(COLEYST200) focus to focos / skyline gear box
#2882
Just spent the last few hours refreshing through this thread nice bud well done bud. Also bud how different/hard would it be too do what you did with the skyline box to a 350z 6speed box (rwd) the ratio's are better than T5 and the boxes are cheaper and seem to be alot stronger than T5 the 350z takes alot more torque than T5?
If you need another 3.9 front diff im pretty sure I have one if you need a spare will check tomorrow and take pics.
#2883
Hi mate thanks for your Kind words on my car . To be onest you might get away with making a adapter plate . And you could use the clutch setup witch is in the 350z gear box as it looks like it could do the job . The big thing I would look at is the length from the front of the box to the gear stick as it looks in a photo of one a long way back but that's a photo .
#2884
#2885
God now your asking the very first one I made my self but I the decided to have a one piece well a slide if one made it was a place in London that did it for me I cannot remember there name off the top of my head. But I think it was about Ł250 / Ł300 . But there are plenty of prop shaft places around
doga-ot (07-01-2018)
#2886
I think it was prop shaft services near Hounslow, I have their number somewhere. 200 - 300 is about right.
There are already adapter plates around for type 9 conversion to rx8 box, maybe one of those could be adapted? For my Porsche 944 to 20v turbo I made the plate out of mdf first but it helped that I knew it could be done as had seen pics online.
#2887
#2892
Nice work Ian, it'll be back in the car soon then?
#2895
Good to see it all back together
H3lsing (28-03-2018)
#2897
Good news, Ian....are you back on track soon?
#2898
We I had a fab track bay at kendrew barracks on Saturday I only span out 2 times
🤣🤣 I'm never spun out before. It was a MOD air bass and we was on the runways . I used just over 60 Lt,s of fuel and killed my first set of slicks they was second hand BTCC tyres and free so not really bothered about them I run them at 26.5 psi when hot
and they did the job spot on
#2899
Nice to see you back out there in anger. Those runways do kill tyres too.
#2900
The good thing that we all liked about this track was that we could push the cars harder than we ever had before because we felt safe as if it went rong there was nothing to hit . And the reson I spun out was I come off the gas . As with my skyline set up when you pin it it will pull you round the corner. My mates Ford Focus witch is rwd with 470bhp
it a quick car that's had a lot of Ł spent on it . But when it come to the fast tight turns I was all over him . Witch to think my car was built on a show string puts a smile on my face
#2902
It is harder to do on a turbo car due to the throttle response but exploring lift off oversteer to tighten the line when the car understeers can be really useful on a track car but as you found doing too much shifts too much weight to the front and off the rears. Great fun exploring on an open track, Bedford autodrome used to encourage it there but they had too many noise complaints from the tyre squeal police.
#2903
Does your diff control have this?
#2904
Iv not really messed with it to much but I do intend to as I have a good mate that has said he will come along tho a trackday with me and set it up to my driving stile as he owns a garage that build race cars for a living and they install then a lot to there cars
#2905
Hi this video was taken at the last track day we did at kendrew barracks the video is Shot from my mates Ford Focus witch is powered by a 2lt zetec motor with 450bhp and running the car in rwd . It starts off with my mate rex in the middle of us in his escort cosworth but with road types on witch he could not hack it for very long and ends up missing a corner . With that the race is on and my mate sheet in his focus starts chasing me witch was a lot of fun . all so the GoPro dose get smashed but keeps filming to the end
https://www.youtube.com/watch?v=ER7rIFSXxgY&feature=share
#2906
Well all went very well at the last trackday apart from the clutch not being 100% and by the end of the day when I put the clutch to the floor it was dragging so I just fort it needed a new master cylinder witch iv fitted today. Then I went under the car to bleed it and that's when today went rong . The bell housing has cracked big time
#2908
100% fixable mate you should no me by now when something brakes I look into it and make it stronger . and as I'm still getting parts together to build a 500Bhp motor in happy as I can still fix this problem and make it stronger so the new motor won't brake it .
As the gearbox has got to come off I'm on the lookout for a light wait flywheel to try and get the motor more snappy out of the tight corners
#2910
Mine has been fine since.
#2912
What is the reason that it has broken? And what is the fix?
I spoke to a company in Kent who said they could take a sand casting of one and produce them without the need for the weld.
Could you weld over the crack and then put some sort of girdle around it and weld over that.? (a bit like putting a whole piece of plaster board over a crack and then skimming with plaster in house terms)
#2916
I was waiting for that.
Iam actually trying to get a courier to pic it up and the other stuff i have in wales as well at the same time.
#2920
Just a small update the gearbox is now back in the car and working and iv had my wheels powder coated and I got fead up of my old trailer so iv bort a Brian james A Max Iv had to do some work on it and sores a wheel rack witch I picked up Friday from Gifford. So I'm all ready for my next trackday witch I booked last night ( 26th august blyton park )
