Wideband lambda. 2 outputs?
Old Jan 30, 2006 | 09:53 PM
Jim Galbally's Avatar
Jim Galbally
Default Wideband lambda. 2 outputs?
I'm thinking of getting an XD-1 kit for my car, wideband lambda + gauge.
http://cgi.ebay.co.uk/Innovate-XD-1-...QQcmdZViewItem
however i'm curious as to if i can wire the LM-1 up to both my ECU and the gauge
my ecu support wideband lamda, so i wouldnt wnt to use the narrowband emulated bit of it, i'd want both the gauge AND the ecu to both get the wideband output.
is this possible? can you just run the signal wire to both devices, or does it cause the signal to be wrong?
Old Jan 30, 2006 | 10:13 PM
M Brian's Avatar
M Brian
not sure on the answer but im intrigued aswell.
out of interest jim what Ecu you going for?
Old Jan 31, 2006 | 12:03 AM
mrviper's Avatar
mrviper
i think the brown wire goes to your signal wire on your ecu
Old Jan 31, 2006 | 08:23 AM
foreigneRS's Avatar
foreigneRS
Testing the future
if both things have a high enough input resistance, then the output will not be significantly reduced.
generally, yes it can be done.
Old Jan 31, 2006 | 12:16 PM
Jim Galbally
so it shold be ok just to split the signal wire then?
Old Jan 31, 2006 | 02:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
should be, but don't rely on it until you've tested it.
couldn't get hold of you on sunday evening jim. the number i had for you was wrong, and the second number just kept ringing. i'll try again sometime, busy for a while now.
Old Jan 31, 2006 | 02:33 PM
Jim Galbally
i've PM'd you my numbers again
are you going to the PE rolling road day on sat?
Old Jan 31, 2006 | 04:19 PM
M Brian's Avatar
M Brian
oi moody answer my question
Old Jan 31, 2006 | 04:33 PM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks jim, got it right now. damn dyslexia fucking tourettes got the bloody lot me
not available saturday sadly, would've been good and not too far away. thinking about it, i will be driving more or less right past so it could be possible. not sure i've got space in the boot though. i'll think about it and let you know by friday night.
Old Jan 31, 2006 | 06:46 PM
Jim Galbally
melv, i've got an emerald K3 ecu
Old Jan 31, 2006 | 07:36 PM
M Brian's Avatar
M Brian
ah
ive got the data sheets on them from the autosport show on my desk at the mo. reckons 550+vat for the loom ecu software etc
have you played with the software at all?
Old Jan 31, 2006 | 07:54 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Jim - I have one of these.
I may be wrong, so don't quote me on this, but I think you can use the kit to send info to two devices - ie the guage and your ECU.
This bit in the ad on ebay (if I'm reading correctly) seems to back this up:
It features the same industry-leading patented digital circuit found in the proven LM-1, and includes digital in & out, plus two programmable analogue outputs. The LC-1 can connect directly to the XD-1 for a standalone AFR gauge, and is ideal for using with an ECU
I don't think you need to 'spit' the signal so to speak - I think you can use one of those outputs or the digital out.
Of course I'm prob hopelessly wrong , but that's how I think it works.
Simon
Old Feb 1, 2006 | 10:54 AM
Jim Galbally
sib, i THINK that means it has a wideband output (for gauge) and a narrowband output (for ECU) but i want wideband on both
Old Feb 1, 2006 | 11:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that's not how that quote reads to me jim
Old Feb 1, 2006 | 09:32 PM
Si B's Avatar
Si B
Damn, I'm not sure either way. May be worth talking to whoever supplied it - I think GGR iirc sell these as well so may be able to help.
Me, I'm stuck now as I'm not using mine to be so clever as yours - mine is for tune up / diagnostics only. ECU is just a humble L8!
If you do find out let us know what the score is!
Simon
Old Feb 2, 2006 | 03:49 PM
Jim Galbally
i'll RTFM when it turns up
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Tim Wharton
Aug 30, 2015 05:46 PM
Dahl88
Aug 22, 2015 08:16 PM
turbinator
23
Sep 29, 2004 09:18 PM
