Mk6 JWRC fiesta cosworth
Old 08-09-2014, 07:44 PM
  #3441
M K
M K's Avatar
Wanted to get a matching kill switch for inside the car, no worry a il buy 1.......... £94 delivered!!!!!!!
Old 09-09-2014, 06:38 PM
  #3442
IanC
IanC's Avatar
£94 for a switch I'd want it to give me a wank too for that kind of money! Wiring is looking sweet thou pal
Old 10-09-2014, 04:03 AM
  #3443
rixstaa
rixstaa's Avatar
Default hey
Been watching this for a while and just decided to join here..
Well done..
Alot of hard work gone into this..
Hope it turns out exactly the way u want as its 5year of your life..
Personnely i dont know how you have stayed motivated..
Very nice youve gave me some ideas
Wish u the best of luck
Old 10-09-2014, 07:35 AM
  #3444
M K
M K's Avatar
Tell me about it mate, nearly fell off me chair
Well done..
Thanks mate
Old 10-09-2014, 07:50 AM
  #3445
RichieST
RichieST's Avatar
Top work as usual mate, really enjoy watching this progress. Might be a bit of a daft / obvious question but will it be driven on the road or just for track?
Old 10-09-2014, 09:40 AM
  #3446
M K
M K's Avatar
It will be road legal purely to make it easier to move about and for the odd drive to a mates/road test but mainly track
Old 13-09-2014, 06:52 PM
  #3447
whizzisat114
whizzisat114's Avatar
Stunning work Marc ☺
Old 13-09-2014, 07:16 PM
  #3448
M K
M K's Avatar
Well got the car back from Simon @ Sileck motorsport wiring
Very nice fella and has done a very nice job of the loom
Hired a transporter for the day as i do not yet have my own and went to collect it
Everything all done and sorted other than 1 small issue of the boost gauge bulb holder not getting power least its nothing major and most like just a lose or unplugged pin in a connector so Simon is going to stop by and sort it next time he is my way
So here is some photo's of the work that has been done
Hidden away neatly are all the mini relays and the main relays for fuel pumps and coils,
All labelled up and tucked away behind the brake fluid under the old airbag cover on the passenger side of dash
The entire loom is made up of type 44 wire and heatshrunk with raychem, even the boot loom for the number plate lights
Extra plugs pre fitted for an intercom system and aux interior light, not yet fitted as havent found 1 i like but both intercom and light plugs are on switches in the main switch box
These are plugs that are ready for wing indicators, as the car is made after a certain year it should by Mot rules have side repeaters but due to the jwrc arches i do not run them, but......just incase it ever causes me mot issues etc then Simon put in the wiring for them but only to a plug so if i ever need them i can just make the other small section of loom from plug to bulb
All blanked off ready if needed
Every bit off loom is new, inc light looms and alternator and starter motor and earths etc
Rear sub loom on a big plug through the boot floor, this allows the fuel pump box to be unplugged and completely removed to work on at the bench without having to undo the wiring to the actual pumps etc
Battery wiring and master kill switch
Also has an anderson plug that is tucked away behind the passenger seat if a boost pack is needed.
Fire extinguisher plug disconnected and clipped to the tank just to be safe whilst it is not needed
Scuttle panel kill switch and fire extinguisher button
Main breaker panel and switch box are on plugs so both can be disconnected easily with no fuss
Steering wheel has buttons for, indicators, flash lights, horn, wash and wipe, and ALS
The bracket is just a hand bent item and is not the finished item, i will be looking to have one machined from billet so it is proper symmetrical etc and looks pukka but we had to make something up for now
Steering wheel buttons are on a curly cord and are on a top spec as connector that i will make a proper mount for but for now it's just tucked by the dash panel
And that is about it really, it looks just as good as i had hoped and still has that proper rally car look and feel to it with everything there for a reason, FUNCTION OVER FORM
The engine does run, for the first time ever in the car
But ive only run it for a short while until i can get the dash can linked to the ecu to check oil and fuel pressure etc
Excited to have it home is an understatement, especially when the car has a new home in the integral garage which is heated and carpeted right next to my kitchen and i can see it every time i walk to the fridge to get a beer which makes me smile MASSIVELY
Thanks
Marc
Old 13-09-2014, 07:42 PM
  #3449
graham c
graham c's Avatar
well come on since last time i looked
Old 13-09-2014, 07:58 PM
  #3450
Gaz 88
Gaz 88's Avatar
That's looks perfect Marc! Like you say everything is done for a reason and a purpose! Will deffo be speaking to Simon when mines ready!
