garethw1986
Great build and a lovely looking car,top work
Old Jan 8, 2012 | 04:37 PM
  #104
surrey_100e
cheers for all your comments guys, much appreciated. Hoping to be on the road for summer.... thats the theory anyway.
lol i can only wish mate, i actually work in a office staring at a computer screen all day
Been working on it today, more updates to come
Old Jan 19, 2012 | 09:16 PM
  #105
surrey_100e
this arrived yesterday, custom spec pace bg dry sump pump
Old Jan 23, 2012 | 06:34 PM
  #106
Mk4 Rick's Avatar
Mk4 Rick
Ive pmed you on vpcuk mate
Old Feb 14, 2012 | 09:35 PM
  #107
barrychambers30's Avatar
barrychambers30
What gearboxes can be used for st engine to use on rwd
Old Feb 14, 2012 | 09:47 PM
  #108
surrey_100e
you cant get most to fit if you make an adaptor plate, but the easy solution is a volvo m90 gearbox i believe.
Old Feb 15, 2012 | 10:26 AM
  #109
barrychambers30
Which volvos. Are they in
Old Feb 15, 2012 | 10:36 AM
  #110
B19 JUB's Avatar
B19 JUB
said it before and ill say it again,your fabrication skills are second to none fella.love the updates
Old Feb 15, 2012 | 11:09 AM
  #111
Cant wait to see this finished.
Old Feb 15, 2012 | 11:10 AM
  #112
Carlos-Titx's Avatar
Carlos-Titx
Rear wheel drive ST powered car? Think i just jizzed!
You work to a brilliant standard mate!
Really well done mate, love it!
Old Feb 16, 2012 | 09:57 AM
  #113
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
stunning work fella,
dont suppose the center push cylinder had any serial numbers on it did it ?
Old Feb 16, 2012 | 10:28 AM
  #114
surrey_100e
cheers everyone
Ha, im afraid its been conveniently smoothed off, however i have heard they are from a mondeo v6 but dont hold me to that, i was going to look at making one or two.
Not much progress happening at the moment, no money + cold weather = unproductive times.
Old Feb 16, 2012 | 12:00 PM
  #115
-beefy-'s Avatar
-beefy-
yeah looking on the bay there exact the same as the mondy v6 and the transit style ,
dont suppose you could knock up a copy of the mount ?
ill fire you a pm fella ?
b
Old Feb 19, 2012 | 09:09 AM
  #116
Cossie Sean
any updates mister??
whats the splitty got going on??? mmmmmmmmmmm
very eager Seany
Old Feb 19, 2012 | 09:23 AM
  #117
surrey_100e
very eager Seany
still not really any updates, just playing about with making the dry sump pump mount but i havent got any money until next week so progress has been slow.
As for the splitty, yeah thats dads toy, its got a 2.3 litre engine in the back on twin 50 webber carbs, its pretty balls out and scares him shitless lol.
Old Mar 8, 2012 | 12:35 PM
  #118
CrOwSoN15's Avatar
CrOwSoN15
Ben
Any updates on this mate?
Old Mar 8, 2012 | 01:46 PM
  #119
surrey_100e
Small update, not much as ive been busy sorting my life out.
After what gjh said i decided to have a change of career and have been accepted for a position as a train engineer after passing assesments and interviews, so thanks for the wise words
Anyway for the update, all i have done is knocked together a mount to mount the dry sump pump to the block.
Will be big updates soon as i will be running the oil lines and plumbing it all in. Then just got do air and water hoses and finish the loom and fueling and a few small things.... sounds so simple like that.
Old Mar 13, 2012 | 10:15 PM
  #120
surrey_100e
won this on ebay on friday. It arrived today so spent the evening cleaning it up, paid £120, new they are £350 im all for saving some monies.
