Track saphhire
Old 17-12-2010, 06:53 PM
  #161
Brettski mk2
Brettski mk2's Avatar
Originally Posted by Cosworthfreak
Where can i buy the part between the camshaft?
Thx for help
Hi do you mean the dizzy blank?
Old 17-12-2010, 07:07 PM
  #162
Cosworthfreak
Cosworthfreak's Avatar
yes this part
Old 17-12-2010, 07:11 PM
  #163
Brettski mk2
I got mine with the loom parts but heres a link
http://www.reyland.co.uk/Details.asp?ProductID=135
Old 20-12-2010, 02:19 AM
  #164
LINCOLN
LINCOLN's Avatar
Love this build. Nice work on the looms and you NEED a set of the OZ wheels.
Old 20-12-2010, 06:00 PM
  #165
Brettski mk2
Yes I do ......I want them so bad it hurts
Old 03-01-2011, 07:38 PM
  #166
Brettski mk2
Body wiring loom is finished THANK FOOK just need to tidy up the loom now and rap it in some protective braid.
Started to fit the new engine loom,this is lovely work...all clean and new.
It came with the a standalone uprated fan and fuel pump loom.
Fitted the AP twin plate clutch and flywheel and Tilton center push.Had a job to line up the two plates but got there in the end,I set the release bearing gap up and put the oil pipes on.
I drilled and tapped the block..... engine mounts holes out to M10 shitting my self incase I made a mistake!!!the GRP A engine mounts alloy arms have m10 holes so needed doing!
Hope to fit the engine and gearbox wednesday night I'm so looking forward to that as it will be good to get that in,then its the fuel pipes and rail,regulator
I want a Aeromotive Fuel regulator and bullet alloy fuel rail,with full -6 teflon aero quip lines,044 pump,I got a stand alone fuel pump loom,I'll use some nice bulkhead fittings to keep it all neat and nidy
Pics up wednesday
Old 03-01-2011, 09:20 PM
  #167
Miller 3
Miller 3's Avatar
Nice one
Old 03-01-2011, 09:23 PM
  #168
ital_cossie
ital_cossie's Avatar
wait wednesday to see the pics!!!!!
keep up the good job!
Old 15-01-2011, 04:03 PM
  #169
Brettski mk2
Keep forgetting to take the camera down the farm.Moving on good now engine in!!
Old 17-01-2011, 08:11 AM
  #170
James_RScos
James_RScos's Avatar
Come on Brett, we need pics
Old 17-01-2011, 12:32 PM
  #171
Big_Mike
Big_Mike's Avatar
I second this!!
Old 17-01-2011, 10:11 PM
  #172
4x4pete
4x4pete's Avatar
1st time iv seen this looks good fella
Old 20-01-2011, 04:07 PM
  #173
Brettski mk2
Hi I seem To have done loads or fartting about wiyh not a lot to show for it!
Got the clutch on and the center release bearing set up.
Got the gearbox on the there engine fitted front diff and prop put the engine and box it to the car
the engine mounts where a bugger to fit to the block and do up not a lot of room to get on the bolts
And the bottem of the inlet is close to the body mounting on the near side
Fitted the engine loom and routed the wires neat
And started to think about the intercooler piping and fitting the tial 50mm bov
Looks overkill in there I think but it was bought for my old scool TTE powered 500 hp sleeper celica 4x4 but never fitted
It cracked the block when being mapped @ 2.2 bar boost only covering 600 miles.......wanted to kill my self
Old 21-01-2011, 04:50 PM
  #174
Brettski mk2
Got some more parts today Grp A top mounts and wheel nuts,One of the bearing is shot but order one from a bearing shop at half the price of ATM
Also some rear anti roll bar brackets from Tony @ tcs thanks mate, there very well made
Old 21-01-2011, 04:57 PM
  #175
Brettski mk2
Also got these to pick up sunday Grp A ap 315 and 4 pots with brackets to fit standed rear beam
Old 21-01-2011, 05:11 PM
  #176
andy escos
andy escos's Avatar
getting there brett
would it not of been better to have cut the bottom of the chassis mount out & weld a plate in the top so you could fit the engine with mounts on from underneath .
going to be an awesome car when done
could you tell me the measurements of your chassis mounts ,how long, how high ,how wide please.
Old 21-01-2011, 05:23 PM
  #177
MK MOTORSPORT
MK MOTORSPORT's Avatar
Originally Posted by andy escos
getting there brett
andy if he had done it that way ,if the rubber bush fails or the bolt fell out so would the engine ,the way it is the worse that can happen it drops till the arm hits the bottom mate
Old 21-01-2011, 05:39 PM
  #178
andy escos
andy escos's Avatar
so thats why they made them that way cheers mark
Old 21-01-2011, 06:36 PM
  #179
Brettski mk2
Its a pig to get engine in as you have to lift the engine up from underneath then bolt the alloy arms on to the block with the other end in the chassis mounting then try starting the bolts in the block
Tell what you want measuring from where to where and I'll do it over the weekend Andy
Old 21-01-2011, 07:41 PM
  #180
Touring Car Spares
Touring Car Spares's Avatar
Looking good mate .
cheers for the Bill ,the bloke spent some dosh on them didn't he ,lol
If the wheel nuts you havethere are Alloy ones please dONT use them !!