Old 13-09-2014, 08:39 PM
  #3451
Caddyshack
Caddyshack's Avatar
I am not sure that I have ever seen a nicer car...ever! I love the attention to detail, Rod did a similar job on my engine loom.
Love it and can't wait to see it driven in anger.
I drove mine for the first time in 5 months and it was just brilliant to experience although I still have a long way to go before I will be happy with the whole thing.
Old 13-09-2014, 08:59 PM
  #3452
jonfoc
jonfoc's Avatar
That's amazing Marc. Who did your pas lines? I'm using the same pump
Old 13-09-2014, 09:10 PM
  #3453
xan_lee
xan_lee's Avatar
Massive respect for all the attention to detail. Nothing to envy to a top spec team car. Also I use your build as a guide for lots of things for my own track car build!
Old 14-09-2014, 05:05 AM
  #3454
c20tbo
c20tbo's Avatar
Mark can you not get a rubber square gear gater, cut it down and should pup under the tunnel nicely, car look mega top job on the wiring, deep down i wish my car had been finished but i have not regretted breaking it, bank manager also agrees with the decision
Good luck with the car i hope it exceeds your expectations, just needs some top diffs and gearbox and it will be right up there.
Old 14-09-2014, 08:27 AM
  #3455
M K
M K's Avatar
It's taking a while but there is light at the end of the tunnel now
Very nice knowledgeable guy, can recommend him highly
Thanks mate, appreciate the nice comments you and others have made, i look forward to the first drive around a track
I made the lines up myself mate, using proper Aeroquip power steering hose and steel fittings, which are the only ones you should use due to the extreme pressures in the power steering system
Same here mate, i have used various car builds i have seen on the net to influence my own build and there is still things id like to redo
Good spot Rob, that gaitor was a trial fit a while back but was no good but i have forgotten to take it off lol i will be fitting something else but have not yet found one i like so the search continues,
I can imagine how you feel having not finished yours and obviously you had your reasons but i would never be willing to let someone else have the pleasure of finishing the car if i gave up after all the blood sweat and tears i have put into it, it's 5 years of my life, every penny and every spare moment committed to it even when i had had enough of things but as said before i can see the light now and the big expense is done,
Proper RnD front diff and RnD dog box will be the icing on the cake but that will be in the years to come as id expect that to be about 8k i spose which will not be available anytime soon lol
Thanks for all the nice comments
Glad you like it
Thanks
Marc
Old 14-09-2014, 08:30 AM
  #3456
fezzajsy
fezzajsy's Avatar
Very very nice
Old 14-09-2014, 08:39 AM
  #3457
Fudgey
Baby Cheesus
Fudgey's Avatar
So much awesomeness right there!
Old 14-09-2014, 10:01 AM
  #3458
Carlos-Titx
Carlos-Titx's Avatar
How high of a standard is that !
That's Amazing.
Old 14-09-2014, 11:09 AM
  #3459
Received 1,044 Likes on 998 Posts
It looks stunning on the back of the truck. The wiring looks top notch. Werent you gonna break rhis car a few months back.
