Work STILL in progress (s2) - back from paint...
Old Jul 2, 2009 | 08:01 PM
  #161
StephenC's Avatar
StephenC
..BS Motorsport..
Originally Posted by RSGARETHW
tis indeed
Old Jul 2, 2009 | 09:45 PM
  #162
Good to see you getting it back together
Old Jul 13, 2009 | 08:10 PM
  #163
StephenC's Avatar
StephenC
..BS Motorsport..
Both rears built up now, got brake lines to go on but ive got a bit of rot in one of the floors that is getting sorted so I can finish running the lines around that area. If anyone ever asks the question powerflex or deflex take a look at this
These are the deflex fitted, thanks to stevenbm for pointing out that I still had the old bush casings still in the arms, just shows how shite a fit they really are.
I was sold these as powerflex which they clearly arent, got a refund and bought the real deal, there was no chance these would go in with the old casings present, very nice snug fit
I really wouldnt want the deflex on the back of my car after seeing the difference.
This is the engine bay at the moment, ive split the engine loom from the car loom and removed things like spot lamp wiring that I wont be using, reloomed the car loom now. Just building a seperate engine loom thats going to plug in through the bulkhead as im having the ecus inside the car now. Im sticking MFI as the car was spot on for me before I took it off the road, doesnt need any more power, just needs driving properly The carbon rocker is coming off as is the spec-r breather.
The paint has lasted well considering it hasnt been touched in 4 years
One more of the rear
Its not mint under there but its certainly mechanically strong and sound. Sills are split mint, the floor is just iffy where some tvvat has jacked it up in the wrong place.
Got some plastic windows to go in. Plan is to get the car running again, put a few hundred track miles on her back, iron out any issues then come winter take her back off the road and full weld in cage to go in and roof replaced with a carbon one. Id do it now but I just want to get it to a working stage without starting too many things and getting nothing done.
thanks for looking
Old Jul 14, 2009 | 06:16 AM
  #164
jonny s2's Avatar
jonny s2
sounds like a plan,i know were your coming from with getting it on the road and enjoying it,mines been off road for time now bassically cause i just dont stop having new ideas and adding,will be ready soon tho and do like you sort it in winter,how much power do you have also wots the spec of the engine
Old Jul 14, 2009 | 04:46 PM
  #165
StephenC's Avatar
StephenC
..BS Motorsport..
engine is NMS stage 5 engine, im hoping with the new loom in and most sensors been new it should be reasonably reliable (the engine anyway) gearbox is just a rebuilt standard affair reckon around 260bhp
Old Jul 14, 2009 | 05:00 PM
  #166
stevenebm's Avatar
stevenebm
post whore
looking good mate.glad you got the bushes sorted.powerflex are so much better.anybody with deflex id say chuck em and spend that bit extra.well worth it.
Old Jul 30, 2009 | 10:46 PM
  #167
bigryrs's Avatar
bigryrs
RSHoleinator
Any photos of the rocker cover mate
Old Jul 31, 2009 | 06:03 AM
  #168
StephenC's Avatar
StephenC
..BS Motorsport..
Its at the machine shop at the moment, having to get a few of the fins milled down to allow my reverse charge carrier to sit properly. Trouble with mates rates is that it takes forever to get things back! Picking it up monday and getting it coated then.
Old Jul 31, 2009 | 10:09 PM
  #169
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
very nice motor that
Old Aug 1, 2009 | 04:45 PM
  #170
jamieRST's Avatar
jamieRST
nice m8,love the carbon rocker
Old Aug 15, 2009 | 03:34 PM
  #171
StephenC's Avatar
StephenC
..BS Motorsport..
Been camping last week so couldnt get on the old girl. Cheers for the comments
got rocker cover back and just tried it with the reverse carrier, its close but alot more substanial than the carbon fibre one, was always shitting myself with the carbon incase it got scratched or damaged. Just a pic of how it will look
Off to get vapour blasted then coated, not sure on final colour but I reckon it will be black. Just waiting on mate to weld floor up then my new petrol tank can go in and I can finish clipping brake lines round. Had tank done riviera blue but havent any pics at moment. Know its dragging on but she will be done this year
Old Aug 15, 2009 | 05:06 PM
  #172
jonnyrsturbo
nice
Old Sep 4, 2009 | 03:55 PM
  #173
StephenC's Avatar
StephenC
..BS Motorsport..
Got rocker and charge carrier back, can get them fitted proper now and get the carbon one repaired and up for sale
Old Sep 4, 2009 | 04:05 PM
  #174
jonny s2's Avatar
jonny s2
looking good steven,where did you get the reverse cross over pipe from?
Old Sep 4, 2009 | 04:22 PM
  #175
StephenC's Avatar
StephenC
..BS Motorsport..
Got it from NMS when I got the double cossie cooler, it came with mounting lugs either side but Ive took them off as I dont use them, the pipework keeps it more than in place, looks a bit neater. cheers
Old Sep 18, 2009 | 04:31 PM
  #176
StephenC's Avatar
StephenC
..BS Motorsport..
Got a few hours on it today, polished the header tank up as it was covered in 5 years of shit, fitted rocker with new rubber gasket, fitted charge carrier but a bit concerned about the step where it meets the throttle housing, its a smooth transition but it never used to be like that, it must be the rocker that is deeper than the carbon one was, reckon it should be okay though. Got my head round wiring loom now so just need to get cracked on with that. Got Bailey Oil breather to fit and get rid of that shite spec-r one.
looks a bot messy at moment but will soon come together, got some studs for turbo on way so once I get them can build all that back up and get radiator fitted and whatnot
Old Sep 18, 2009 | 04:40 PM
  #177
jonny s2's Avatar
jonny s2
looks real smart that
Old Sep 19, 2009 | 11:32 PM
  #178
Nice project i like it alot.
