My '88 Sapphire RS Cosworth 2wd (update 23.04.11)
Old 22-06-2010 | 04:59 AM
  #561
MARCOSWORTH's Avatar
MARCOSWORTH
Old 27-06-2010 | 04:31 PM
  #562
RS-Stian's Avatar
RS-Stian
www.fordclubnorway.no
Well, i had plans to fire the car up this weekend but discovered some major problems with the braking system
Issue number one: the rear brake pressure reducing valve is clogged which is probably caused when it got anodised/electroplated. I have tried to disconnect it and clean it properly but no luck.
Issue number two: the ABS pump is leaking fluid somewhere from the round motor that sits underneath the valve block.
Old 27-06-2010 | 04:50 PM
  #563
cossiedevil22b's Avatar
cossiedevil22b
Top work done to a super motor stunning
Old 27-06-2010 | 05:30 PM
  #564
damien roe's Avatar
damien roe
lovely car 10/10
Old 28-06-2010 | 04:56 AM
  #565
MARCOSWORTH
Shit Stian, hope it's a easy fix
Old 11-07-2010 | 04:29 PM
  #566
krzoska82's Avatar
krzoska82
this car seems to be getting better and better top work and a pat on the back to you
shame about the leaks im sure you will sort it out in no time
Old 12-07-2010 | 10:39 AM
  #567
Rs_Nick's Avatar
Rs_Nick
Hope you can fix it mate. Car looks sweet
Old 16-07-2010 | 01:33 PM
  #568
RS-Stian's Avatar
RS-Stian
Sorry for the lack of updates but have been working alot to fix those brake issues. Managed to get hold of a good brake pressure reducing valve which fixed one of my problems. Then next problem occured, the T-piece was leaking but had a brand new one so an easy fix. Lessons learned, do NOT anodize/electroplate brake parts.
The ABS pump was leaking from around the motor so i took the whole thing out and used some proper tube sealing gasket. Now it was time to bleed the brakes but by some reason the pump wasn't building up any pressure to the accumulator, no fluid was coming back to the rear calipers either. Took the whole unit out (again) and when opening the motor the small round washer with two tappets only had one tappet left, the other one was broken. With this broken the motor cannot get the other part attached to spin around.
So next task was to source up a new ABS unit and next day i was heading towards a friend of mine to pick up a unit he had laying around. Cleaned it up properly, changed the fluid bottle as mine looked abit better and those bolt and nuts of course. Bolted the new unit into the car and i was ready to bleed the brakes, but the same problem as before occured, the motor was running and running without any sign of building up pressure. I started to get really frustrated now but yesterday i tried to pump the brake pedal without the ABS motor on. The pedal was slowly getting harder and harder, and when i started the motor now it was building up pressure too. After 20-30 seconds the motor stopped, what a relief!
Happy as i was i started to bleed the brakes. Began on the right rear caliper, my assistent pushed the pedal in, started the motor and the fluid came out. Did the same process on the left side with success but when i was close to finish up the right front caliper i heard some dripping from the rear right caliper. It was fucking leaking, and guess what, from inside around the piston!
Now i need to send the calipers back down to Biggred i UK since i got them refurbished there. My plan was to get the car down on it's wheels during weekend but now i need to wait at least 3 weeks
Old 16-07-2010 | 04:30 PM
  #569
MARCOSWORTH
Bugger mate
It will be worth the wait
Old 16-07-2010 | 05:32 PM
  #570
Cossy Mike's Avatar
Cossy Mike
Bin them mate there wasted on your car. You can buy brand new genuine Ford calipers from Power torque racing for Ł119
http://cgi.ebay.co.uk/ESCORT-SIERRA-...item5193e2e551
I'm just at the begining of mine, inlet out over the weekend then the engine next
Old 16-07-2010 | 05:47 PM
  #571
Rs_Nick's Avatar
Rs_Nick
Damn that sucks
Good luck with waiting... Times fly when your having fun, but now
Old 16-07-2010 | 09:01 PM
  #572
fezzajsy's Avatar
fezzajsy
hope u get it sorted mate
Old 17-07-2010 | 04:25 PM
  #573
krzoska82's Avatar
krzoska82
it wont be long m8
Old 20-07-2010 | 08:59 PM
  #574
RS-Stian's Avatar
RS-Stian
Calipers are now sent back to BiggRed and i will probably pick them up when i'm in UK in August. Flight tickets, rental car and hotel are now booked, really looking forward to Ford Fair
Well, while waiting for the calipers i can sort out some other minor things. Got the gauges connected and wired up here the other day.
I've also ordered a new fuel pump loom as i didn't get the one i bought to work. The new loom will go straight from the battery to the pump and not through the original pump relay.
Old 20-07-2010 | 09:04 PM
  #575
COCHYN's Avatar
COCHYN
Wow man, really going all out with this, well done! You'll enjoy Ford Fair, plenty of toys to buy for your car and loads of inspiration from the motors on display
Old 20-07-2010 | 10:06 PM
  #576
fezzajsy's Avatar
fezzajsy
sweet
Old 21-07-2010 | 04:25 AM
  #577
Cossy Mike's Avatar
Cossy Mike
Oooo very nice
Where can you get the full fuel pump looms from??
I been looking and can only find the ones you refer to, that go through the original relay
Old 21-07-2010 | 04:48 AM
  #578
MARCOSWORTH
Gauges look nice mate
Old 21-07-2010 | 07:44 AM
  #579
Miller 3's Avatar
Miller 3
Originally Posted by saphcosmike
Oooo very nice
Ryan on here can make you one
Old 21-07-2010 | 10:11 AM
  #580
Cossy Mike's Avatar
Cossy Mike
Ryan??
