Kaliber Cossie Gets a re-build , and not before time !
#42
Originally Posted by RickDraper
![](https://img.photobucket.com/albums/0703/TonyRyan/morrrre006e.jpg)
Can you tell me what pumps etc are seen in that pic? I need to sort out the fueling side of my car and that looks like a purposeful setup.
Its an ATL swirl pot about 1 1/2 - 2 litres , 2 x Facet red top low pressure pumps , 2 x Bosch high pressure pumps feeding into seperate filters and seperate lines forward to the fuel rails . It looks like 1 x 044 or 979 GpA pump and a std cosworth pump on the top that wasn't connected , twin 044's is my recommendation if youre using 8 injectors anyway .
Hope that helps .
#43
Hi Tony,
Rebuild looks great i am sure i have seen this car in performance ford or fast ford a few years back along with a red brooklands one as well?
So the 2 facet red top pumps are the lift pumps from the tank to the swirl pot? I take it your tank has 2 pipes to be able to plumb these in? On my tank i only have one pipe from the tank so how would i be best going about plumbing in a swirl pot and lift pump?
#46
Got this lot to tackle next then ....
![](https://img.photobucket.com/albums/0703/TonyRyan/e-baybits005e.jpg)
![](https://img.photobucket.com/albums/0703/TonyRyan/e-baybits008e.jpg)
Check out the exhaust tunnel for the 4" side exit !!
This large lump in the centre is for the re-located gearbox , its back about 6" in total and means the trans tunnel has been enlarged quite a bit .
![](https://img.photobucket.com/albums/0703/TonyRyan/e-baybits007e.jpg)
y4n
17-08-2015 12:12 PM
CabrioTurbo
01-08-2015 11:04 AM
