Tim Garringtons WRC V8, Engines back in and bulk heads nearly completed! 03/05/11
Old 03-05-2011, 09:23 PM
  #201
whizzisat114
whizzisat114's Avatar
I so want that engine for my focus project
Lovely fab work on the bulk head
Are you using an adjustable rake bearing for the steering?
whizzisat114 is offline
Old 03-05-2011, 10:10 PM
  #202
timbhp
timbhp's Avatar
thanks for your comments, hows your project going?
will be using rose joint for lower mount and remake top mount to take original
column fixing
timbhp is offline
Old 03-05-2011, 10:27 PM
  #203
Minirotty
Lucifer II - 666
Minirotty's Avatar
Looking amazing Tim! I'll pop over later in the week mate
Minirotty is offline
Old 07-05-2011, 09:32 PM
  #204
v8ndy
How much! I`ll have it!
v8ndy's Avatar
Wink Wink! Nice choice of engine there chap
Great looking project, I did try it for size in the 206`s engine bay and thought this could fit! But it was already destined for the TVR
v8ndy is offline
Old 07-05-2011, 10:52 PM
  #205
whizzisat114
column fixing
Slowed down a bit a s ive been helping m8's out with there project's
But ive started to mod my loom's at the mo and im gonna have to finish them off before i can prep it for paint , Guess ill have to pull my finger out
Enjoying back working on it with no stress to finish it
Would love a V8 monster in the front of it real envious of you and your build
Old 07-05-2011, 11:37 PM
  #206
timbhp
timbhp's Avatar
nice set up you have ,what size is the kenne bell s/c? and what transmision you going to run
timbhp is offline
Old 08-05-2011, 04:55 AM
  #207
jonfoc
jonfoc's Avatar
Just read this thread from start to finish. Amazing! this is you when you have had a disk removed, What were you capable of when fully fit. Stunning work Tim.
jonfoc is online now
Old 08-05-2011, 09:48 AM
  #208
v8ndy
v8ndy's Avatar
Its running the 2.2 charger with a choice of pulleys from 14-20 psi at 20psi its been dyno`d at 650bhp. I`m using the Tremec TKO600 as it fits into the chassis, will handle 600lbs ft or so they say and multiple position for the gear change, The T56 box i think your using is a big bugger and wouldn`t fit without altering the tunnel. I`ve just got the ecu back this weekend from having the PATS removed so hopefully a start should be on the cards today
v8ndy is offline
Old 16-05-2011, 08:22 PM
  #209
timbhp
timbhp's Avatar
small update
pedal box in place
with dash for test fit
need to make lower column extension so got 2 rack pinions from my local rack re conditioners and some bar
ground of teeth to end up with shaft to insert into bar
drilled into end of bar and drilled through sides for welding
pressed ends in both ends ready for welding
shaft with new uj's had top joint made with STD upper part with lower to fit splines
more updates end of week
i'm trying to get car somewhere near so can take to ford fair but we will have to see how things go?
timbhp is offline
Old 16-05-2011, 08:40 PM
  #210
timbhp
timbhp's Avatar
hit wrong key and put up post again so have removed and it wouldn't let me so had to type something
timbhp is offline
Old 16-05-2011, 09:38 PM
  #211
whizzisat114
Nice work
Are you extending the colum back to make up for moving the seat back?
Gonna be a nice tight fit down the side of the clutch pedal with that beefy gearbox there ay?
Old 17-05-2011, 04:26 PM
  #212
andy escos
andy escos's Avatar
Nice work
it can not be any worse than mine Dave i think i got to borrow some of LUCA,S plimsolls because my work boots do not fit that well
andy escos is offline
Old 17-05-2011, 06:32 PM
  #213
timbhp
timbhp's Avatar
Nice work
yes have repositioned column but still have adjustable column so got a bit more adjustment if reqd
and moved pedal box back,
the pedals are not that cramped with work boots on still loads of room so all should be good
timbhp is offline
Old 17-05-2011, 10:23 PM
  #214
whizzisat114
Got to be one of my favorite builds on here i really do get exited when i see you've updated. Id love to see it in the flesh one day
Old 24-05-2011, 08:29 PM
  #215
timbhp
timbhp's Avatar
small update
pedal box mounted but tunnel was wrong shape and made foot position uncomfortable so reshaped
column in place so can make up mounts
i will use rose joint for lower steering column mount so need to make mounting point so cut and folded sections ready for welding
clamped together
getting a few bits together
1300 bhp + fuel pump and filter
escort mirror image expansion tank made for me by pro alloy they are also making me another tank for other side for charge cooling system so will have one each side
tilton 3 in 1 unit to feed master cylinders
just a few of the hose ends needed for all fluids
a few stainless exhaust components so i can finish exhaust system
offered pro alloy fuel tank tray in position so can work out mounting for it
timbhp is offline
Old 24-05-2011, 08:36 PM
  #216
COLEYST200
COLEYST200's Avatar
some very nice work going into this car well done mate keep it up
COLEYST200 is offline
Old 10-07-2011, 04:47 PM
  #217
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thread / built ended. Due to ill health.
If you would like to purchase the car or any substantial parts from it please PM Tim, he is a gold member and will have for sale adverts up soon.
Thanks for viewing, thread now closed.
ekjim
17-08-2015 08:57 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
Escortdriver1
Ford Focus RS Parts for Sale.
10-08-2015 05:47 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Tim Garringtons WRC V8, Engines back in and bulk heads nearly completed! 03/05/11