We have a supply of M14 Steel Nuts ,dont want your wheels dropping off do we
Old 21-01-2011, 08:00 PM
  #181
Brettski mk2
Was looking at them on you site Tony,Are the alloy one not the best then?
Old 23-01-2011, 04:21 PM
  #182
Brettski mk2
Went and got the rear ap 315 Grp a breaks today they have bracket to fit on the standard bearing carryers
Old 23-01-2011, 05:55 PM
  #183
Touring Car Spares
theyre no good really , im sure when Brand new theyre ok but weve seen disasters occur with them , for the sake of just a few quid the Steel ones are worth doing . Drop me your address and i'll send you some over
Old 24-01-2011, 01:21 AM
  #184
Gav Diamond
Gav Diamond's Avatar
Been a while since I last looked in on this build.
Love the work you have done mate, loom work is great as well
Old 26-01-2011, 09:48 PM
  #185
Brettski mk2
Hi all got 3 days off work so am in the shed
I wanted the fit the oil cooler but needed a alloy fitting for the take off plate so went over to the wifes uncle at rally extreme to see if he had one opened the door to the work shop and saw my old mk2 sitting there and f.ck me its changed
SEX ON WHEELS!!
Did a bit on mine after wanking over the mk2
bits back from powder coating
mocked the dash up
Old 26-01-2011, 09:50 PM
  #186
scottyrs
DURHAM RSOC
scottyrs's Avatar
love it , and that mk2 was lush!
Old 29-01-2011, 02:06 PM
  #187
Brettski mk2
Stripped the rear wheel bearing carryers down and cut the caliper lugs off so the new rear brakes fit on,then shot blasted them,primed and painted black
also found some nice mesh off a coach roof mounted aircon uint "it went under a bridge and ripped it off!!" and shaped it to fit the grill and front fogs then used windscreen bound to fix it in place
Old 04-02-2011, 05:34 PM
  #188
Brettski mk2
Powder coated springs back on and just waiting for new front scraper seal to go in the body then all the front end can be fitted
Old 04-02-2011, 07:59 PM
  #189
JonnyBravo
JonnyBravo's Avatar
Whats going on with that Celica ?
  #190
XRT_si
XRT_si's Avatar
Looking good!
How was the Mk2 when you had it then?
Old 04-02-2011, 08:03 PM
  #191
tezmanian devil
tezmanian devil's Avatar
epic mate, keep up the good work, dont swop it for an escort, not after all the graft you'v put into it, get it finished, and give it a dam good spanking round some track's
i want your revolution's, so get the OZ's! lol
Old 04-02-2011, 08:28 PM
  #192
Brettski mk2
Hi had that before the cossie,old sleeper... tryed for 500hp new forged engine,big turbo,motec mapped at fensport but it cracked the block @ 2 bar only 750 miles on new engine so it got broke for parts
Old 04-02-2011, 08:29 PM
  #193
Brettski mk2
Originally Posted by XRT_si
Looking good!
See first post page one
Old 04-02-2011, 08:31 PM
  #194
Brettski mk2
WANT A SET SO BAD
Old 04-02-2011, 08:34 PM
  #195
JonnyBravo
JonnyBravo's Avatar
Was just about to say a mate of mine at Fensport would be interested in it
Oh well ! onwards and upwards
Old 13-02-2011, 10:01 PM
  #196
andy escos
andy escos's Avatar
hi brett sorry its took so long to get back to you
A.is width at inner flitch
B.is from front of bracket ,inner flitch to engine mount hole
C.over all length
D.inner flitch to fold
E.WIDTH OF ENGINE MOUNT
f.back of bracket to bulk head ,o/s +n/s
G.height of bracket
H.flitch to engine mount hole
if it is at all possible it would be very helpful
sorry about the crap art work its my first attempt at it.
Old 14-02-2011, 07:58 AM
  #197
James_RScos
Brill Brett!
Looking good mate, cant be long left till the first test now
Old 17-02-2011, 07:04 PM
  #198
Brettski mk2
Hi all getting on with it now
Fitted fan and fuel pump relays in the hole in the dash,the white bits are allot plates so can be flocked over
And made a carbon cover up to hide them up
Also I have been missing about trying to hide my HT leads on the rocker cover,Well it has taken a full 2 day to get it right!!!
Only because I want to hide the coil in the car! so the leads had to be long to reach the coil on top of the gearbox tunnel 900mm long leads!!!got them made up from ka leads
Don't want the engine bay to cluttered up
Fitted the GRP A top mounts and mocked up a a corner, hope it drops a bit!
front
Old 17-02-2011, 07:18 PM
  #199
Brettski mk2
Andy I'll do it at the weekend for you
I have now payed for a set of tarmac GRP A ap 355mm floating discs and bells with 6 pot calipers and brackets!!!! should get them next week and can't wait
Old 17-02-2011, 07:21 PM
  #200
andy escos
andy escos's Avatar
thanks brett ,i would love to have all your mechanical parts on my escort ,im very jealous .
Quick Reply: Track saphhire
