(COLEYST200) focus to focos / skyline gear box
Old 19-09-2015, 05:46 PM
  #2601
ossie cossie
ossie cossie's Avatar
Excellent news mate, the mondeo clutch centre push is also getting sent to you it should be with you in a couple of days.
Old 20-09-2015, 07:02 PM
  #2602
COLEYST200
COLEYST200's Avatar
It's all so here mate just one center push
Old 20-09-2015, 07:19 PM
  #2603
COLEYST200
COLEYST200's Avatar
Well I'v started putting the supra diff in to my focos and apart from one small problem it's all starting to fit very well
And this is the small problem . When you put a supra diff in using the MK fitting kit you get a spacer witch is about 20mm that fits to the diff and the prop to the spacer well as this car is a one off and I'v had to make every thing fit I had the prop shaft made 35mm longer so the plan is to put a standard prop on the car and make a spacer to fit . So my mate Rex is going to get the steel tomorrow for me . I'm not going to mob the prop at the mo as I would proffer to save the Ł at the mo as I'm going to have a new prop made for the car over the winter
Old 20-09-2015, 11:06 PM
  #2604
ossie cossie
Yes mate just 1 center push, and the 2 GTR bits, PM me your email address and i will email you later.
Old 21-09-2015, 01:16 PM
  #2605
S1MATT
S1MATT's Avatar
Hi Coley, do you mind if i ask where you get your metal from. Thanks
Old 21-09-2015, 01:35 PM
  #2606
M K
M K's Avatar
Hi Ian
Can you confirm if there is any pressure or not in the return line from the attesa pump to the fluid reservoir?
Thanks
Old 21-09-2015, 02:37 PM
  #2607
Caddyshack
Caddyshack's Avatar
Received 1,033 Likes on 945 Posts
Originally Posted by M K
Hi Ian
Thanks
None to speak of, i just used jubilees in case but push fit would pretty much do it.
Old 21-09-2015, 05:01 PM
  #2608
COLEYST200
COLEYST200's Avatar
Hi mate I go to a place in Aston in Birmingham called Edwards metals
Old 21-09-2015, 05:04 PM
  #2609
COLEYST200
COLEYST200's Avatar
Hi Ian
Thanks
Hi mate I would say there is not any pressure as there is only a very small amout of oil that moves up it
Old 21-09-2015, 05:40 PM
  #2610
M K
M K's Avatar
Thanks guys
I didn't think there would be, just wanted to make sure push fit hide would be ok
Old 21-09-2015, 07:27 PM
  #2611
COLEYST200
COLEYST200's Avatar
Only done a very small bit tonight as it's been a long day today at work . Any way my new rear springs turned up today so as it was a nice small job I sorted them
Old 21-09-2015, 08:06 PM
  #2612
Caddyshack
Caddyshack's Avatar
Looking good, what poundage are they?
Old 21-09-2015, 08:38 PM
  #2613
COLEYST200
COLEYST200's Avatar
There 500 and I'v put 600 on the front
Old 22-09-2015, 12:26 AM
  #2614
S1MATT
S1MATT's Avatar
Thanks for that. There only just down the road from me. Cheers
Old 22-09-2015, 04:40 AM
  #2615
COLEYST200
COLEYST200's Avatar
If you do go down there tell them ian cole told you to go there the lad with the cosworths trust me it will help and pay cash and you don't won't a receipt
Old 24-09-2015, 12:45 AM
  #2616
S1MATT
S1MATT's Avatar
lol will do. i only want some box section to make up some dolly's and a bit of sheet, well hopefully, i'll see what i uncover soon Thanks again
Old 26-09-2015, 12:53 AM
  #2617
COLEYST200
COLEYST200's Avatar
Well the clock is now ticking as in the week I book up with my mates to do a track day on the 10th of October and with working away I'm up against it now to get the car running again . So When I got home tonight my mate Rex had been and picked up the last of my powder coating and some metal so I could make a spacer for the prop I'v had to put a stander prop on for the track day as I could not get a spacer in with my prop any way this is wot I got sorted tonight .
I'v got to get some new bolts but it will do for now
Old 02-10-2015, 09:23 PM
  #2618
COLEYST200
COLEYST200's Avatar
Not much of a update but when I'v been home witch is not a lot as I'm back to working away a lot again . I'v been working flat out trying to get the focos back togever well tonight I finished it off and did a road test and thank god it's all ok . But as all the tools were out and I'v got a track day next Satday i fort it was about time I put my new tale gate on witch is a very nice carbon fiber one . It only tuck about a hour to do and I'm very happy with it and the fit but the car dose not look the same with out the rear fin . I really need to put one back on the car but the old one is shot and to be onist I don't won't to put a fiber glass one back on it's so heavy . I'v seen carbon fiber and carbon Kevlar ones on cars just need to find out how sells then if any one nows any info please let me no
Old 05-10-2015, 06:24 PM
  #2619
Tev
Tev's Avatar
looking good ian!!! i really must make a effort n come see the focos at some point
Old 05-10-2015, 08:49 PM
  #2620
COLEYST200
COLEYST200's Avatar
Hi mate I'm at Mallory park this Satday coming pop over and have a look
Old 06-10-2015, 07:30 AM
  #2621
Tev
Tev's Avatar
Ah perfect, I now live 5 mins walk from mallory you are literally on my doorstep!! I will pop down mid day to take a good look round the car
Old 09-10-2015, 10:24 PM
  #2622
M K
M K's Avatar
Hi Ian
Can you tell me what mix match of parts you used for your clutch set up as I'm looking to have a second set up that is more road/driver friendly
I currently have an AP twin plate but have race material ceramettalic and it's not so road friendly
I gues I would need the standard flywheel, AP cover plate and a skyline single clutch plate, but will any plate fit with cosworth AP cover or is it only a spring plate type ?
