My Escort Cosworth, now on the road again ...
Old 27-12-2007, 09:00 PM
  #121
NEEDFORSPEED
NEEDFORSPEED's Avatar
Originally Posted by DENNIS
Originally Posted by NEEDFORSPEED
clutch please sounds too good to be true!!lol
does this sound rite to you for the coil dwell info?
Batt Voltage Dwell time
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
16 Volt 3.0 ms i presume yours will be the same aswel so may of saved you a job
look`s good, but i will check to make sure ... just need to find five minutes
as for the clutch ...
a preview...
unfortunately this has proven to be very expensive, as i have had to make major changes to the flywheel,gear box and operating mechanism and the clutch alone retails at £1000.00
but for the results, i feel it`s worth it and should be a fit and forget item.
i now have all the bits back and have got as far as fitting the crank with the ARP main stud kit and modding the block to accept the new knock sensor where it should be !!!
pics soon ..
thanks alot appreciate it. clutch looks good. expensive but worth every penny if it works out! good work! you should offer it as a conversion if everythin goes to plan
Old 27-12-2007, 09:08 PM
  #122
rapidcossie
rapidcossie's Avatar
1000 quid plus fitting and fannying about for a light clutch?!
Give me a £350 quid 6 paddle anyday
Old 27-12-2007, 09:31 PM
  #123
DENNIS
DENNIS's Avatar
its not the weight, its the capabilities and driveability..
i have killed 3 AP 6 paddles now and i am sick of throwing money at clutches.. ( 3 x £350.... £1050... ) i should of done it ages ago !!
i know quite a few use the AP / Alcon 6, but even AP Racing only rate them up to 310lfb...
this is rated to 800 BHP and its related torque,... but with out the horrid " judder, snatch you get with most " performance " clutches...
Old 27-12-2007, 09:33 PM
  #124
NEEDFORSPEED
trouble free clutch, how long will a 6 paddle last if your launching all the time? mine didnt last that long at all and slipped toward the end without going for a twin plate theres no other options for cossies
Old 27-12-2007, 09:34 PM
  #125
NEEDFORSPEED
oops beat me to it lol
Old 27-12-2007, 09:35 PM
  #126
DENNIS
DENNIS's Avatar
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
a preview...
pics soon ..
i have keep`ed all the tech specs for reference, but i would assume most would see it as a " pointless luxury " .. but i could get them made if there was enough interest...
Old 27-12-2007, 09:38 PM
  #127
DENNIS
DENNIS's Avatar
PS ( its a twin plate )
Old 27-12-2007, 09:53 PM
  #128
NEEDFORSPEED
il sit back down! i meant tripple plate lol
Old 28-12-2007, 08:36 PM
  #129
DENNIS
DENNIS's Avatar
lol.. i know that's what you meant
Old 28-12-2007, 08:46 PM
  #130
DENNIS
DENNIS's Avatar
OK update`s ...
i have had some free time today, so i got some done ...
i have now fitted the main cap studs.
and checked the clearances are all OK ..
so the crank has found its home again..
all going back together..
my new Knock sensor set up..
just waiting to get the time to finish the engine build.. before i get stuck in with the new ECU / loom set up..
Old 28-12-2007, 09:11 PM
  #131
rapidcossie
fair point mate....teaches me to jump in
Old 28-12-2007, 09:13 PM
  #132
rapidcossie
what kind of knock detection you using?
Old 28-12-2007, 09:21 PM
  #133
zetecturbo
zetecturbo's Avatar
fair play mate .shows you know what ur doing .no matter what you do ther will always be negative comments from someone.carryon regaurdless .its ur car at the end of the day
Old 28-12-2007, 10:10 PM
  #134
DENNIS
DENNIS's Avatar
was a fair comment really...
just trying to find a better way .. it may look expensive on the front of it, but it will out weigh the cost if it lives up to its name.. ( i am sure it will !! )
as for the knock control, i will be using the autronics knock functions..
Old 28-12-2007, 10:13 PM
  #135
DENNIS
DENNIS's Avatar
Old 28-12-2007, 10:21 PM
  #136
rapidcossie
DENNIS
What needs to be added to a SM4 for knock control?
Old 29-12-2007, 11:31 AM
  #137
Dan
Dan's Avatar
Engine looks great mate!
Have you got that number for the electroplating?
Old 29-12-2007, 08:57 PM
  #138
DENNIS
DENNIS's Avatar
DENNIS
PM sent ..
