Zetec problem
Old Jan 23, 2006 | 01:07 AM
Zetec Andy's Avatar
Zetec Andy
the only "cures" ive read about with is one of two things.
1) ICV (idle control valve)
2) The sensor attached to the catalytic converter.
Both are worth a good clean before spending stupid money, IIRC the ICV is behind the manifold, find someone with small hands!
Old Jan 23, 2006 | 05:16 PM
Zetec Andy's Avatar
Zetec Andy
to be honest i have never attempted removing my ICV but i have heard it can be a nightmare to remove and refit, no springs or washers to loose just a couple of bolts and its off, heres what it should look like...
http://cgi.ebay.co.uk/ford-idle-spee...QQcmdZViewItem
Good luck
Old Jan 23, 2006 | 05:33 PM
Moondust_crust's Avatar
Moondust_crust
mate what car is it? my escort 1.6 zetec used to do this , i would be sitting at traffic lights and it would rev up to about 3k and sit there, was ok when it was warm, turned out to be the iscv
hope this helps, cheers mark.
Old Jan 23, 2006 | 06:03 PM
Moondust_crust
its a ford thing mate some people know some dont, yeah ita easily sorted it just gets stuck. its right at the back under the inlet manifold bit of a pain to get to but its probly just dry, i cleaned mine out with brake cleaner then a bit of wd40 , let us know how you get on.
cheers Mark.
Old Feb 15, 2006 | 04:51 PM
Moondust_crust
glad you got it sorted mate , from what you have descibed that sounds about normal now.
cam cover gasket is well easy to change only about 6-8 bolts and it lifts off, if its standard it will be a brown rubber gasket, you will have to put it on the cam cover first then bolt it on to the head.
hope this helps
cheers Mark.
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
