Mk6 JWRC fiesta cosworth
Old 23-02-2011, 09:52 PM
  #1081
COCHYN
COCHYN's Avatar
Originally Posted by M K
I don't know mate as i may step up a size on the turbo and go for 500-550bhp so the transmission is likely to last 5 seconds
wow......reassuring
Old 01-03-2011, 11:06 PM
  #1082
ian w
Car mad
ian w's Avatar
Looking awesome now mate, great work..
Old 03-03-2011, 02:13 PM
  #1083
M K
M K's Avatar
Well thought i would give you a bit of an update as although things are happening there's not much to show for it lately so a parts update is probably the best thing,
so......
BIG BIG THANKS TO MARK @ MK MOTORSPORT
He has sorted me out with a full array of his awesome billet parts for my engine build, including 36-1 crank pulley, water pump pulley, aux pulley, small crank tooth pulley, alternator bracket and drop bracket, standard cps bracket and a ss crank pulley bolt,
He also sorted me out with one of his billet air injector brackets with cam cover posts to mount it on. I had the air injectors sent off and checked then rubbed them down and re painted them as they were a bit battered, in the pic is the old air injector mounting bodies but i have new ones on the way so it will all be nice and new
There's a few more parts waiting to come from MK MOTORSPORT but these haven't landed yet but hopefully soon so will put pics up when they do, i am waiting on a billet alternator pulley, ss aux bolt, some new air injector bodies and a billet wrc crank sensor bracket
He also made up some custom high tensile bolts to suit my custom wrc style tca pins the AG made me, he done them to my dimensions incorporating a washer/step and finished them in the same style as his ss cam pulley bolts and they came out perfect but don't have any pics to hand at the moment.
So big thanks to Mark for some great parts at fantastic prices, if you need any billet parts or one off custom parts then i recommend you give him a shout
Old 03-03-2011, 02:23 PM
  #1084
M K
M K's Avatar
As for the rest of the build its still going slowly and i have spent a few quid on new tools etc lately to help me along the way and i was fed up of spending 10 times as long doing things as i should because i didnt have the correct tools,
So i went out and bough a 6 ton hydraulic press, now i know its an ebay import cheap job but hang on because i thought the same! but after someone said they weren't that bad i thought i would give one a try as compared to the Ł200 + at machine mart for a 10 ton item this one was Ł61.40 as i collected it from the firm 2 minutes from my house (its Ł71.40 delivered) and it works perfectly, ideal for the diy/home mechanic and it done the jobs i had struggled with (and even caused damaged to parts while trying other methods of removal ) easily and took minutes so here is a link to the item
http://cgi.ebay.co.uk/6-Ton-Industri...item1c180af9c7
GET ONE
Also on my list of things i shouldnt be without was a work bench, a bench grinder, decent vice and last but not least a press drill all these items are invaluable imo and now i have them i cant see how i did without them,
you can just make out the press beside the bench
I am now properly tooled up
Old 03-03-2011, 02:46 PM
  #1085
M K
M K's Avatar
Back to the parts i have been buying non stop lol
Got a load of the sensors and accessories needed for the engine build as you forget these parts but they all add up to a fair few quid, i still have to order my bosch 5 bar map sensor and billet housing and oil pump but im getting there,
Also in that picture is the mocal remote filter fittings, although the return for the oil will be going back to the block ala wrc/grpa engines so one port on the take off will be blanked off,
Got hold of another aeromotive fuel pressure reg, some people dont like these but i have used them before and for me they worked perfectly
Got a friend Karl to weld me some aeroquip to my thermostat housing, i already had one with this done but the water pump pipe was quite corroded so i sourced a decent one and had new fittings welded on,
Karl also made me up a 4x4 sump baffle, using the original ford pressed baffle plate, he sells these for Ł85 which is a hell of alot cheaper than anywhere else, and they can come with or without the weights on the gates,
If you want his contact details then just send me a pm, he is working on the proper wrc 2 piece 4x4 gated sump baffle as well but its not done yet and will be a lot more expensive but will keep you posted,
I got all the fittings need to suit my double pump and filter set up and also the tial external gate and fuel rail, i can now say my aeroquip fettish is well and truly back
That is just a few of the threaded adapter fittings believe me
Also underway is the refurb of a few parts, first of is the grp a bladed roll bars, so new bushes and mounts sorted and the blades cleaned up ready for plating
Chris latham is going to be powder coating the roll bars for me along with all the wrc rear link bars and tca/comp struts to start with then slowly as needed he will be doing hubs and flanges etc,
And lastly i think on the engine front, next week my sump should be ready from FMS after having some more fittings welded on and the big wing section oil holes drilled into one large channel, and i should have back my shot peened rods and fully worked crank to show you along with a wrc breather i picked up
And i almost forgot, FMS has supplied me an 8 injector version T6 ecu ready for the engine build too
And they have 7 more available as of last week, three 8 inj versions and four 4 inj versions too, at Ł1000 each roughly so get in touch if you need one,
God this is an expensive hobby
More soon folks
Marc
Old 03-03-2011, 02:57 PM
  #1086
COCHYN
COCHYN's Avatar
About time you updated this pal Cracking stuff! The sump baffle looks quality!
