4x4 saph wheel question
Caraholic
You will stand corrected then, as ALL YB Cosworth Fords are identical
ET40 is okay for that width - although you may have arch problems on the front on a 4x4. Also you will be limited to running 225/35x17s, so I would stick with a 7˝ x 17 in ET37 to allow 215/40s, which gives you a much greater choice.
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
pmsl ive been looking for ages for 8 inch wide wheels so i can fit my brembo brakes and i dont think they will go behind 7.5 x 17"
the only other wheel i would consider getting is some 18" mo's which again would cause probs
fookin car looks like i will always have poxy std brakes lol
cheers guys.............matt
Sorry i must have got mixed up,the xr4x4 must be the 100mm pcd,sorry i answered on that basis,must read properly before replying!Of course i stand to be corrected again.LOL.
Infact i will state now it is only the 2wd cosworth that uses 108mm pcd,the 4x4 is 100mm pcd.Can you prove i am wrong with more than just a reply on a BB?
you are more than welcome to come and measure mine if you like, and i know you will find Mike is correct
, can you prove you are right in the same way?
Caraholic
I also happen to own a 4x4 Cosworth as well
Next?
also given to Fords liking for keeping bolt patterns the same, i think you will find Most 4 stud fords are 4*108. ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Mike i think you forgot to hand this out
![007](https://passionford.com/forum/images/smilies/bond.gif)
some VERY knowledgeable people on this site mate, and most wont disagree with you unless they are 110% sure
but hey you took it like a man so no harm done
DixieTheKid
23-07-2023 10:16 AM
jdsjojo
30-08-2015 07:48 PM
