Mk6 JWRC fiesta cosworth
Old 09-03-2012, 07:24 PM
  #2201
M K
M K's Avatar
Also quickly dropped this in tonight ready to dummy build/measure a few things
Old 09-03-2012, 07:42 PM
  #2202
Minirotty
Lucifer II - 666
Minirotty's Avatar
An engine in!!! I know not a working one but still looks
Old 09-03-2012, 08:05 PM
  #2203
fezzajsy
fezzajsy's Avatar
Old 09-03-2012, 08:35 PM
  #2204
bad boy rs
bad boy rs's Avatar
Top job
Old 09-03-2012, 11:38 PM
  #2205
stu21t
stu21t's Avatar
Why does that look so cool?
Old 10-03-2012, 05:19 AM
  #2206
rs turbo j
virgin
rs turbo j's Avatar
Love the way u say I just dropet it in mate looks perfect has it got the gear box on it as well or is that just the engine sitting pritty mate
Old 10-03-2012, 07:38 AM
  #2207
M K
M K's Avatar
It is nice too see an engine in there, just a shame it isn't fully built up ready to stay in there,
The reason being is that if i give it to Tommy @ Fms to finish i will have no money to do anything else for 3 or 4 months, but if i dummy fit what i have now and buy the turbo as the next main thing then i can make hoses/oil/fuel lines and the exhaust system and work out a few little niggles, like there being no room for the wrc cam pick up sensor, so will have to find an alternative like Coley i think did on his focos.
I did literally drop it in as i had to lift it into place by hand on my own
Built up the sump/block/arms etc the lifted into bay over the cradle onto the mounts
The gearbox is not in place at the moment but i may put the old dummy box back in later today
A few more pics
Lifted the block and sump in
Then put the manifolds on
Soon as the exhaust manifold was fitted i thought there was no way the external wastegate was going to fit but luckily it is ok, and will have enough clearance, maybe more if i find once the turbo is fitted i can mill down the manifold spacer if possible
Not a great deal of room but enough
Another front view
And back of block
Gonna spend some more time on it today and work out where il put the remote filter head and hopefully get front and rear props painted
Old 10-03-2012, 07:45 AM
  #2208
Jay,
Sponsor
Jay,'s Avatar
Dude this car is a ocd work of art !! just gets better
Old 10-03-2012, 08:20 AM
  #2209
ozmk1cos
ozmk1cos's Avatar
I must say it is a special build
Old 10-03-2012, 08:30 AM
  #2210
M K
M K's Avatar
It's not OCD lol i just want to do things right first time round if i can
Ozmk1cos - cheers mate
Got some of the rear end fittings through today, but they were out of -6 teflon hose so have 12m of that coming tuesday or wednesday
Can make up the -10 fuel lines though today from tank to pumps
Old 10-03-2012, 08:33 AM
  #2211
Sticky.
Sticky.'s Avatar
Oh i bet you was nervous putting that engine in incase you chipped the paint.
Everything about the car is stunning Marc & it's a credit to you.
Old 10-03-2012, 08:51 AM
  #2212
Miller 3
Miller 3's Avatar
Looking real good Marc
Iv been thinking of chopping my slam panal an making it removeable but i may just leave that as a job for the future
Old 10-03-2012, 11:33 AM
  #2213
Gadget
Spanner monkey
Gadget's Avatar
Uber cool, just looks so factory finished.
Old 10-03-2012, 02:28 PM
  #2214
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
Originally Posted by M K
The cooler is only small and won't be in direct air flow but I may channel it through the rear bumper with a duct but as the rs500 touring cars ran there's inside the boot I don't think the duct will be needed,
are you flat flooring it??
if not there should be plenty of turbulent airflow under the boot floor to be good enough for that cooling.
If you go flat floor its relatively simple to have a naca duct to feed the cooler (and you might as well as youre doing it) then exhaust out the bumper like you said.
I presume with all that exhaust pipework in the engine bay you will be spending a fair bit of effort on heat management???
Old 10-03-2012, 02:33 PM
  #2215
Psycho Warren
Carbon Crazy
I think if he didnt realise you meant well, he could be offended at calling it "factory finished". It is soo much better than anything OEM.
Old 10-03-2012, 04:57 PM
  #2216
M K
M K's Avatar
Thanks Paul, yeah i was careful but chips and scratches happen and it has a few already, i just don't upload the photo's of them
Makes things a lot easier mate so get it done
Cheers Gary
At a later date maybe a flat floor but not to start so should be ok,
As for heat proof etc yes, i will most likely use the adhesive backed thermo-tec stuff and cover the turbo side wing and exhaust side of transmission tunnel and a bit of bonnet underside
Thanks Warren
Old 10-03-2012, 05:04 PM
  #2217
M K
M K's Avatar
After getting my cam cover back from my mate i soon realised that with the engine in place as it was it is actually IMPOSSIBLE to get the bloody thing on as there is no room! This is fine if you want to have the hassle of dropping the engine 35mm every time you need to remove the cover or if you never want to remove the cover while the engine is in the car, but sometimes it may be necessary so i can't leave it like this
So i had to lower the engine down on the cradle enough to get the cover on, probably dropped about 35mm before it would go on, maybe Andrew missed this or just didn't think lower the engine is a real issue, im not sure
This is how tight it is with cover on and engine in the proper position, not a chance of using the normal wrc cam position sensor set up
So things had to get serious
Old 10-03-2012, 05:15 PM
  #2218
andrewg
andrewg's Avatar
the reason we left the engine high was so the car could be low without drive shaft angle issues
its easy to space it down a bit but impossible to lift it,
Old 10-03-2012, 05:16 PM
  #2219
andrewg
andrewg's Avatar
the sensor in the focus fitted in still as it was at the raised part of the windscreen panel
Old 10-03-2012, 05:21 PM
  #2220
andrewg
andrewg's Avatar
Old 10-03-2012, 05:40 PM
  #2221
M K
M K's Avatar
The underside of the fiesta panel is flat to the back so i will have to use a 90 degree sensor so that is easily solved
Yeah makes sense, i thought i remembered you mentioning the angles during the build so knew there would be a reason,
I have cut a section of the bulkhead underside so the cover fits easily now and the engine will not need to be lowered so shaft angles are kept good
Old 10-03-2012, 05:45 PM
  #2222
M K
M K's Avatar
Sliced the panel and cut a small section out then folded it back up together and for now have bonded it together with tiger seal, i will tack weld it in place and fill in the gaps at the side and paint over to tidy up later when engine is back out
Old 10-03-2012, 05:57 PM
  #2223
M K
M K's Avatar
I may even cut it all out along this line and cover the cut edge with panel edging trim, that way i will have lots of room and no welding or bonding needed
Old 10-03-2012, 06:22 PM
  #2224
JonnyBravo
JonnyBravo's Avatar
Got to be honest Marc this is probably one of the nicest builds I've seen in years, lots of fantastic work going into it
Old 10-03-2012, 06:37 PM
  #2225
whizzisat114
whizzisat114's Avatar
Mark did you see my post on coleys thread?
