Who knows about solid lifter engines? As i dont!
DEYTUKURJERBS
If you DO know about em...
Does what ive typed below make sence to you, or do i need to ring em back as ive got summat wrong
Getting some cams done for the GTR, they re-grinding mine.
Rather than just make bigger shims (cams operate directly onto the shims on GTRs) they said it would be better to add something underneath the shims, less mechanical load/wear/losses or summat by doing that.
That make any sence? I forget.
They said they needed to know the diameter of the shims, fair enough.
The diameter of the valve stem, fair enough.
But the final one maybe im confused. Think he asked how far the valve stem protrudes above the collars.
That make sence?
Hope so
That make sence?
Hope so
DEYTUKURJERBS
Lee- If i dont get the exact answer by tomorrow morning (hopefully robbie in NZ will gimme the answer later when they wake up down there!) i was planning to ring Martin, yup
Matt- Eh? Like said, they dont want to fit big shims for some good reason i dont understand, they want to do something a bit more flash, again for reasons i dont really understand
It was early and it was noisy, I shouldve listened more![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Easy to ring back n sort it, just wondered if what I have said makes sence to the experts...
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
PS
are liners solid lifters to begin with like Teg's or is this an aftermarket conversion?
If its aftermarket you need to change the cam profiles as they will have excessive initial ramps for opening the valves as they arent designed to take up clearance before opening!
Tomei do blanks for a pretty keen price or will gring them to your specs.
GTRs are solid as standard. GTSTs arnt.
Yea, he prob said collets!
Does it make sence if say that?![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
These bits:
![](http://www.indoschottle.com/images/coll-tbead.jpg)
DEYTUKURJERBS
If its collets then it sounds like he just wants to know much of the valve sticks out past those two little semi cricle bits you put on the top of it to retain the spring in place.
These bits:
Just measure it with a feeler gauge, he wont even need to know particuarly exactly, nearest couple of thou will be perfectly adequete
just rest feel gauges on top of the caps till you find one that feels about level with the head of the valve, jobs a good'un
Nah, standard figures are fine.
Oh hold on, would this be in the workshop manual? I got one of them...
you could ask on the GTR forum?
( see if anyone on there has asked Abbey those details when there car was serviced
DEYTUKURJERBS
And I have asked. And im sure you wont be at all suprised to know that there is no real help so far, as these details arnt something you usually need for writing out massive cheques
He was servicing someones GTR and it said on the receipt
"Valves, check clearance, 10 thou"
They thought it meant that they had to pay to clear the cheque they wrote for the valves and gave him 10 grand extra to cover it
DEYTUKURJERBS
Originally Posted by Cam
Give Rod a bell [no pun]
01704 822848![Top](https://passionford.com/forum/images/smilies/smile011.gif)
01704 822848
Hopefully will get the answer off Robbie via email later anyhow
01704 822848
![007](https://passionford.com/forum/images/smilies/bond.gif)
I'll get my coat
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
