F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
Old 26-01-2012, 09:06 PM
  #801
matman
matman's Avatar
looking good kev
Old 26-01-2012, 10:09 PM
  #802
Minirotty
Lucifer II - 666
Minirotty's Avatar
My new fibreglass boot!!!!!!!!! so chuffed to have got these made now.
Thanks to Phil at PBFProducts - SportingFords trader.
Old 26-01-2012, 10:31 PM
  #803
cossiedevil
cossiedevil's Avatar
Very nice and light ,phil work is unreal best fibreglass parts i have used
Old 26-01-2012, 10:36 PM
  #804
Minirotty
Lucifer II - 666
Minirotty's Avatar
His work is perfect mate, he also made my bonnet, wouldn't use anyone else now.
Old 29-01-2012, 08:26 PM
  #805
Minirotty
Lucifer II - 666
Minirotty's Avatar
Didn't really touch L2 this weekend as its been mental and doing some stuff on van ended up in A&E lol
Put tank back together and used new alum key bolts, looks loads better now.
Old 03-03-2012, 06:36 PM
  #806
Minirotty
Lucifer II - 666
Minirotty's Avatar
Long road trip today with Kieron and Mick to collect everyones boots! Thanks to the lads for today.
Here me boot, rediculously light too!!! perfect fit.
Love it!
Old 03-03-2012, 06:45 PM
  #807
Mark_
Mark_'s Avatar
Looking good Kev,
Will you have it finished this year mate? you must be fairly close now
Old 03-03-2012, 06:59 PM
  #808
Minirotty
Lucifer II - 666
Minirotty's Avatar
I don't know mate, don't do dead lines now but I am on it lol loads of progress to come soon!
Old 03-03-2012, 08:19 PM
  #809
Minirotty
Lucifer II - 666
Minirotty's Avatar
Got my inlet today and trial fitted my 52's on, needs very minimal work and the trumpers need the usualy flating of edges to fit strate, will get on it asap.
Chuffed to bits with it.
Old 03-03-2012, 08:29 PM
  #810
COLEYST200
COLEYST200's Avatar
Stunning mate i love them
Old 03-03-2012, 08:34 PM
  #811
Zetecfiesta
Zetecfiesta's Avatar
Looking good!
Old 03-03-2012, 09:57 PM
  #812
Minirotty
Lucifer II - 666
Minirotty's Avatar
Cheers lads.
Old 04-03-2012, 12:32 PM
  #813
Minirotty
Lucifer II - 666
Minirotty's Avatar
My mate wrapped these for me, his idea! not to sure on um myself and probably wont be fitting them.
Old 04-03-2012, 08:53 PM
  #814
Minirotty
Lucifer II - 666
Minirotty's Avatar
had a fellow RS enthusiast visit my unit today to collect his boot and he said he found L2 insperational, so I decided to give myself a bit of insperation! porn pic's -
Old 04-03-2012, 09:16 PM
  #815
whizzisat114
whizzisat114's Avatar
Look's Stunning
Looking forward to more updates
Old 04-03-2012, 09:32 PM
  #816
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks bud, gona be a few weeks before more updates but will have the engine in bay next month if all goes to plan.
Old 04-03-2012, 09:45 PM
  #817
COLEYST200
COLEYST200's Avatar
Come on mate get that motor in there
Old 04-03-2012, 09:55 PM
  #818
Minirotty
Lucifer II - 666
Minirotty's Avatar
Hoping for next month mate
Got to weld in my GrpA mounts first using a mock up block and empty gear box.
Old 04-03-2012, 10:09 PM
  #819
01dwilkinson
Mk3 capri 3.0l
01dwilkinson's Avatar
Loving those pics.
Old 05-03-2012, 06:28 PM
  #820
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks bud, gives me something to look at when not able to get to unit lol
Old 05-03-2012, 08:59 PM
  #821
lanfire
lanfire's Avatar
Looks cracking mate
Old 06-03-2012, 05:02 PM
  #822
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks bud
Old 06-03-2012, 09:53 PM
  #823
Minirotty
Lucifer II - 666
Minirotty's Avatar
rear beam update -
Originally Posted by SamT
managed to do a small amount on the beam 2day, i'll finish it one day i promise lol
Milling down some spacers
snug fit
some mock up
More bits done to the bracket
cut some more tube and mitred the ends for a nice fit
bolted up
i'll try and do some more tomorrow
Old 06-03-2012, 11:25 PM
  #824
COLEYST200
COLEYST200's Avatar
Nice mod that mate
Old 07-03-2012, 03:30 PM
  #825
Minirotty
Lucifer II - 666
Minirotty's Avatar
Cheers bud, I have still to buy a suitable rear anti roll bar for it yet, I know I can purchase a sierra one that';ll fit for now that's bladed.
