Lets get on with it then !!!!!!!!!!!
#203
#204
PassionFords Creator
I take its that's cryptic for there is another thread and you have decided not to continue with the one you started here so if we are interested we should just search for ourselves?
#209
Marks guess at Power given to the mag before he started was 840bhp limited by port sizes & exhaust cam it made 838.4bhp & flatlined after 6.5k. Impressive low down i wont be chasing the 100 horses or so that would be found with a big valve head & wilder exhaust cam it would destroy that flat torque curve. The smaller Turbo made 810bhp & spooled 300 rpm earlier with similar peak torque & its that turbo I will probably end up fitting not sure yet.
#211
#220
#221
#224
Mark
#230
Mike i read your reply several times & thought do all those smilies mean hes joking or has he got it wrong, funnily enough Mike I thought you were joking..
#231
No, I think I just misheard what Chip said, as I was convinced he said it was almost perfect dyno conditions, so the correction factor was only a tiny percentage and that it made 838, corrected to 831bhp . My bad !
That's good power for the port sizes - mine is only 500bhp and uses bigger .
#232
It is good power for the port sizes, but as I was saying to jimbo last night, at 8.7:1 you have 20% more pressure in the cylinder head at the end of the exhaust stroke than you have at 7.2:1 so that has to help with getting the last few gasses out.
Rich, can you quote me, in case im still on ignore, Im sure Mike wont mind reading this reply
#233
It was near perfect temp/pressure, hence the correction factor was only 0.9% just in the opposite direction to the impression I gave you it would appear, apologies for not being more clear.
Quoted
#234
chip wanted this quoted
#237
Done nothing for a week under doctors orders so the stripping of the car for the cage has not happened, will probably go to MAD tomorrow to start but ive family commitments on Saturday so the Monday delivery of the car to XSport looks dodgy. Still my health comes first i suppose, will keep updating till the bl**dy thing is finished, dont ask when cos ive no idea.
Heard from Topgear mag yesterday, they may use the car on the launch of the Focus Rs no idea what that means as its a few months off yet & may probably means wont, we shall see.
Rod
Rod
#238
Rod
Rod
#240
We went back to the WRC gasket & used a new form of head studs. The compression ratio was also raised (8.7:1) so that less ignition was required, hence less cylinder pressures. Last time saw 26 deg ignition this time only 16. A very conservative engine.
