Transit Connect with ST170 running gear?
I've owned my connect from new (2005) and would like to know if it's possible to fit the engine and running gear from the Focus ST170. I believe the Connect is Focus based so would the swap be a simple one? Would the whole wiring loom from ST need to be transfered?
I suppose the best bet would be to pm BIG.GEOFF.H as he has done a couple of Focus RS engine conversions, maybe he can give you pointers or even fit the engine and loom etc.
Hope this helps.
Hope this helps.
Easy to do as above its all focus up front any way so u can fit that in no problem i changed every thing on mine and fitted discs to the rear beam and has all the abs on it as well if you need any info ring me on 01204 521850 and ask for geoff
heres my 2 i did
heres my 2 i did
yes not to bad we fitted the full loom and moddified it in a few places as the connect rear light loom runs onder the van so we joined it behind the seats and run it throgh the floor and modded the central locking as well other than that it all went in fine
van_dogg_pavvy
03-03-2016 09:30 AM
James Porter
28-10-2015 12:17 PM
23
12-09-2015 12:56 PM