Old 14-09-2014, 03:32 PM
  #3460
105Ian
105Ian's Avatar
Absolutely stunning build and the attention to detail really shines through , the wiring loom like the rest of the build is top quality
Old 14-09-2014, 03:51 PM
  #3461
M K
M K's Avatar
Thanks guys
Glenn - no mate I've never even considered breaking this car
Old 14-09-2014, 06:39 PM
  #3462
stu21t
stu21t's Avatar
I'm looking forward to seeing this in the flesh.
I would love mine to have a proper rewire like this. I did mine all myself and although I'm proud that everything works, I can't help but think it would be so much better done by a pro lol.
Old 14-09-2014, 08:46 PM
  #3463
M K
M K's Avatar
Stu - fair play if you can do yourself mate, but wiring is not something I like to get involved with, I'd say 60% of all Cossie problems are wiring related if not more lol plus shitty electrics can cause fires and very hard to trace intermittent problems so I did not want to risk it and got Simon on the case
Old 14-09-2014, 09:31 PM
  #3464
M K
M K's Avatar
Excuse the dodgy sound as my phones a bit old and battered but here is the first running of the car!!!!! (Ok the second but didn't have phone recording 1st time lol)
Just a quick run to show how nice it fires straight up on the button literally
Old 14-09-2014, 09:44 PM
  #3465
stu21t
stu21t's Avatar
Congrats mate.
Such a wicked feeling.
Let's hope I did ok lol. Did the entire car, fuse/relay box, engine loom... The lot.
Old 14-09-2014, 09:52 PM
  #3466
M K
M K's Avatar
I'm sure yours will be fine Stu
Also made a new bumper mount today
Old 15-09-2014, 09:03 AM
  #3467
CraigoScott
CraigoScott's Avatar
fantastic as usual, well done
Old 15-09-2014, 03:26 PM
  #3468
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Running out of excuses now
Old 15-09-2014, 04:15 PM
  #3469
M K
M K's Avatar
I know
Got Tommy Field popping round 1 evening hopefully this week to switch on all the can setting and fan and fuel pump settings on the Ecu for me so I can run it up properly to bleed coolant system etc as currently everything in Ecu is turned off as it's new and was not needed on the dyno
Then I will concentrate on sorting the clutch issue out then when that is sorted it can go for corner weighting and Geometry set up with Tom Field senior
So that's the plan for next few weeks
Old 15-09-2014, 05:20 PM
  #3470
DavebST170
DavebST170's Avatar
i love this car. looks awesome!!
Old 15-09-2014, 05:39 PM
  #3471
siscossie
3-door moonstone
siscossie's Avatar
Amazing mate credit to you truly awesome
Old 15-09-2014, 06:01 PM
  #3472
frsjon
frsjon's Avatar
just wow marc! just like the rest of the car the wiring looks awesome ..bit jealous of the garage,almost as good as having the car in the house lol
Old 15-09-2014, 06:02 PM
  #3473
Billy_RS
Billy_RS's Avatar
This is amazing!
Fair play mate
Old 15-09-2014, 07:58 PM
  #3474
Miller 3
Miller 3's Avatar
Well done Marc buddy :0)
Old 15-09-2014, 08:30 PM
  #3475
M K
M K's Avatar
Thanks people
Jon - It's as good as in the house
Old 15-09-2014, 08:42 PM
  #3476
scarnny
scarnny's Avatar
Good work, engine sounds sweet, looking forward to some more vids.
Old 15-09-2014, 09:19 PM
  #3477
Fullflush
Fullflush's Avatar
One of the best fords I've ever seen!!
Old 16-09-2014, 08:26 AM
  #3478
haz87
haz87's Avatar
Fantastic job
Old 16-09-2014, 03:33 PM
  #3479
markk
markk's Avatar
Originally Posted by M K
Thanks people
As long as you don't start running any high octane, carless smells awesome, just not sure I would want it in the house lol
Old 16-09-2014, 04:19 PM
  #3480
M K
M K's Avatar
Lol
I love that fruity race fuel smell but I agree not so much in the house
Quick Reply: Mk6 JWRC fiesta cosworth