Old 10-10-2015, 05:57 AM
  #2623
COLEYST200
COLEYST200's Avatar
Hi Ian
Hi mate 100% right if you look back on my post it's all there the car is running a standerd 2wd flywheel ap cover and a skyline paddle clutch plate nuthing fancy and it works the O/D of the skyline clutch is the same as the Cosworth one so it's just pug and play
Old 10-10-2015, 08:13 AM
  #2624
Caddyshack
Caddyshack's Avatar
I have the helix reyland uprated cover, skyline paddle and 4x4 flywheel.
I have a spare AP cover brand new and I think I have a 4x4 flywheel if you want to try it out.
Old 10-10-2015, 08:26 AM
  #2625
ossie cossie
Will a 2wd flywheel fit?
Old 10-10-2015, 09:29 PM
  #2626
Caddyshack
Caddyshack's Avatar
According to coleys post it will.
Old 10-10-2015, 11:18 PM
  #2627
ossie cossie
Cool i have a 2wd engine i am going to use in the track car converting it to 4x4 with oil pump, pickup and sump so it will have a 2wd flywheel.
Old 29-10-2015, 10:12 PM
  #2628
COLEYST200
COLEYST200's Avatar
Just a small update as of tonight I'v sent off for a controler that will run the gear box it's the Map dccd controler it's fully program abull and come with some maps set in it and second lee I'v got a mate here in Birmingham that uses this kit all the time and can set it all up to my car and the way I drive on the track . And all this for the nice price of Ł283 to the door
All so as in still running as standard dash clocks I needed one of these with work my speedo and the gearbox controller
Old 29-10-2015, 11:27 PM
  #2629
markk
markk's Avatar
Like mine in the Escort 😉
Size:  238.9 KBName:  20151026_185930_zpsm3k2hfbu.jpg
Old 29-10-2015, 11:29 PM
  #2630
markk
markk's Avatar
Was a bit more than Ł289 by time you've paid import duty, though the pound is better than the dollar from when i bought mine 2 years ago.
Old 30-10-2015, 02:56 AM
  #2631
ossie cossie
Is this instead of the other type gearbox controller. The ETS pro? whats the difference as i will be looking at getting a gearbox controller soon.
Old 02-11-2015, 08:50 PM
  #2632
Caddyshack
Caddyshack's Avatar
Yes, does A similar job to the ets. It looks like you can map it more yourself.
Old 14-11-2015, 09:01 AM
  #2633
COLEYST200
COLEYST200's Avatar
Yes Toby I'm told you can map it your self so let the fun begin lol any way joking a side I'v got a lad in Birmingham that has worked with this bit of kit for a long time now and has offered to map it to my car and the way I drive .
Very small update the new gearbox controller has landed in the UK so all being well over the next month or so we will get it all wired up and running
Old 14-11-2015, 12:49 PM
  #2634
Caddyshack
Caddyshack's Avatar
If you need to extend any wires I have a massive real of 4 core coloured cable in the right size that I bought to extend the ets wires, I can post you a load if you need any.
Old 14-11-2015, 04:08 PM
  #2635
COLEYST200
COLEYST200's Avatar
Thanks very much Toby I will keep you in mind thanks
Old 23-11-2015, 02:27 PM
  #2636
Willka
Ford KA 1.7 Vct, soon...
Willka's Avatar
Absolutely awesome project mate! Just spent a few days reading through it, you'll end up with a cracking car
Old 23-11-2015, 03:22 PM
  #2637
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Ian,
500lb springs for the rear is way too much IMHO.
Old 23-11-2015, 10:02 PM
  #2638
COLEYST200
COLEYST200's Avatar
Originally Posted by Martin-Hadland
Ian,
With your expertise with these cars mart you are proboly right but with standerd springs on the front and 200 on the rear the car rolled like a boat I the sea . It's got 4x4 rear arb and a bladded front set up on it now . But at the same time the gearbox has not been helping as it's been corsing the car to loos grip in the corners witch in the new year when I get the map dccd working that should be sorted and then we can have a second look at the springs but I must say it felt prity good the last time out at Mallory park . I all so need to look into tyres as that could / is all do letting the car down . In your eyes Martin wot would you put on the car / springs and tyres ?
Old 24-11-2015, 01:06 PM
  #2639
Caddyshack
Caddyshack's Avatar
Worth trying the Dunlop Direzza range or Toyo R888 (Or Michelin Pilot Cup Sport 2) if mainly used on track, just keep an eye on the tyre pressures when they are up to temp as you need to find the optimal hot running level (as with all tyres on track) I would expect them to gain around 5-6 psi or more when hot and remember to pump them back up at the end of the day.
Old 24-11-2015, 01:38 PM
  #2640
MK MOTORSPORT
MK MOTORSPORT's Avatar
HI
softer springs and stiffer roll bars
Quick Reply: (COLEYST200) focus to focos / skyline gear box
