Underside Resto advice - your input needed....
Old Dec 18, 2006 | 10:22 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Default Underside Resto advice - your input needed....
Looking for info on how to do an underside resto:
What stuff i use and in what order?
Steam clean, degrease, Stonechip, paint, krust, waxoyl (is it really needed after a resto)
Any tools that are best to use (however im doing it on a budget!), and any pointers/hints wouldn't go a miss.
I fancy tidying up the underside of my fiesta this winter.
Old Dec 19, 2006 | 10:15 PM
Turbo Pez's Avatar
Turbo Pez
I'm gona be doing the same to my turbo next year, Hopefully! all im gona do is wire brush on angle grinder removed all old sealer and paint, fully stonechip it then paint with hammerite a few times!
Gonna do it in sections tho, back, middle then front!!
Mine's already stripped underneath so should make it easlier, plus im looking at making a bracket to fit on the hubs along 1 side which will allow me to turn car nearly on its side!
Hope this helps
Old Dec 20, 2006 | 12:40 PM
AGAR-COSWORTH
Redumbdancy
Cheers for the advice - hub idea sounds good but i'd be worried of tipping my car over on its roof
Old Dec 20, 2006 | 02:48 PM
markc's Avatar
markc
wire brush attachment for grinder cheapest and very effective
remove ALL RUST
acid etch primer
hammerite (so the panels are sealed)
then stone chip or tetra (think thats how u spell it lol) under seal (the propper sprayed stuff not out of the tin)
remember to make sure u do it in a dry enviroment
Old Dec 20, 2006 | 06:33 PM
AGAR-COSWORTH
Redumbdancy
Cheers guys - looks like i'll be buying a heater for the garage then
Old Dec 20, 2006 | 10:09 PM
Maximum Hustler's Avatar
Maximum Hustler
Depends if its been undersealed before. Mine had tonnes of underseale on it when i got it so i found the best way was to soften it up with a heat gun then a scrape it off. After you've done any welding that needs doing then a soft pad on the angle grinder will get rid of any surface rust followed by a wire wheel on the drill for hard to reach places. I then used red oxide primer or etch primer will do followed by stonechip, then primer, and then paint or hamerite.
Check my resto as ive not long finished the underside
Old Dec 21, 2006 | 01:08 AM
AGAR-COSWORTH
Redumbdancy
Thanks for that
Old Dec 21, 2006 | 04:01 PM
Turbo Pez's Avatar
Turbo Pez
Hope this helps
I forgot red oxide before stonechip!
Old Dec 21, 2006 | 04:12 PM
bassboy's Avatar
bassboy
does stone chip go first or last?
bassboy
Old Dec 21, 2006 | 05:30 PM
AGAR-COSWORTH
Redumbdancy
Stone chip first it seems.
Oh meant to ask - where do you guys get all your paint/stonechip supplies from? Anywhere decent online, - what are the brands to buy?
Old Dec 21, 2006 | 09:28 PM
JezSierra's Avatar
JezSierra
happy with that
use 3m products if you can mate,pricey,but the best imo
Old Dec 21, 2006 | 09:43 PM
bassboy's Avatar
bassboy
jez...where from mate
bassboy
Old Dec 21, 2006 | 09:54 PM
Turbo Pez's Avatar
Turbo Pez
Primer (red oxide, etc) then stone chip then paint (hammerite etc)
Old Dec 23, 2006 | 08:34 AM
JezSierra's Avatar
JezSierra
happy with that
well we use a company called hex holdings,but im sure you would be able to get the meterials from a paint product supplier local to you
Old Dec 23, 2006 | 07:13 PM
AGAR-COSWORTH
Redumbdancy
Cheers again guys
Old Dec 23, 2006 | 07:14 PM
AGAR-COSWORTH
Redumbdancy
Oh - how much of each material/paint is needed for an underside - escort/fiesta size?
Old Dec 24, 2006 | 08:03 AM
JezSierra's Avatar
JezSierra
happy with that
you wouldnt need much more than 0.5 of a litre of paint to paint underneath a car,are you going to laquar underneath aswell?then about 0.6 on laquar,to give it a good and long lasting finish
Old Dec 24, 2006 | 11:04 AM
AGAR-COSWORTH
Redumbdancy
I think i will laquer it but are these volumes of paint for painting using a spray gun, or brush and roller?
Old Dec 24, 2006 | 11:15 AM
Rossco's Avatar
Rossco
IMO Waxoyl looks a bit messy once you spray it everywere but it does stop the rust and is needed
Old Dec 24, 2006 | 12:07 PM
JezSierra's Avatar
JezSierra
happy with that
use a spray gun if poss mate,well least for the laquar,and the volumes are for using a spray gun
Old Dec 24, 2006 | 12:12 PM
AGAR-COSWORTH
Redumbdancy
JezSierra - cheers for all the advice
Old Dec 24, 2006 | 12:14 PM
JezSierra's Avatar
JezSierra
happy with that
no probs mate,liking what your doing to your car alot mate,keep the updates up
mk3ste
Oct 17, 2021 10:09 AM
boeb
Jan 9, 2020 05:11 AM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
