Mk6 JWRC fiesta cosworth
Old 08-09-2015, 08:14 PM
  #4281
markk
markk's Avatar
Eh, your previous post says the biggest problem was getting the splines aligned?
I actually mis read who the poster was and thought MK had forgotten to swap to Datsun splines.
Ok, what my mind was thinking maybe didn't come out in text, the clutch plate alignment to the splines, no issue, aligning the 3 plates onto the length of splines available took alot of fettling 😉
How's that?
Old 08-09-2015, 08:17 PM
  #4282
Caddyshack
Caddyshack's Avatar
How's that?
Ah, got you now! Thanks for clarifying.
Old 08-09-2015, 08:39 PM
  #4283
COLEYST200
COLEYST200's Avatar
Are you still putting mt75 back in for the weekend or now going for the skyline gearbox
Old 08-09-2015, 09:02 PM
  #4284
M K
M K's Avatar
Markk - With the twin plate I have no issues at all as the depth of spline needed to engage both plates is around 31mm and the length of spline going through from the input shaft is around 35.5mm so I can see why you would struggle getting it all to fit with 3 of them
Toby - Stuff I use was from a friend and is silly expensive for what it is but in theory any good 3m tape would do the same job
Ian - I will put the cossie box in for the weekend as I will not have time to modify the exhaust, I would of happily ran it with no attessa pump in2wd now I know no damage would be done but im not driving it with no exhaust
So I will put the skyline stuff in, take it for a quick spin and make sure everything is good and working correctly then re fit the cossie stuff for the weekend,
Then before my trackdays at the start of November I can get the 2wd/4x4 pressure switching sorted and re do the exhaust
That's the plan anyway
Caddyshack (09-09-2015)
Old 09-09-2015, 12:34 AM
  #4285
ossie cossie
ossie cossie's Avatar
great work.
Old 09-09-2015, 05:24 PM
  #4286
M K
M K's Avatar
Cheers mate
Got the skyline box fitted today
Went together like a dream even on my own, helps that the gearbox weighs more and sits evenly on the jack and is better balanced,
Had no issues with splines lining up splines or getting gearbox bolted up at all, was almost too easy lol
Anyway some fitted pics
The cylinder has 5-6mm to give for clutch wear
Front prop on with nice clearance
Rear prop all in
All in, not painted or powder coated gearbox mount yet just in case I needed to alter anything
Started the car just to check it but only for a sec as I have not put the oil in the box yet
Going to do that tomorrow and maybe take it around the block to test but it's fecking loud with just the downpipe
Old 09-09-2015, 06:47 PM
  #4287
COLEYST200
COLEYST200's Avatar
Looking good under there mate
Old 09-09-2015, 07:55 PM
  #4288
Caddyshack
Caddyshack's Avatar
Glad it went in well, top job. I am hoping my next attempt goes as well!
Old 09-09-2015, 09:17 PM
  #4289
M K
M K's Avatar
Cheers Ian
Toby - I posted on your thread also but incase anybody else has issues or wanted to know I will post here also
Going by me measuring my block/crank....
The stick out of the input shaft beyond the block face can be NO more than 6.5mm or the input shaft will be jamming up against the bottom of the crankshaft spigot hole
Caddyshack (10-09-2015)
Old 10-09-2015, 12:50 AM
  #4290
ossie cossie
awesome work. love it.
Old 10-09-2015, 02:55 AM
  #4291
M K
M K's Avatar
Had an early finish due to a cancelled night shift so just filled box with Redline heavy shockproof gear oil and what a long winded task....... About 4.1 litres and it's like syrup so took forever to pump in with a hand pump lol
Also filled transfer box with Redline ATF racing fluid
Not a bad way to spend Ł130
Old 10-09-2015, 03:13 AM
  #4292
ossie cossie
What type of redline ATF and do you have a pic of the bottles. i need to order some myself from ebay. they are $100 each here in OZ thats about the same price in pounds.
Old 10-09-2015, 10:18 AM
  #4293
M K
M K's Avatar
Here you go mate
Old 10-09-2015, 11:09 AM
  #4294
ossie cossie
Thanks i will order some straight away.
Old 10-09-2015, 12:15 PM
  #4295
Fudgey
Baby Cheesus
Fudgey's Avatar
Excellent work mate!
i used redline HSP in my impreza gearbox, mixed with some castrol heavy gear oil.
it was like pouring treacle so i put the bottles in a bucket of hot water for 20 mins to warm it up, went in a bit easier but still took forever. on the impreza you fill via the gearbox dipstick hole
Old 10-09-2015, 07:03 PM
  #4296
COLEYST200
COLEYST200's Avatar
Have you drove the car with it yet
Old 10-09-2015, 08:18 PM
  #4297
M K
M K's Avatar
Fired it up before driving it out the garage with no exhaust as I haven't made it yet lol
Old 10-09-2015, 08:47 PM
  #4298
M K
M K's Avatar
That's just a video of it with no exhaust lol
Will quickly run it down the road tomorrow.
