Time Attack ST170 Build - 17/05/11 - More Engine Loom & Dash Stuff
Old 26-12-2008, 01:46 PM
  #201
fezzajsy
fezzajsy's Avatar
Old 15-01-2009, 11:20 PM
  #202
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Right, quick update!
Engine bay now looks like this!
Top end of the supercharger removed:
Heat exchanger removed:
Delivery from Wizards Of Nos:
Marking out with new fuel rail:
Scary part - drilling holes!
Say hello to my little friends - lol
Now seen here...
And here
A short time later:
Then i started doing this... From this:
To this!
Then this arrived...
And one of these!
Then a bit of this...
And a start on the exhaust ports for the new head...
More as it happens!
Old 15-01-2009, 11:54 PM
  #203
pani_k
PassionFORD Member
pani_k's Avatar
Wow and errrr....WOW!! Really not doing this in halves are you!!! How big is the mortgage you've taken out to fund all this shit?! Going to be a proper BIG car this!
Old 16-01-2009, 10:40 AM
  #204
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
Good work Will!
Old 16-01-2009, 03:30 PM
  #205
Great work
Old 16-01-2009, 03:37 PM
  #206
fezzajsy
fezzajsy's Avatar
awesome stuff
Old 16-01-2009, 04:59 PM
  #207
XRT_si
XRT_si's Avatar
Very nice, so where exactly does the blower mount on the inlet? I thought it was like the Jackson Racing supercharger converison? Any detailed pics of it?
Old 16-01-2009, 05:19 PM
  #208
Big Will_
Big Will_'s Avatar
It's a complete replacement for the inlet manifold mate - basically, the supercharger is behind the block, the snout holds the pulley wheel under the alternator, then it comes up and feeds onto the head like the standard manifold - very neat setup
Thanks for the kind words guys
Old 17-01-2009, 03:34 PM
  #209
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
Very very interesting read this - makes a change from the usual Cossie builds on here.
Old 17-01-2009, 03:53 PM
  #210
andy escos
andy escos's Avatar
nice car m8
Old 18-01-2009, 05:12 PM
  #211
Big Will_
Big Will_'s Avatar
Cheers mate
Might not make massive numbers like some of the Cossie boys - at the end of the day most people are topping these chargers out at around 290bhp and there's no easy way of increasing from there sadly
Old 18-01-2009, 05:19 PM
  #212
rst-g
ZETEC TURBO
rst-g's Avatar
keep it up will mate
Old 18-01-2009, 09:50 PM
  #213
COCHYN
COCHYN's Avatar
Cracking matey, my computer at home works well!
Old 18-01-2009, 10:02 PM
  #214
Big Will_
Big Will_'s Avatar
Great news!
Seeing as you trashed your work one and were asking me for updates by text you cheeky ginger welsh tail toucher
Old 18-01-2009, 10:10 PM
  #215
rst in breaking
rst in breaking's Avatar
top work will, you do love to keep yourself busy lol
Old 18-01-2009, 10:30 PM
  #216
Big Will_
Big Will_'s Avatar
Busy?! Understatement of 2009 dude
Think i'm going to have to pull out of Bedford - not prepared to rush this and make any mistakes - if i can get it all done, dusted and shaken down for RSOC Central Day at the pod i'll be happy
Old 18-01-2009, 10:41 PM
  #217
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
How well do them chargecoolers work?
Old 18-01-2009, 10:54 PM
  #218
Big Will_
Big Will_'s Avatar
As well as the design allows...
Seriously - to run an air to air intercooler setup (my personal preference) would probably free up some power but is virtually impossible to do on this particular setup.
The powerworks kit was designed as a 'bolt on' solution and it works well, don't get me wrong...
But i did find i was getting high ACTs on track - one of the reasons i've changed the spec to try and get the engine to make the same power at less boost - i.e 14psi at 50 degrees gives the same power as 10psi at 30 degrees...
Nowt ventured, nowt gained
Old 18-01-2009, 10:58 PM
  #219
Charlie Chalk
Unknown.
Yeah I know the kits a bolt on jobbie, But Just wondered actually how well it does perform, as it looks small.
How big is the radiator? Could you not run a water box in the car filled with ice for track?
Old 18-01-2009, 11:05 PM
  #220
COCHYN
COCHYN's Avatar
Originally Posted by Will @ M Developments
Great news!
