E5 MDS 4x4 saph re-build . . . for sale . . .
#361
cheers! just the reliability thing really. all the 'big power cars' seem to be using them now so theyre pretty well proven. didnt even get to drive with the quaife in!!
#364
Originally Posted by Shorty
As i said yesterday Mark, gonna be a weapon mate
Cheers for meeting up too, them looms look nice too
#365
Nahh its cool mate, i had my mate with me, so we just sat there chatting random bollox as usual
#366
out with the old in with the new!!
the only difference between 3.6 and 3.9 is 1 tooth on the pinion?!
Do the same with the 3.9 wheel and 3.9 pinion.
That will give you the ratios if you have any doubt.
#368
ordered a new peter g fanimold today from his uk distributor street racers cannot wait to get it he said about 4 weeks to make it quality looks unreal! not sure wether to leave it as it is or get it ceramic coated with front pipe?!!
#369
got these today the quality is unreal!!
also dropped my box off with marco polo yesterday at his house. what a bloody nice genuine bloke! offered a bru and a biscuit as soon as we climbed thru the front window!!lol who needs front door keys anyway! really knew his stuff about transmission / suspension. should be back in a few weeks!
#378
on a serious note andy you actually will have to lol!! marco just called said there wasnt even 1nm torque on the centre vc! which means it was rear wheel drive with a lot of drag!
#379
my nos man! real fast and furious now!!
seriously tho can control it with the motec along with the water injection so no need for a progressive controller or such like. just needs tib to fill it up for me! + a lick of paint and some nice fittings!
#380
got my vems wideband guage thanks apt! quick friendly service! this things got so many features, once plugged into laptop it uses the same program as i used to use with my megasquirt (megatune) so am familiar with that, has different narrow or wideband output which i can use with the motec, datalogging loads of different inputs also etc etc and i also went for the extra thermocouple so will read egt's aswel brilliant bit of kit
pickin my box and diff up sat morning! wahoo!
#384
been at my bros this wkend and did a bit on my car today. something creative at last! measured up and cut (somehow managed to completely f*ck up the measurements mite i add )just needs a plate makeing for the bottom where they meet and welding up but you get the jist
also brackets for the nos bottle
drilled all the way through just need some long bolts
#386
Yeti Racing
cheers mate!
now got these
that are in this
and also diff fitted and aligned properly
massive thanks to maro & barra great helpfull service
cheers mate!
now got these
that are in this
#387
Hi mark
no worrys , sorry for delay any probs/advise you got my number
dont forget run it in about 300 road miles and use decent 75/90 fully synthetic oil in both parts of the box , use the gears to slow you down aswell while running in
in the diff use decent 80w/140w fully synthetic oil
good luck with the stuff mate
cheers marco
p.s keep up the good work
cheers marco
#389
defo one less thing to worry about. yep cheers gona run engine in for a good 700 miles anyway. will phone the oil man tomo how much oil do i need alltogether for f + r diffs and box? save me lookin tomo. cheers
#396
got a load of pnumatic push fittings with 6mm nylon tube for boost control etc etc just nead to stick in hot water to push on map sensor for the fittings in inlet. will look much neater and reliable than having vac pipe everywhere and costs fuck all. its the little bits that count!
#399
small update done more on the inlet just needs sand blasting, a fitting for the external anti lag valve and paint
shaped all the inside etc with dye grinder
plenum spacer welded on
wheels been acid dipped and my dad re painted them after the last lad fucked them up! look spot on now and a much better colour. just gona leave them for a wk then fit tires
got all the bolts matched up from under car etc to allen head bolts and will paint them apropriate colours will look much better
and a bit pissed about these 'collins' engine mounts got discount tho 100quid delivered but look EXACTLY the same as the cheap ones of ebay ie no collins printed into them or anything!
#400
getting somewhere now. done a few hours today
dads painted the box for me gona put a bit of laquer on so it washes off easier. drilled 2 holes for the slave cylinder pipes to go through. wil make a blank for where the arm used to go through next wk so no shit can get in.
sand blasted the inlet and rocker cover again as i wasnt happy with it.
cut the pipe to length for the fuel reg warmed pipe up and pushed on. will paint plenum in wk. then hopefully next sat get the engine box and diff built up.
as im using a wrc breather i didnt need the breather on rocker cover so made a 'bung' on the lathe and knocked that in and smoothed over.
i wander once its all built up how much it would move if i tried to fire it up!! really wana hear it now! want to get some real work done now rather than half an hour here and there.
