My 3dr Cosworth project updated (16.01.12)*
#841
I believe they go straight in with no tunnel mods, just have to make a custom gearbox mount, but only where it fits to the gearbox.
#842
Gav,
I did miss it yes bud, it's my age you see mate, once you're in your 40s you have selective memory loss....
Stunning box that though mate, no breaking that fooker @ Pod now...
#843
Hopefully won't break it mate, if they can take the power like Rod's running i should see no problem with it on my car.......time will tell, lol
Need to get the car running before i think about Santa Pod again but i will be running it as i really want to get a low 11 maybe even high 10s run out of the car.
#845
Best terminal with only 3 runs really was 120mph at 1.7bar boost so at 2.2bar once its mapped and with 100bhp of gas i think it should be around 135mph+ ???
#849
Cheers mate and thank you for the info on CYC forum
Little more done over the weekend, although looks like 10mins work was actually about 4hrs
Chiseled out the original seam sealer in the engine bay as it had cracked and looked messy, after a quick clean i resealed it
Cleaned and fitted the floor bungs
Started to clean the rear arch up
Got bored after a hr and a half so moved to the front
That is pretty much spotless bar the original rubber sealer....I have bought the 3m bag sealer to do the whole floor but i want to know if you are supposed to clean it to bare metal before doing that or if it is ok to leave it as i have done????
#851
Its such a boring and soul destroying job mate....will do some more wednesday as busy tomorrow day but hoping that a good week will see it cleaned up ready for sealant.
Do you know if it need to go bare though as the packet just says clean and free from grease and oil??
#855
#856
Only the cock up with the hydraulic clutch positioning that i showed you before......
Need to get the hole drilled in the correct place first and then weld up the wrong one as it will be a mission to cut the hole through the welding if done before, need to sort a rose joint out and sort the clutch pedal out so i can mark the bulk head like you said you did with yours.
#859
what you using to remove the original sealer Gav?
when i did mine i used a big angle grinder with twisted knot wire wheels - the sealer came off soooo easy!
id do it bare before recovering - like you say you want to do it right
Keep up the good work.
Mart.
Mart.
#860
Cheers Paul
Thanks mate, using the knotted wire wheel the same as you mate on the grinder, just seems to take a while.
Using a small at the minute as its all they had will try to get the next size up and see how that goes..
#866
I took mine down to bare metal then etch primed it.As iv,e said before,it,s a f*cking terrible job but you are only going to do it once and the results are unbelievable.
Good luck.
Good luck.
#869
Is that an offer to help Gaz?? lol
Erm.....can't see it going this year, lol. Don't think my little caster wheels will servive the 80mile journey there
I don't mind doing the work as long as i can see some progress, nothing worse than spending a day on it to look at it and think nothing has really been done.
#870
Few more hrs spent on it today..
Black area is just factory paint i believe so no point removing
2 arches and 1 grinder down
Could also do with a smaller atachment to get into the smaller area's so will have to pop to Marchine Mart and see what they have.
#873
Not sure about that but will get the other 2 arches done and make a start on the floor, just need to go Machine Mart and get some more wire wheels as well
#876