Will it be the same qaulity as the other 'kit', with the proper connections on the fuel pump?
Old 21-07-2010 | 07:12 PM
  #581
RS-Stian's Avatar
RS-Stian
Cheers mate. Yes, first time at Ford Fair for me this year, definitely gonna use alot of time around the concourse cars to see what the standard are up to
Old 21-07-2010 | 07:14 PM
  #582
RS-Stian's Avatar
RS-Stian
Oooo very nice
It's from an eBay guy called 'gs618328'. The auction has ran out so i had to send him an e-mail.
Old 21-07-2010 | 08:37 PM
  #583
COCHYN's Avatar
COCHYN
Yeah....their pretty high
Old 22-07-2010 | 06:38 PM
  #584
Rs_Nick's Avatar
Rs_Nick
Good work! Have the same plate in my 4x4.
Ford Fair is great! was there ones. But this year i'm on holliday.
I've also baught a new wiring for the fuel pump. Incl the group a pump. Mine is from ebay and the seller names cw_looms_uk. Fit the wiring also by my brohters 3dr. Verry good! Same as yours, From battery to Pump. Relais in the wiring.
Good luck with it
Old 26-07-2010 | 12:28 PM
  #585
RS-Stian's Avatar
RS-Stian
While waiting for the calipers and pump loom to arrive i started working on the boot and spoiler during the weekend. There are some surface rust around one of the mounting pillar that has annoyed me for a long time along with a dent on the boot and some minor paint fault spots on the spoiler.
When disassembling the spoiler only one bolt came out in one piece (of course), both bolt heads for the middle pillar went off and i had to drill off the head on the last one. After some fiddling work the spoiler was finally off and i could start drilling out what was left of the rivnuts in the boot which obviously went easy, but the ones in the spoiler was hard to get out. Now i need to find a couple of new rivnuts to glue back into the spoiler. The two holes in the boot are hexagonal so i need to find some hexagon rivnuts to use there.
The painter is on vacation now so i need to wait a week or two before i can get the boot and spoiler painted. I hope he can only paint and fix those areas where there are some surface rust as i don't want to paint the whole boot since it overall looks very good. Looking forward to get all this sorted out
Old 03-08-2010 | 07:31 PM
  #586
RS-Stian's Avatar
RS-Stian
Boot and spoiler are now sent away to the painter.
Have been struggling a bit to get the fuel pump running. The new loom i've got was too short but Gary is a top guy and will send me another one. After a few hours with troubleshooting and pissed off as well i wanted to try the first loom i bought from Prometheus again and then the pump was running. Another problem fixed
Just had to try to turn the engine around for the first time too and it seems like everything is working. So next time, car are fortunately back on it's wheels, fuel on the tank and i'm ready to fire her up.
Old 03-08-2010 | 07:42 PM
  #587
I like the gauges.
Old 04-08-2010 | 07:15 AM
  #588
MARCOSWORTH
You''ll get there mate
Also got fuel pump and fan looms from Gary a while ago, good man to deal with
Old 18-08-2010 | 07:53 PM
  #589
RS-Stian's Avatar
RS-Stian
Time for a little update again. Bootlid and spoiler are back from painting and got it all mounted today. Think i was really lucky with the painting as i can't see any color difference between the boot and rest of the car. Of course, the boot are more shiny but the car hasn't been washed or polished for the last two years.
Think the boot suits good without any badges but they are coming back soon.
And guess what, wheels are now ordered
Old 18-08-2010 | 07:55 PM
  #590
damien roe's Avatar
damien roe
looking the nuts mate
Old 18-08-2010 | 09:06 PM
  #591
DaveCrack's Avatar
DaveCrack
You're for sure a perfectionist when it comes to your Saph!!!
Old 19-08-2010 | 04:39 PM
  #592
fezzajsy's Avatar
fezzajsy
looking good mate
Old 19-08-2010 | 09:37 PM
  #593
R5COS's Avatar
R5COS
top work fella its gonna be a cracker once finished
Old 20-08-2010 | 11:01 AM
  #594
RSRoy's Avatar
RSRoy
What wheels have you ordered mate?
Old 20-08-2010 | 04:12 PM
  #595
RS-Stian's Avatar
RS-Stian
Cheers guys
RSRoy: These mate, 8x17" Image DM.
Old 20-08-2010 | 04:49 PM
  #596
fezzajsy's Avatar
fezzajsy
diffrent from the rest mate.u not getting old skul comps then?
Old 20-08-2010 | 04:58 PM
  #597
Tommen's Avatar
Tommen
My pet is Moonstone blue!
Cheers guys
hĺhĺ!
ET???
and price in norske kronur?
(slapp av eg skal ikkje herme)
Old 20-08-2010 | 05:03 PM
  #598
damien roe's Avatar
damien roe
great wheel choice mate
Old 20-08-2010 | 05:31 PM
  #599
RSRoy's Avatar
RSRoy
Nice wheel but look good at the finish of them. I've red some stories by people who had the same wheels but the quality was lacking initially. Fixed by Image Wheels though
Old 22-08-2010 | 09:33 AM
  #600
MARCOSWORTH
Looks good mate, shame you can't drive it yet
How long for the brakes to be solved???
Quick Reply: My '88 Sapphire RS Cosworth 2wd (update 23.04.11)
