erst estate going 4wd,now on the road
#321
Managed to get a few more bits done over the last few days,the welding that needed doing to the bulkhead and tunnel is almost done now and will hopefully be done tommorrow night,i got my steering column made from an escort top half and sierra bottom half as im using an escort peddle box and column surround so it all looks standard,the only welding that will be left then is the rear end of the sills,bottom back end of the rear 1/4s and one of the rear arches has roted away aswell so got to take the kit off to weld that up aswell,i will try to get a few pics for me over the weekend and then get them up aswell
#324
Got a few more bits done over the last few weeks,ive got the carpet cut about and in place,because of the tunnel i couldnt use the original inner seat mounts so i had to modify them to fit so ive managed to get both sides modified and fitted,i had to cut the bulkhead a bit more so i could fit the heater box and blower aswell,the steering link from the column to the rack is done aswell,wiring loom is in aswell along with the seperate looms for electric windows,mirrors,central locking and heated front screen
i had to modify the loom for the extras as the loom im using is a basic loom so didnt have anything extra on it atall,ive also changed the dash plugs for my astra gte digital dash,ive been modifying the front bumper a little bit aswell as i wanted something a bit different but subtle aswell so thats coming along quite well,my favourite part that ive done so far is my cold air intake pipe for the turbo,as space under the bonnet is going to be quite tight once its all complete i think the engine bay will get quite hot so i had an idea to move the air filter,i made the pipe from bits of old rst exhaust that i had laying around so its 2 1/2 inch pipe all the way from the filter to the turbo,the airfilter now sits in front of the intercooler in the top mouth of the bumper,as the car isnt going to get used to much in bad weather it should be ok,i will get a few pics up soon
#326
ive got a few pics on my phone so will put those up,ive decided to modify a 90 spec front bumper to make it a bit deeper but still look subtle,i will get some pics up later of it almost finished
![](http://i2.photobucket.com/albums/y22/jonesymk2/IMG_0344.jpg)
![](http://i2.photobucket.com/albums/y22/jonesymk2/IMG_0345.jpg)
ive also sat the block and head in place so i can mock up a few bits and work out where everything will eventually go
![](http://i2.photobucket.com/albums/y22/jonesymk2/IMG_0346.jpg)
once the engine was in place i had the idea to mount the air filter in front of the intercooler so i used some old exhaust pipe i had laying around from an erst and cut it about to get from the turbo to the front of the cooler
![](http://i2.photobucket.com/albums/y22/jonesymk2/IMG_0348.jpg)
![](http://i2.photobucket.com/albums/y22/jonesymk2/IMG_0347.jpg)
i will get a few more pics later today when i can be bothered to go out to the garage lol
#331
will hopefully have some more pics soon,battery tray is all welded in,heater hole in the bulkhead has been modified and moved back about 1 1/2 inches,fuel filler hole has been welded up and filled,one arch has been welded up,one of the 1/4s has been patched up,aero catches have been put into the bonnet,badge recess on the bonnet has been smoothed over and is in primer,just got a small patch to put in near the fuse box hole,a small patch to put in on the inside of the n/s/r 1/4 and the n/s/r arch needs plating up then its just filler work left to do then it caan go into primer then paint hopefully in the next month or so
#335
no still not finished yet mark lol hopeully will be by about end of april if all goes well,i picked an engine up for it the other week with loom and a chipped l8 ecu,got the engine bay painted last week aswell so i can start getting it all back together and running and driving so my mates can paint it for me,pm me your number and i will txt you a few pics
#336
pm on the way mate
#338
as you can see the engine and gearbox are al in,wiring is in aswell but i just need to extend a few sections for everything to be in the correct places,im als making my own exhaust aswell as space is so tight so a cossie downpipe wont fit,the exhaust will be 3inch pipe all the way through and will finish with the big side exit pipe,ive got to get it running and driving so my mates can paint it for me then i can get it finished in the next couple of months and then start enjoying it
#348
the car now starts and runs with the ignition so at least i know that part of my wiring is all ok lol,just need to sort fuel pipes and brake pipes to the rear and get a rear prop made then its ready for paint,i will get pics soon and get them up when i get chance
#353
the exhaust is 3 inch pipe all the way through and the centre box i found at a place i used to work,i had to make it all as everything is so tight its the only way to get it how i need to clear everything and also means i could make it how i want
#355
good progress mate, would love this done to mine but couldnt bring myself to cut it up and realise i probaly dont have enough skill and incentive to finish it lol
#359
Car got painted black to start with so it would all look the same when painted red
![](http://i2.photobucket.com/albums/y22/jonesymk2/9f5a7422.jpg)
then the shell was given 3 coats of red and 3 coats of laquer
![](http://i2.photobucket.com/albums/y22/jonesymk2/8681c47d.jpg)
then the bonnet,boot and doors were painted
![](http://i2.photobucket.com/albums/y22/jonesymk2/08110592.jpg)
then the plastic parts were painted black
![](http://i2.photobucket.com/albums/y22/jonesymk2/96a19277.jpg)
![](http://i2.photobucket.com/albums/y22/jonesymk2/703f628b.jpg)
once i had everything back at home i could start fitting bits back on
![](http://i2.photobucket.com/albums/y22/jonesymk2/956e986a.jpg)
![](http://i2.photobucket.com/albums/y22/jonesymk2/9936e6f5.jpg)