You'll need a ford galaxy cam sensor with the low 90on degree bend.
Stunning build
Old 10-03-2012, 07:47 PM
  #2226
COCHYN
COCHYN's Avatar
Mint as always
Old 10-03-2012, 09:23 PM
  #2227
RickDraper
RickDraper's Avatar
Mark is one of the issues not because the engine has no box fitted? In this photo it seems to run a fair bit lower:
Old 10-03-2012, 09:25 PM
  #2228
whizzisat114
Now you've posted that pic up it does look back end high without the box on in the earlier pics
Old 10-03-2012, 09:29 PM
  #2229
M K
M K's Avatar
Well spotted
I didn't even think of that
I line the engine up so it was level and obviously the box tilts it back alot more,
Well with any luck the wrc cam sensor will be ok now I have cut the extra piece off which means I won't have to buy or fit another set up as even tho it sits alot lower with the box I don't think there would of been enough room
Problem solved
Thanks for pointing that out
Old 10-03-2012, 09:31 PM
  #2230
RickDraper
RickDraper's Avatar
Well spotted
I didn't even think of that ]
No problem you can send me a cheque in the post
Old 10-03-2012, 09:34 PM
  #2231
M K
M K's Avatar
Will have to be an I.O.U with the cost of this thing
Old 10-03-2012, 10:01 PM
  #2232
youngben
youngben's Avatar
awesome as allways! cant wait to see this get used!!
with it being tilted back as much as it looks in andrews picture you may need to rethink your external wastegate after all as it looks close!
Old 10-03-2012, 11:24 PM
  #2233
Psycho Warren
Carbon Crazy
stick your spare box on to check alignments just in case
Old 11-03-2012, 12:00 AM
  #2234
polly_x
polly_x's Avatar
Mark, why don't you just use the dizzy phase trigger? You don't have to fit the cam sensor in the cover?
Old 11-03-2012, 12:17 AM
  #2235
Psycho Warren
Carbon Crazy
id imagine hes going coilpack and wants to ditch the whole dizzy crap.
Old 11-03-2012, 06:04 AM
  #2236
M K
M K's Avatar
Yeah box will go on next time I'm in the garage to see exactly where we are,
Think the wastegate should be ok but it will be close,
STU - I wanted to avoid using the ST dizzy phase sensor set up as its big and chunky
Will update again when box gets put on
Old 11-03-2012, 08:48 AM
  #2237
Gadget
Spanner monkey
Gadget's Avatar
Mark, If you are tight for room on the rear end of the cover, Why not run a trigger off the cam pully as we do when doing a cossie management conversion on the cvh's? Only requires the disc behind the pully and a small bracket off of the cam cover, A fair bit cheaper too?
Gadge.
Old 11-03-2012, 08:53 AM
  #2238
Gadget
Spanner monkey
Gadget's Avatar
I think he knows it was a compliment but maybe i should have said WRC factory finished!!
Old 18-03-2012, 01:22 AM
  #2239
M K
M K's Avatar
on the cossie head Gary there is no room for a disc behind the pulley as the cams run literally a couple of mm away from the head,
Someone sent me a pm with another option of a small wrc type sensor that goes where the dizzy used to but is a lot smaller than the ST set up, i think i will go on ebay and order a galaxy sensor and see how that is as it may just fit
The normal wrc 1 is not going to fit, even if i cut out the entire skin underneath the plug will be tight i think
Old 18-03-2012, 02:17 AM
  #2240
M K
M K's Avatar
Anyway, i got the box and old diff casing bolted up so the engine is exactly where it wants to be
Now that the dummy box is on and the engine is in its correct position, there is a few issues i need to sort,
The external wastegate now touches the engine bay cross bars of the cage, no major issue, i will just cut off the wastegate pipe, shorten it a tiny amount then re angle so it fits and clears then weld it back on,
Here is how it is now
I then fitted the cams to the head so i could bolt up the quaife peg drive verniers to see the clearance and they are hitting the bonnet reinforcing skin,
I will see how much clearance it creates by cutting away the reinforcing skin around the pulley area as i do not want to lower the engine if i don't have to, but i will have to if needs be but it's not the end of the world.
Quick Reply: Mk6 JWRC fiesta cosworth