Old 29-12-2007, 08:58 PM
  #139
DENNIS
DENNIS's Avatar
i will dig it out for you..
Old 29-12-2007, 09:00 PM
  #140
DENNIS
DENNIS's Avatar
OK ....... i finished building the engine today, after all my testing and checks, its all how i was expecting ...
it has taken some time changing the turbo core angles to suit the new exhaust manifold and have had to make some changes to run this and all the other items i will be using..
But there's still plenty to do ..
as soon as i have the manifold polished, i will be connecting and changing all the wiring to my new spec..
The bad news is ... i have decided NOT to use the Anti Lag on this engine
Old 29-12-2007, 09:18 PM
  #141
NEEDFORSPEED
please can you pm me about the knock control aswel please!
Old 30-12-2007, 09:27 AM
  #142
M K
M K's Avatar
good work fella,
Old 30-12-2007, 05:33 PM
  #143
Bullett
Bullett's Avatar
some good work there dennis you on time to get her out at the fornt and the shows this year?
Old 30-12-2007, 06:01 PM
  #144
DENNIS
DENNIS's Avatar
yes all is looking good, i hope to have it all back in and running within the next few weeks ready for running in, when i have finished mapping it, i hope to try and get some testing done at Santa pod early next year..
some more pics...
Old 30-12-2007, 08:42 PM
  #145
rapidcossie
awesome looking engine
Old 30-12-2007, 08:51 PM
  #146
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Now you're talking - love the clutch .
What mods did you have to do to fit it, and how does the HKS one differ from the normal AP twin plate?
Old 30-12-2007, 08:55 PM
  #147
TimC
TimC's Avatar
Thats looks soooooooo clean
Old 30-12-2007, 09:49 PM
  #148
NEEDFORSPEED
looks proper mate! yes very clean, love the workshop its how they should all be! unlike me working in a home garage withy leaves blowing about you must be chuffed with it
Old 30-12-2007, 10:22 PM
  #149
DENNIS
DENNIS's Avatar
Hi mike, it is completely different from the AP clutches , i have had to start from scratch with the flywheel as it is mounted on studs with locating blocks rather than bolts, & the PCD is miles off from the ford PCD. the complete operating side is different and i have had to make new clutch arms and mod the gear box as well..
a lot of work i know, but i feel it will be worth while...
Old 30-12-2007, 10:29 PM
  #150
DENNIS
DENNIS's Avatar
Thanks i am happy with the way things are going with it. and i must admit, i am very fussy when it comes to cleanliness... if it hadn't show`n
Old 31-12-2007, 07:03 AM
  #151
Bullett
Bullett's Avatar
that engine looks the daddy! you must be well proud dennis. im rather jealous
Old 31-12-2007, 10:27 AM
  #152
redrsmk5
redrsmk5's Avatar
Congratulations so far Dennis Your car could change the way that escort cosworths are modified in the future. I love reading your updates and the engine pictures are truly stunning mate, seems a shame to put that in the car ....it belongs in a gallery with other works of art
Old 31-12-2007, 10:36 AM
  #153
NEEDFORSPEED
do you not fancy a wrc breather for it?
Old 01-01-2008, 11:20 AM
  #154
DENNIS
DENNIS's Avatar
looks nice but the breather i have is up to the task..
where dose it go ??
Old 01-01-2008, 11:28 AM
  #155
DENNIS
DENNIS's Avatar
Bullett
redrsmk5
NEEDFORSPEED
AquariousRS
Thank`s, i was going to put a glass top on it and put it in the living room as a table, but the other half wont let me .... don`t know why
Old 01-01-2008, 12:04 PM
  #156
NEEDFORSPEED
Bullett
redrsmk5
NEEDFORSPEED
AquariousRS
me neither!! it bolts to the side of the block and sits in where the firetrap normally goes
Old 01-01-2008, 12:08 PM
  #157
DENNIS
DENNIS's Avatar
interesting... where did you get it from ??
Old 01-01-2008, 12:35 PM
  #158
NEEDFORSPEED
i had 3 made up. by the same people that made mike rainbirds (well theyre exactly the same) i just think they look neater and out of the way not cheap tho and stil need fittings aswel
Old 01-01-2008, 05:37 PM
  #159
Mike Rainbird
Caraholic
Pictures of this would be most interesting as it sounds unique (compared to the other bits ) .
Old 01-01-2008, 06:05 PM
  #160
Dan
Dan's Avatar
Engine looks fantastic mate! Any luck with that telephone number?
Quick Reply: My Escort Cosworth, now on the road again ...