Old Oct 9, 2009 | 03:33 PM
  #179
jonny s2's Avatar
jonny s2
any more updates mate cant wait to see
Old Oct 9, 2009 | 05:11 PM
  #180
StephenC's Avatar
StephenC
..BS Motorsport..
Just got another few hours on the wiring loom then it can go in, want to get all the turbo and radiators etc back on then
Old Oct 9, 2009 | 05:26 PM
  #181
jonny s2's Avatar
jonny s2
good stuff bud keep at it
Old Oct 15, 2009 | 08:01 PM
  #182
jaiscossie's Avatar
jaiscossie
Love the car and all you have done to it mate.
Old May 9, 2010 | 09:46 AM
  #183
jonny s2's Avatar
jonny s2
come on stephen dont lose hope
rent a lock up or something, and put some cossie management or something on it,its a big waste just sitting there
Old May 9, 2010 | 02:07 PM
  #184
StephenC's Avatar
StephenC
..BS Motorsport..
tell me about it, its so close yet so far, back end is on underneath just needs torquing up, fuel tank putting back on then thats back done. Front end just needs turbo putting back on and rad re-fitting then either a new engine loom (mines only half built) or new management altogether. Not a lot of work really but I just get no time at all on it now, in fact if it was running I doubt Id have time to drive it. Really unsure this time, thought about it in past but its been easy to just leave it at the old mans place, now thats going Ive either got to get it running and use it or sell it. Id rent a lock up but Id be constantly shitting myself about it been broken in to etc, I work away all week and coming home to that wouldnt be fun. hmmmm, not sure.
Old May 9, 2010 | 02:15 PM
  #185
jonny s2's Avatar
jonny s2
if you were closer we could of got a lock up between us,im sure you will get something sorted,it will be sad to see it broken after all that buftyness and hard work. im in 2 minds what to do with my moonstone escort as ive just got too many cars LOL
Old May 9, 2010 | 10:23 PM
  #186
fezzajsy's Avatar
fezzajsy
get it sorted mate
Old Nov 9, 2010 | 09:33 PM
  #187
StephenC's Avatar
StephenC
..BS Motorsport..
When I took the carpet out the sound deadening underneath was soaking wet, a couple of years of that has took its toll on certain parts of the floor. Pics show it better. Weve got floor repair panels to go in that are full length of the car so should be a nice neat job when done, look much better than patching it up. Heres tonights work thanks to Charlie
before
after
still looking good
Old Nov 9, 2010 | 09:55 PM
  #188
Gav Diamond's Avatar
Gav Diamond
Great project, keep up the good work mate
Old Nov 9, 2010 | 10:00 PM
  #189
Old Jan 8, 2011 | 05:17 PM
  #190
StephenC's Avatar
StephenC
..BS Motorsport..
Plenty of progress from Charlie this week, asked him to do a few custom bits too and he's made it look easy found a few suprises on the way but nothing worrying, just little patches here and there; she has been sat outside for 7 years without moving so pretty amazing really. Once jesus works his magic on the paint its in with a full new loom and get it down to NMS for cossie management and hopefully a setup and drive home!!! Probably a good while away yet but at least theres nothing in the way now, I can crack on and get it built.
thanks for looking
Old Jan 8, 2011 | 06:20 PM
  #191
Blimey not much going back in the bay then
Old Jan 8, 2011 | 06:44 PM
  #192
StephenC's Avatar
StephenC
..BS Motorsport..
looking that way! I just love the look of a clean minimal bay, as its going to be 99.9% track car I reckon I'll be able to live with having no heater.
Old Jan 8, 2011 | 07:03 PM
  #193
jonny s2's Avatar
jonny s2
its the way forward mate, good to see some progress at last
watch out for the moody looking grey one's tho
Old Jan 8, 2011 | 07:06 PM
  #194
StephenC's Avatar
StephenC
..BS Motorsport..
Its coming to 7 years since I drove this car!! Seriously looking forward to clearing the cobwebs!! Im putting a rear view mirror in it so should be able to keep track of the murky grey ones
Old Jan 8, 2011 | 07:13 PM
  #195
jonny s2's Avatar
jonny s2
liking the enthusiasm im just adding the WON system to mine which will follow with a decent box hopefully, so you'll be needing a little more than a rear view mirror
Old Jan 8, 2011 | 07:25 PM
  #196
mhs's Avatar
mhs
Nice job
Old Jan 8, 2011 | 10:18 PM
  #197
StephenC's Avatar
StephenC
..BS Motorsport..
I'll wait in the pits til the gas runs out box is worrying me but Im hoping I'll be just within its limits
Old Jan 9, 2011 | 09:06 AM
  #198
fezzajsy's Avatar
fezzajsy
Old Jan 9, 2011 | 10:24 AM
  #199
jonny s2's Avatar
jonny s2
you will be ok mate, im gunna run my box as is for now, if it breaks it breaks
yours is looking good anyways pal, and im quite pleased to see so much progress and extra thought gone into the ol beantin,
Old Jan 13, 2011 | 10:29 PM
  #200
StephenC's Avatar
StephenC
..BS Motorsport..