Baffled the gear lever today to stop the common transfer fluid leak, I haven't had the issue as I've not driven the car but read about it and as it was a sime mod I thought I'd do it anyway
Before
After
Old 10-09-2015, 08:51 PM
  #4299
COLEYST200
COLEYST200's Avatar
Looks a nice small mod I will have to look into it my self
Old 10-09-2015, 08:59 PM
  #4300
M K
M K's Avatar
Yeah i was searching for some other info and came across this
http://www.elitetech.co.uk/N1Baffle.htm
So thought id get it done as i bloody hate stupid little annoying leaks that make massive mess
Old 11-09-2015, 10:12 AM
  #4301
Caddyshack
Caddyshack's Avatar
Thanks for the pic....I will get making one. What thickness steel? or Ally? did you use?
Old 11-09-2015, 10:37 AM
  #4302
M K
M K's Avatar
Only about 1mm mate maybe even 0.8mm
Caddyshack (11-09-2015)
Old 11-09-2015, 11:36 AM
  #4303
ossie cossie
I see its just a thin flat plate cut and fitted under the original baffle.
Old 11-09-2015, 12:12 PM
  #4304
M K
M K's Avatar
Yes mate
Old 11-09-2015, 12:21 PM
  #4305
TPM961
TPM961's Avatar
The word 'awesome' is over used a lot. But in this case it's an understatement. Fantastic work.
Old 11-09-2015, 01:01 PM
  #4306
Caddyshack
Caddyshack's Avatar
Cool, I will fire up the Plasma cutter and file it to suit....can you see any issue with using stainless as I have some here...if not I have some 1mm
Old 13-09-2015, 09:55 PM
  #4307
M K
M K's Avatar
Can't see it making any difference Toby I just happened to have some thin mild steel so used that
As I didn't get to pod today for Ford Fest I done some on the skyline exhaust
Still have to cut 1 more piece to complete it as it was too late to fire up the chop saw lol
Had to make some tight bends from pie cuts to clear things like the pressure feed on the rear of the box and had to unweld and move a few times to get right but will be all good once fully done
Also had to shorten the back box by 250mm as the skyline box is longer
Once the last piece is in I will double check everything then I will purge weld the lot, so should be done by end of the week then il look at mounting the attessa pump and getting that plumbed in
Few pics
Just 1 piece here to finish the jigsaw
More pics when it's all done
Old 13-09-2015, 11:50 PM
  #4308
Hellraiser
Hellraiser's Avatar
Lovely bit of fab work on the exhaust mate, car is gorgeous I have to say :0) your a talented fella keep up the good work
Old 14-09-2015, 07:49 AM
  #4309
Fudgey
Baby Cheesus
Fudgey's Avatar
I take it the skyline stuff is staying in now? cool beans fella, will soon be done!
Old 15-09-2015, 10:06 AM
  #4310
M K
M K's Avatar
Thanks mate
Yes mate decided it was not worth swapping back and forth with the cosy stuff and I had to work a shift which meant no Ford Fest so just going permanent skyline now
Old 15-09-2015, 10:58 PM
  #4311
M K
M K's Avatar
Exhaust is all done apart from waiting on some new rubber hangers
Not as neat as I like it I rushed it to be honest, anyway
How it all sits under the car now
Once hangers are here I can take it for a test drive with the new box
Old 17-09-2015, 10:13 AM
  #4312
M K
M K's Avatar
I am not going to be able to afford the ETS PRO controller just yet so can anybody tell me the basic wiring install I will need to run the box in 4wd and 2wd using the attesa pump via a switch?
Old 17-09-2015, 10:47 AM
  #4313
COLEYST200
COLEYST200's Avatar
Your going to need one of these then mate so you can set the psi to wot you won't . I will give you more info tonight as I'm off out now .
http://pages.ebay.com/link/?nav=item.view&alt=web&id=271492847161&globalID=EB AY-GB
Old 17-09-2015, 10:57 AM
  #4314
M K
M K's Avatar
That would be great
Cheers Ian
Old 17-09-2015, 12:53 PM
  #4315
ossie cossie
I bought one of them as well just to test the box. Before going ETS pro in the future. Haven't tried it yet but looks simple enough to wire up.
Old 17-09-2015, 09:10 PM
  #4316
COLEYST200
COLEYST200's Avatar
Right it's prity simpol the motor is 12volt and as you no there is a presher switch that brakes when the pump hits aprox 500/600psi so if you wire it with a relay and fuse so when you turn the pump on it turns the pump off at max and simple wire the veribull risister in so that will control the amout of psi that's sent to the gearbox and at the same time plum in a psi gauge so you can see wot it's doing very simpol to be onist . But as I'm finding out don't try to run to much psi to the gear box as with this gear box more is not all ways better when we did silverstone I had it set at 200 psi and as all I was thinking was save the diff and driving the car I forgot to lower the psi witch made the car 4 wheel slide in the corners witch was not good . These gearboxes are that strong my car has been driven two times now with the rear diff smashed to bits just by putting it at about 200psi there that strong
Old 17-09-2015, 09:24 PM
  #4317
markk
markk's Avatar
The pump should only make about 200psi if it's wired proper😉
Old 17-09-2015, 09:30 PM
  #4318
Caddyshack
Caddyshack's Avatar
It only needs that for full lock but it can go past 600 of left to go full chat.
Old 17-09-2015, 10:01 PM
  #4319
markk
markk's Avatar
For what purpose? And only if you bypass the built in pressure switch.
Old 17-09-2015, 10:08 PM
  #4320
frayz
Boost Junkie
frayz's Avatar
Great job Marc. Can't wait to see it.
You doing Snet 300 on 9th November?
Quick Reply: Mk6 JWRC fiesta cosworth