Idealy I'd like WRC bladed adjustable item but they aint cheap lol
Old 07-03-2012, 07:15 PM
  #826
Minirotty
Lucifer II - 666
Minirotty's Avatar
Sam's been busy again today!
got in the garage this afternoon.
Second horizontal tube cut.
diagnol cut
then same for the otherside
welded the inserts in
Welded the bracket onto the main tube
started welded the tubes on
where i left it. need to remove it from the jig so i can fully weld the tubes on and weld on the diagnols
Old 08-03-2012, 06:59 PM
  #827
Minirotty
Lucifer II - 666
Minirotty's Avatar
How good does this look off of the jig!!!
Lame update, but i welded on the left hand tube not diagnol though, was out most of the day and ran out of gas, so need a refill before i can do anymore, but its off the jig now and is looking good
tubes placed on just for pics lol
Old 08-03-2012, 07:41 PM
  #828
M K
M K's Avatar
Looking good mate,
Although as a bit of constructive criticism id recommend putting adjustable bushes in so the arms are adjustable in situ, as by the looks of yours you have to undo the rose joint completely and remove from the bracket then turn and re fit every time to adjust it,
These are the kind of thing you want to fit
Old 08-03-2012, 07:52 PM
  #829
Minirotty
Lucifer II - 666
Minirotty's Avatar
Alrite mate, those bushes you've posted up shouldn't be need on the rear beem due to it not really being made for adjustment in that area. The bushes are in situ to allow for the beem to have more independence and not static like the standard beem.
Tow in and out and camber will be achieved with shims etc on the hub face of the beem.
Where I do need those bushes you've posted up though is in my ZOO front arms, crap design of bushes he's placed in as I will need to remove the arm every time I need to adjust it and setting up will be a nightmare.
How much would 4 of those be?
Old 08-03-2012, 07:57 PM
  #830
M K
M K's Avatar
Ah i see, i didn't realise you were shimming for toe in/out, thought you were doing it off the joints and that was the reason for making it adjustable
Dewitts race and rally sell the bushes, about Ł40 each so not cheap for 4 but the best way to do things properly
Old 08-03-2012, 07:59 PM
  #831
Minirotty
Lucifer II - 666
Minirotty's Avatar
Cheers, they're now on my shopping list
Old 09-03-2012, 07:20 PM
  #832
Minirotty
Lucifer II - 666
Minirotty's Avatar
Started modifying my dash panel readyfor RaceTech2 dash and swithces, never done fibreglassing before so bare with me lol
Got to do filler work on it next.
Old 09-03-2012, 07:36 PM
  #833
andy escos
andy escos's Avatar
rear beam is looking very good ,lovely bit of welding
Old 09-03-2012, 08:22 PM
  #834
Minirotty
Lucifer II - 666
Minirotty's Avatar
That's Sam for you mate, he's ability to learn is amazing, self taught welder.
Old 11-03-2012, 10:29 PM
  #835
Minirotty
Lucifer II - 666
Minirotty's Avatar
To show how light the boot is my mate held it with one finger -
Old 11-03-2012, 10:43 PM
  #836
whizzisat114
Bloody hell that's either very light or your very bloody strong
Old 12-03-2012, 08:31 PM
  #837
Minirotty
Lucifer II - 666
Minirotty's Avatar
lol very light mate.
Old 18-03-2012, 06:50 PM
  #838
Minirotty
Lucifer II - 666
Minirotty's Avatar
Not realy an update but some chat re- me car.
Been working on a few cars up at my unit past few weeks and few mates been looking over L2.
One tuck the piss cause I have cotten sheets under car cover (Ginge) lol and another who paints told me I needs to get a good layer of protection on to the paint even though it's in storage because the covers were putting more and more swirl marks into the paint due to them being taken on and off.
So popped to Halfords today lol for polish! got the three stage Maguires stuff and went up and gave it a wipe over after taking family out for dinner.
Hers is a photo from other day showing paint not looking to great -
Now heres some from today after the three stages -
Only did the front and the passenger side, when I tried to put the sheets and car cover back on on my own it was a nightmare as it all kept sliding off as the paints that smooth
Old 18-03-2012, 07:00 PM
  #839
jonfoc
jonfoc's Avatar
Stunning Kev, now get it finished!!!!
Old 18-03-2012, 07:42 PM
  #840
Minirotty
Lucifer II - 666
Minirotty's Avatar
It'll get there Jon, it's a project, these things take time lol
Quick Reply: F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