You racist discriminating......fuck ya, I ain't dropping myself to your level ya troglodyte
Build is really coming along well, will stop by in the next few weeks to say hey
Old 18-01-2009, 11:24 PM
  #221
Big Will_
Big Will_'s Avatar
The chargecooler rad can be seen under the numberplate in the pic below - can't get it much bigger!!!
Old 18-01-2009, 11:36 PM
  #222
boothy
boothy's Avatar
big
Old 19-01-2009, 02:07 AM
  #223
CarbonRick
PF Village Idiot
CarbonRick's Avatar
Car is looking fantastic, I remember Ian's incarnation from FFOC days. Glad to see it moving to the next level.
Old 19-01-2009, 05:45 AM
  #224
patalrob
In Training
patalrob's Avatar
Mother of god! Been awhile since i've checked up on this.
Looking great Will!!
Old 19-01-2009, 05:12 PM
  #225
fezzajsy
fezzajsy's Avatar
Old 19-01-2009, 07:52 PM
  #226
AustenW
AustenW's Avatar
Old 19-01-2009, 09:05 PM
  #227
Rick
Rick's Avatar
Will - have a look at extra pumping capacity - ideally u want to generate pressure in the system - it has a signficant effect on getting the heat out of the chargecooler core.
Rick.
Old 22-01-2009, 09:53 PM
  #228
Big Will_
Big Will_'s Avatar
Rick.
Yeah, been looking into fitting a 'Craig David' electric water pump as a secondary booster - tempted to see how well the new head flows frst
as i suspect i'll have superior air flow. That could well see a reduction in boost pressure and air temps accordingly...
Apologies for updates being slow progress - been working some ridiculous hours recently, but hey - overtime is no bad thing!
Found a few minutes to mock out a few more bits for the nitrous - joyous task of working out what i control, what the nitrous maximiser controls and what the ECU controls - making sure it's consistent and repeatable is the plan!
Oh - and picked up a few bargains at Autosport which i've finally got round to unpacking!
Might get chance to do a bit at the weekend - will update as it happens!
Old 23-01-2009, 09:27 PM
  #229
patalrob
In Training
patalrob's Avatar
What compression do you plan on for your pistons Will?
Also where did you get your cat cams ground?
Doing great work!! That N2O is going to be a blast!!
Old 24-01-2009, 02:02 AM
  #230
Big Will_
Big Will_'s Avatar
Expecting to run between 9.8:1 and 10.2:1 depending on how much gets decked off the block and the head before final assembly.
CAT Cams were done through Quality Engineered Products (QEP) - i can get you contact details if required!
Yeah - hopefully the gas will ice the cake - i might even run it on track for the straights
Old 24-01-2009, 03:30 PM
  #231
Big Will_
Big Will_'s Avatar
Righty - managed to get a bit done on the dash today!
Started by removing the inside of the surround - this was a LONG and painstaking job, let me assure you!
From this:
To this:
Then time to cut the carbon surround to sit behind it:
Which then looked a little like this!
And when the tape came off:
Then time to finish the surround off and paint it:
Decided the black backing was better on the AEM gauge:
Semi finished article:
More to come soon hopefully!
Old 24-01-2009, 03:39 PM
  #232
SteveH
SteveH's Avatar
Nice work will, been reading this alot recently!
Old 24-01-2009, 04:17 PM
  #233
MAD EVO 4
MAD EVO 4's Avatar
looking good Will
keep the pic coming
good read
Old 24-01-2009, 04:35 PM
  #234
kev 3dr
kev 3dr's Avatar
Its lookin ace mate keep it up !!!
Old 24-01-2009, 04:48 PM
  #235
McGoo 69
McGoo 69's Avatar
damn this is gonna be a animal!
good to see something different that turbo, awesome work
Old 24-01-2009, 05:23 PM
  #236
COCHYN
COCHYN's Avatar
Dash looks impressive pal
Old 24-01-2009, 05:48 PM
  #237
fezzajsy
fezzajsy's Avatar
luving dash
Old 24-01-2009, 06:57 PM
  #238
youngben
youngben's Avatar
looks ace that matey
Old 24-01-2009, 07:00 PM
  #239
Great work there
Old 25-01-2009, 09:05 AM
  #240
sbd16v
sbd16v's Avatar
looking good mate loving the dash install
your going to need to my gas is going back in in the next few weeks
Quick Reply: Time Attack ST170 Build - 17/05/11 - More Engine Loom & Dash Stuff
