zetec turbo build
Old 27-09-2009 | 05:58 PM
steve,s RS's Avatar
steve,s RS
16v turbo
Default zetec turbo build
hey everyone i have just started puttin my zetec turbo together and if i use focus rs pistons do i still need to use the decomprssion plate and im also using the rover turbo inlet its already bolted to the head do i need to modify that at all.
Old 27-09-2009 | 06:08 PM
jonny s2's Avatar
jonny s2
if you have the black top zetec and focus rs pistons,there is no need for a de-comp plate unless you want to lower the compression more,you will also need uprated valve springs to run more than 8psi
Old 27-09-2009 | 06:13 PM
steve,s RS's Avatar
steve,s RS
16v turbo
Its the 2.0 silvertop im not after massive power about 180 to 200 hp so should i just stick with the decom plate
Old 27-09-2009 | 06:24 PM
jonny s2's Avatar
jonny s2
if its silver top im sure them focus rs pistons dont fit in silver top as they are black top pistons,yeah de-comp plate would be ok for that power
Old 27-09-2009 | 06:29 PM
steve,s RS's Avatar
steve,s RS
16v turbo
Thanks very much for clearing that up for me its prob just saved me alot of money.
Old 27-09-2009 | 06:34 PM
gramsey's Avatar
gramsey
sorry to hijack the theard but i have a similar question. so the rs pistons fit straight in a 2.0 blacktop? what bhp are these good for? cheers
Old 27-09-2009 | 06:44 PM
jonny s2's Avatar
jonny s2
the focus rs engine is a black top zetec in drag(duratec)on the rocker cover,im sure they good for 350hp ish
Old 27-09-2009 | 07:22 PM
crazycage's Avatar
crazycage
the rods and pistons will fit in a silvertop 2.0l engine fine ,but as far as im aware you cant get new rings for them and the block probably would need a rebore to be 100% so that rules them out imo.
Old 27-09-2009 | 07:29 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Any engine machinist who knows his job will be able to get a set of rings to fit...
I've struggled for piston rings in the past and my machinist has normally sorted me a set in less than 20 minutes...
I wouldn't worry too much!
Old 27-09-2009 | 07:36 PM
crazycage's Avatar
crazycage
there you go then mate .
Old 30-09-2009 | 06:27 PM
steve,s RS's Avatar
steve,s RS
16v turbo
So if i take pistons and rods from a 2.0 zetec blacktop they will be ok to fit into my 2.0 zetec silvertop as i only have a bear block thanks.
robnock
21
13-05-2019 06:29 PM
robnock
22-08-2015 11:51 AM
Chopshop85
17-08-2015 07:38 PM
turbobill
09-08-2015 06:21 PM
turbobill
01-08-2015 09:55 PM
