Car alarm just went off :S anyone got a clifford 300 manual?
im sitting in the house and i just heard my alarm go off and its in the garage all locked up. Nothing in the garage to set it off so very confused :s
i dont have a manual for the alarm so can anyone help please...
when i pressed the keyfob the alarm chirped 3 times. Then when turning ignition on but not starting the car the alarm light flashed 4 times. Can anyone look at the manual and tell me what that means please? I know the flashes are like a code for different reasons.
ta
chop
ta
chop
Don't ask - I don't know
The 4 flashes is to let you know the alarm actually went off. I know that as my old man's does that if that goes. Probably just having a mad half hour mate - as no disturbance and the garage hasn't been tampered with.
cheers mate. its a bit weird like! but saying that i went to the garage the other day and the alarm chirped like it had gone off. i thought it was a mistake because its a totally closed in garage thats part of the house.
ah well!
ah well!
Someone will be able to confirm this, but if it's the same as the 600 with regards to chirps/LED-flashes, then it's the following (from my 600 manual):
3 chirps = Alarm disarmed but there was an intrusion attempt while you were away
4 LED flashes = Door open/ajar/tampered with
Originally Posted by richm
Chop.. have you got a microwave oven on at the time by any chance (assuming your garage is attached or close to the house)???
go and play - you will be able to set it off every time..
Microwave sensor!
I disable mine from the fob if i remember before i use the microwave...
one of the well documented "false alarm" triggers.
aaaaah!
can you tell me how to disable it without wading through the manual?
intended for "if" you leave animals in the car with the alarm set, or your mobile..
your cell phone stands a good chance of setting it off if you leave it in the car switched on in close proximity to the microwave sensor and the alarm armed. (set mine off a couple of times in petrol stations like that, received txt msg while i was paying.. )
kosienutter
31
22-08-2015 09:55 AM