Old 03-03-2011, 04:17 PM
  #1087
andy escos
andy escos's Avatar
bloody hel marc you have been busy flexing your wallet ,some very nice bits you have there
Old 03-03-2011, 04:24 PM
  #1088
whizzisat114
whizzisat114's Avatar
Great update will be a cracking build once it starts going together
Old 03-03-2011, 05:59 PM
  #1089
M K
M K's Avatar
Cheers guys,
The plan now is to leave the car itself alone and purely buy and get ready everything for it so that when it comes to going together I will have 99% of the parts sitting new or rebuilt ready to bolt on, the only downside is it's a shed load of cash that's needed lol
Old 03-03-2011, 06:39 PM
  #1090
fezzajsy
fezzajsy's Avatar
very nice
Old 03-03-2011, 06:53 PM
  #1091
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
well done mark , this is going to be a very nice well built car
cheers paul
Old 04-03-2011, 03:57 PM
  #1092
COLEYST200
COLEYST200's Avatar
Nice to see all the parts coming togever now mate
Old 04-03-2011, 08:00 PM
  #1093
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
what size weld on fittings are they on the stat housing mk ?
beef
Old 04-03-2011, 09:46 PM
  #1094
M K
M K's Avatar
-8 and -4 beef
Old 04-03-2011, 09:57 PM
  #1095
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Mmmmmm billet
Old 04-03-2011, 10:38 PM
  #1096
-beefy-
-beefy-'s Avatar
hummmm weld on fittings lol
Old 05-03-2011, 02:01 PM
  #1097
M K
M K's Avatar
i dont like hoses and jubilee clips so where possible i like to change them
Old 05-03-2011, 06:24 PM
  #1098
c20tbo
c20tbo's Avatar
Like the idea of that marc.
Must admit im in the same boat as you fella, im getting there now though, waiting for a big list of parts from MK Motorsport.
It is a very expensive hobby
Old 07-03-2011, 08:33 AM
  #1099
M K
M K's Avatar
How is Andrew getting on with the shell Rob?
Old 07-03-2011, 11:11 AM
  #1100
Hoogi
Hoogi's Avatar
Just spotted the fitting from your 4x4 Thermostat Housing........
Am I right in thinking the -8 Fitting would go to your Water Temp at the back right hand side of the Head ? Maybe via the Car Heater Matrix ????
And the -4 Fitting is for the Turbo Water Feed ????
If that's the case does that mean the Outlet from the Water Pump (the on that points at 7-8 o'clock) goes back to the Header Tank ????
Been struggling to get my head round this for about a Month !
Many thanks..........Car looks superb by the way.
Old 07-03-2011, 03:52 PM
  #1101
M K
M K's Avatar
to be honest mate i dont know as i never had a yb before and this one is still in bits lol but yes the -8 is a heater hose which i am not using so will be capped off and the -4 is turbo water hose,
Old 07-03-2011, 04:07 PM
  #1102
M K
M K's Avatar
Made myself some new anti roll bar drop links as the old ones were very worn and battered, you can see how battered they were in this pic below,
and although you cant tell from a pic the rose joints were well worn so i wanted new ones, i know you can get normal tube already threaded left and right but i much prefer the hex than round bar with flats,
i bought a length of alloy 5/8th hex bar and cut it into the correct lengths, here is a pic of the off cut to show how it started
then i had it turned on a lathe to leave just the spanner sections top and bottom for easy adjusting, and a 8.5mm hole drilled through it ready for tapping,
Got myself a left and right handed m10x1.5 tap off ebay and tapped a lh & rh into each piece and fitted with the high performance rose joints i got from McGill motorsport and walaa you have yourself 4 new rose joints for a fraction of the price you can buy them anywhere else, and i could of saved alot more money if i had my own lathe so may pick one up next month,
That's another thing sorted and tucked away to one side for the build up
Old 07-03-2011, 05:25 PM
  #1103
whizzisat114
Nice when you do something like this instead of just buying it ay?
Old 07-03-2011, 05:41 PM
  #1104
JonnyBravo
JonnyBravo's Avatar
Nice work there Marc, can see the Aeroquip bill becoming rather large on this build
Old 07-03-2011, 08:03 PM
  #1105
Hoogi
Hoogi's Avatar
Same here, first YB..........I'm sure we'll get there
Old 07-03-2011, 08:15 PM
  #1106
Brettski mk2
Brettski mk2's Avatar
Hi will it be ok to blank off the heater pipes on the head and Thermostat housing?
