Mk6 JWRC fiesta cosworth
#683
after all Andrew, scott and the ag motorsports guys hard work i finally have a date set to collect the car ![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
me and gus will be heading up there on sat 14th august to get it![Top](https://passionford.com/forum/images/smilies/smile011.gif)
big big thanks to gus for all the trailering he has done for me in the past, and the future![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
also big thanks to ronnie amis for the loan of the trailer to take it there and back,![Top](https://passionford.com/forum/images/smilies/smile011.gif)
thanks guys.
roll on the 14th
thanks guys.
roll on the 14th
#684
Me too mate,
Also asked Andrew today to put the car as it stands now 80% built on the corner weights to get a rough idea of what final weight it may be so I'm sure he
will post the results when he has had a chance to do it, and maybe some pics of all the carbon look internal brake lines
#698
Yeah Ive seen the escorts green lines to match the green focus rs paint colour but I want something a bit more subtle to match anthracite
that il be painting the inside with so Andrew said he has the carbon look so should look good when all done,
Also picked myself up a full carbon bonnet that I will be collecting from ford fair
#699
Also picked myself up a full carbon bonnet that I will be collecting from ford fair![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#703
few pics of the bonnet i got off fleabay,
as said its not mint has has a few defects and isnt a great finish, i would not pay the full Ł514 if the finish was like it from new but as said its over 2 years old now but its function over form for Ł270 and looks good unless very close up
![Name: PICT0030-1.jpg
Size: 171.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119183d1501884623-mk6-jwrc-fiesta-cosworth-pict0030-1.jpg)
![Name: PICT0031.jpg
Size: 192.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119184d1501884623-mk6-jwrc-fiesta-cosworth-pict0031.jpg)
it will do for now![Top](https://passionford.com/forum/images/smilies/smile011.gif)
got some better pics of my fuel rail from M K Motorsports that is spot on and looks the part
![Name: PICT0025-1.jpg
Size: 179.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119185d1501884623-mk6-jwrc-fiesta-cosworth-pict0025-1.jpg)
![Name: PICT0023-2.jpg
Size: 213.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119186d1501884623-mk6-jwrc-fiesta-cosworth-pict0023-2.jpg)
and a few more of the big wing sump with -6 drain instead of the standard bolt that rounds off and needs the nylon washer replacing all the time, no need for that with aeroquip caps and they dont drip. Also has boss for 1/8th npt oil temp sensor and -10 fitting for oil breather drain![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Name: PICT0028-1.jpg
Size: 188.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119187d1501884623-mk6-jwrc-fiesta-cosworth-pict0028-1.jpg)
![Name: PICT0029-1.jpg
Size: 184.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119188d1501884623-mk6-jwrc-fiesta-cosworth-pict0029-1.jpg)
holes between sump and big wing
![Name: PICT0026-2.jpg
Size: 263.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119189d1501884623-mk6-jwrc-fiesta-cosworth-pict0026-2.jpg)
I also managed to catch up with Andrew at ford fair, and have a look at the fuel tank in the green AG escos as mine is identical so impressed with that and the fact it has worked faultlessly with hard track use/cornering so a great job done by the AG boys as usual,
Andrew said the battery recess is now welded into the floor and the carbon brake lines are pretty much finished so just the bonnet pin mounts to go and its gonna get chucked on the scales this week to see what its weighing in at so far so that will be interesting,
roll on saturday
it will do for now
roll on saturday
#709
you need to put more holes along the top of where the big wing is or the oil will not be able to go in & out as it will be air locked i put 10mm holes in mine,make sure you put a hole in front of the x shaft so air can get out 4 in total will be fine a few more holes as low as possible as well or you might struggle to get all your oil out when its time .
#710
Thanks Andy I have asked alot of people
About what holes are needed etc and got no real answer but Gus showed tommy field the
Pic for me today and he said to put a dozen 6mm holes along the top and to put a few more holes right along the bottom and then slot them together
You have any pics of yours?
Do you run a sump baffle as well as tommy has advised me too,
#712
thanks Dave, your have to pop over for a look when its back ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
got a quick picture from Andrew of the pump and filter housing that will mount underneath the car next to the fuel tank sump, all nice and neat and covered up so just the fittings into pumps and out of filters are exposed, will be using 2 of the proper motorsport bosch 10bar fuel pumps and ford motorcraft filters,
Another top job from Andrew and the guys![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
![Name: IMG_0648.png
Size: 264.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119190d1501884623-mk6-jwrc-fiesta-cosworth-img_0648.png)
#713
#715
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/IMG_0648.png)
#718
volcomstone411 - thanks mate, i have always loved the jwrc cars and the fiesta won it for me, although i was very close to doing the same thing to a puma shell,
Well the trailor is locked and loaded so to speak and the travel lodge is booked and drinking boots packed, so tomorrow me and gus are off to sunny scotland to collect the car from Andrew, and then head back sunday
#719
Well the trailor is locked and loaded so to speak and the travel lodge is booked and drinking boots packed, so tomorrow me and gus are off to sunny scotland to collect the car from Andrew, and then head back sunday![Top](https://passionford.com/forum/images/smilies/smile011.gif)
bet you cant wate mate.
thanks steven..
#720
Cheers mate , i tried to make mine as simple as possible without compromising the fuel delivery in any way! youd be mad to cut corners with a fuel system eh!
