mk indy rr1 new videos
few more bits arrived today! firstly the r1s are really bad for oil starvation and breathing so ive bought a baffle plate, the blocks already been modded internally and will put 2 extra breathers in the cam cover.
one with the airbox on, with it haveing a shallow sump im hopeing that it can be mounted quite low allowing me to keep the airbox / bit of forced induction!
and a new sprocket-prop adapter
cheers guys!!! santas been today (parcel force delivery man) with a little present!
3 way nitron dampers and eibach springs
just got to get some measurements and work out the front rocker ratio then get them re valved at nitron and away we go! bargain of the century!!
It's a bastard being in the North East at times, not a lot is close to me
think I could do with investing in a trailer and tow vehicle.
Croft - 43.8 miles
Oulton Park - 178 miles
Cadwell Park - 181 miles
You lads ever been on track at Blyton Park, it's a canny little track, nicely priced and not too strict on noise etc
http://www.flickr.com/photos/blytonp...re/5786202893/
think I could do with investing in a trailer and tow vehicle.Croft - 43.8 miles
well the engines in, in a fashion! got a fairly good angle on the prop which will bolt streight up with a little machining to the adaptor, manifolds not a million miles off and makeing the rest of the mounts up isnt going to be the end of the world so im a happy chappy! airbox is going to be the biggest issue as i really want to retain the tricy trumpets but going to chop it up and bring the intake from the opposite side piped from the naca duct which shouldnt interupt the airflow if done rite but wel see! time for the professor to make some nice mounts now
lots of pics comeing! to be continued . . . .
well posties been again today! last big spend before christmas thank goodness, so this weekend il mainy be makeing a pukka loom! k6 arrived full of funky features! going to control the variable trupet motor with the vtec output, anyway lots more loom building pics in the next few days hopefully, looks like a sony advert but not intended!!! also the rsst of the flatshifter expert/blip kit is here. unbelievable support and communication from both companys (which maks all the difference) and in constant contact brilliant!!
right managed to squeeze few hours in this afternoon got bits of wiring done and fitted a innovate wideband lambda guage.was going to just get the controller and run it through the dash/ecu but the guage isnt much dearer so thought id just get that. all looks a little messy at the mo but will be much better once tie wrapped up!
heres the blipper for the flatshift kit, simply remove the throttle off cable and fit this in its place, took a bit of messing to get it working smoothly but is all good now!
and a few of the cradle just needs welding up now and painting. spacers used to make it easier to remove as its bound to break it has cosworth parts in it!!!
on with the engine loom tomo!!
not long now!
bit more progress, mocked up a mount for the gear change solonoid, cradles all welded up and wired the ecu, just waiting on some more heatshrink lables and away we go! could be on for a start up next week! getting exited now!
unfortunately chris i need it to run closed loop cos it gives the ecu a wideband output. il send you a link to the guage! think its probably the last thing you need at the mo anyway!
cheers beefy
right had a mess with the throttle bodys and variable intake trumpets. my ecu will only give an out put to operate the motor one way so at rest i needed the trumpets to be fully closed rather than sat off so set about turning a groove onto the link rod to bring the mechanism lower and fitted a longer stronger spring
fully closed at rest now
also with it being a flybywire set up the preload holding the butterflys closed was pretty extreme so stripped them down again and removed the large spring from the middle where the motor would normally go, is much easier now and will take a lot less load of the blipper
right big update time! a load of pics in no real order,
first of all a bit of a pikey touch up paint job while the bits were off for powdercoating!
moved the solonoid for the gearshift down under the cradle out of the way keeping the weight low down
exhaust headers modded and lower primary has been completely remade to go under the brace bar
made a bracket for the clutch slave pinched form my old engine, was originally from a pulsar gtir and was the perfect ratio so decided to stick with it
lambda boss welded in the collector for the wideband
little tip for cooling systems!! needed a reducer so rather than makeing one pre soldered plumbing fittings have little ribs on them already and are perfect for the job so the pipes dont slip off! whole things piped up now (with plumbing fittings and samco)!! and decided to run a thermostat so managed to get this inline one so see how i get on with it as it tool so long for my old engine to get up to temp properly!
few random ones!
spot the plumbing fittings!
ecus, gearchange on the left, flatshift and throttle blip on the right and the engine ecu under them
few random ones!