I am not having a heater and was going to link the two up but if you could just blank them it would be neater
Old 07-03-2011, 08:24 PM
  #1107
markk
markk's Avatar
"if i had my own lathe so may pick one up next month,"
everyone should have a lathe !!
one pair of brake bells in progress
from this
after a small tickle
might get to do them by the weekend.
having the machinery saves loads of time, not only money. the result might not be as 'pro' or as shiney, or look as 'bling' but if it does the job, and the bonus being if you made it yourself, you then become less of a 'cheque book racer' - its all part of the enjoyment to me.
good on you for the effort to produce
Old 07-03-2011, 08:32 PM
  #1108
c20tbo
c20tbo's Avatar
Not sure as of yet Marc, not had any updates or anything so will contact him once home, i need to drop all the stuff off from Mk anyway as he will need those parts.
Im in no hurry i suppose, just really the box to buy parts wise and seats ect, then it can be built back up, see how it goes.
Old 07-03-2011, 08:35 PM
  #1109
andy escos
andy escos's Avatar
billet drop links look good your not the only one who would like there own lathe
Old 08-03-2011, 01:55 PM
  #1110
M K
M K's Avatar
Top stuff Markk thats a decent sized lathe then to be turning that,
got a few bits through the post this morning for the build,
Bosch 5 bar map sensor and sub loom
Some may say its overkill and there probably right as i may never need a 5bar compared to a 3bar but for the extra Ł20 in price and the fact it would have to be re mapped if i changed at a later date i thought why not fit i one now as its only Ł20 and i will be machining my own billet manifold for it
Also i bought these Pro Alloy twin spal fans and laser cut plate for my cossie Pro Alloy rad of off Fudgey Who is breaking his written off 3 door, i will be giving the plate a rub down and having it black along with the cooler and rad so will freshen it up a bit,
Lots more to come but still waiting on a lot of parts as everyone seems to be manic busy and behind schedule lol
Old 09-03-2011, 03:27 PM
  #1111
andy888
andy888's Avatar
will the alloy drop link threads be strong enough mate?
Old 09-03-2011, 03:35 PM
  #1112
M K
M K's Avatar
Yes mate, the original ford motorsport 909 droplinks were made from the same alloy hex bar, and so are the ones supplied by Dewitts and TCS i believe.
Old 09-03-2011, 06:03 PM
  #1113
Touring Car Spares
Touring Car Spares's Avatar
True , and very cheap too !
Old 11-03-2011, 04:37 PM
  #1114
M K
M K's Avatar
Stripped down the front shafts again as they will be going off for powder coating along with the lobro housings, all bearing parts degreased and now been left in oil to keep them from going rusty,
Also stripped down the front hubs and flanges so they too can be sent away and powder coated, managed to get the new bearings out completely intact as well which was a result
That's about it this week
Old 11-03-2011, 04:51 PM
  #1115
COLEYST200
COLEYST200's Avatar
keep it up mate good progress and iv got a lathe only a small one but it dose me i payed Ł350 for it as the chat was moving house
Old 11-03-2011, 05:57 PM
  #1116
Received 1,044 Likes on 998 Posts
Wow some nice looking parts there.
Old 15-03-2011, 04:36 PM
  #1117
M K
M K's Avatar
Went to kill a few hours in the garage today so i striped down the rear grp a uprights to clean them up but i am not really sure what to do with them???
May try and sell them again and see what they fetch and get new ones but have to see if they have interest i spose
stripped down
Then next on the agenda was to strip down all the suspension, so out with the rags and give it all a clean etc as i go as i hate working with greasy oily parts lol, all laid out on the bench so i can work out what i want to replace and what im am going to paint/plate etc
I have absolutely no idea what rate the springs are and cant find any info on them so i think to be safe i will work out a good starting point/poundage for my cars rough weight and use and buy news ones before they go back on the car,
I made a note of the numbers on the billy inserts though as i want to know what there from and a quick check in the grpa/wrc manuals tells me the they are tarmac based,
FRONTS
part number 9095642 - tarmac strut body
9095863 - 550/200 insert
REARS
part number 9096010 - 450/120 insert
Does anybody know if these inserts are good for what i want in a track car? obviously the fact they were for a tarmac set up is a good start,
What poundage springs should i run with them?
Also if i want to get the cases zinc plated etc to tidy them up can i just unbolt the bottom 17mm nut and pull the insert out the case or is it not that simple???
Also can these be re filled or overhauled by anyone still as one front one is very slow to return compared to the other!
Any info on that little lot would be appreciated
Got my billet block through the post today so at some point i will machine up the manifold for the 5 bar map sensor
And got my MK MOTORSPORT Aux pulley stainless 1 piece bolt through
Old 15-03-2011, 06:32 PM
  #1118
Progressing nicely marc
Old 15-03-2011, 11:00 PM
  #1119
markk
markk's Avatar
inserts will unscrew once you have the nut off, do not lose it, they are metric fine thread.
I would beware of the valving on them struts dependant on your cars weight, and if your car is as light as it should be, no settings from escort/sierra will have any relevance.
Old 15-03-2011, 11:16 PM
  #1120
M K
M K's Avatar
Do the insert unscrew the normal way rh thread?
Also can I get new seals anywhere for the casings?
What do I need to be aware of with the valving mate?
Quick Reply: Mk6 JWRC fiesta cosworth
