finding a wireless user
Old Jan 18, 2006 | 08:13 PM
AlexF's Avatar
AlexF
Default finding a wireless user
How do I find which neigbour is steeling my wireless connection....
I need to use it unencryted ocassionally and EVERY time I do this flocker comes on and cains my connection!!
Any sugestions?
Alex
Old Jan 18, 2006 | 08:18 PM
Go round and knock him out
Jim Galbally's Avatar
Jim Galbally
why do you NEED to use it unencrypted?
easiest way of doing it is to connect onto his PC and take a poke about to try and work out who he is. cookies with addresses in will be your best bet
Old Jan 18, 2006 | 08:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
just set fire to all the houses in the strret.
you should get him then
Old Jan 18, 2006 | 08:22 PM
AlexF's Avatar
AlexF
OK its easier for me too... old pda...
anyway
how do I find out about his pc?
Alex
Old Jan 18, 2006 | 08:27 PM
BigNige's Avatar
BigNige
MMm you will see it in the set up of your router should have a status page with his IP address and details what you do then dunno
I would jsut wep or WPA it up though
Nige
Old Jan 18, 2006 | 08:29 PM
JohnnyB's Avatar
JohnnyB
when you think he is using you system, use your web browser and log onto your router and see the Ip address and HW address which has loged on.
Then go on your PC and in the run Command \\"ipaddress" return
if he has know shares then use \\"ipaddress" c$ and guess the admin password, which is blank in most cases
Old Jan 18, 2006 | 08:30 PM
Jim Galbally
set your DHCP leases to 30 days and only have it give out 2 IP addresses in the scope (1 for your PC one for your PDA) that way if he connects he wont get an IP address so cant do feck all.
or some routers let you lock it down via MAC addresses, so only m,achines you decide can have access will have access.
more to the point tho...
IF YOU LEAVE AN UNSECURE WIRELESS CONNECTION ACTIVE YOU DESERVE TO HAVE YOUR NEIGHBOURS USE IT!
Old Jan 18, 2006 | 08:31 PM
wes's Avatar
wes
Does your router give out IP addresses via DHCP? Can you not just disable DHCP on your router, and use static ip addresses on your router + PC / PDA?
Open a command prompt on your PC (start \ run\ cmd ) then type in "ipconfig /all" , make a note of your MAC address (physical address), then go into your router and set it so only this MAC address can use it.
Old Jan 18, 2006 | 08:35 PM
edz's Avatar
edz
do this as a minimum if you cant secure the network. Change the default password on the router. You should also make sure you run a firewall on your pc.
Old Jan 18, 2006 | 08:36 PM
Stu.H's Avatar
Stu.H
cant be arsed to read this post fully (yer my arogant side) but if u cant be arsed to protect ur wireless network properly, i have no sympathy
Old Jan 18, 2006 | 08:37 PM
AlexF's Avatar
AlexF
well fuck off my post then
Old Jan 18, 2006 | 08:38 PM
andy_st200's Avatar
andy_st200
Originally Posted by edz
You should also run a firewall on your pc.
how will that stop his neighbour using his wireless connection??
as for firewall on your pc, if your firewall has nats their aint much need to have something else.. just virus and spyware detector
Old Jan 18, 2006 | 08:40 PM
edz's Avatar
edz
it wont but it protects him from his neighbour
Old Jan 18, 2006 | 08:41 PM
AlexF's Avatar
AlexF
thanks for the concern peeps...
my pc is fine and VERY VERY rarly is my net connection open to people.
Its more a case of I'd like to knock on a door and say hello to this person!
Alex
Old Jan 18, 2006 | 08:42 PM
ECU Monitor Enthusiast
No wireless network is secure no matter how much encryption there is !!
Old Jan 18, 2006 | 08:45 PM
User 32922's Avatar
User 32922
really? if it's good enough for the us government.....
Old Jan 18, 2006 | 08:47 PM
pgtips, that much secure then
Old Jan 18, 2006 | 08:49 PM
RANJ's Avatar
RANJ
run a packet sniffer
Old Jan 18, 2006 | 08:52 PM
User 32922's Avatar
User 32922
yeah, but it might just blow itself up or maybe its neighbours
Old Jan 19, 2006 | 09:11 AM
AlexF's Avatar
AlexF
HW address?
Alex
Old Jan 19, 2006 | 10:20 AM
Dan B's Avatar
Dan B
HW address?
Alex
"Hardware address"......otherwise known as a MAC address.
But yes, I'd lock the router down to MAC addresses, all of which should be pretty easy to find out for your own machines. Then, anyone who tries to connect with a MAC address not on that list doesn't get a wireless-connection (not easily, anyway).
Old Jan 19, 2006 | 10:59 AM
Phil's Avatar
Phil
Jeebus
Monitor his packets and get his bank details
Old Jan 19, 2006 | 11:06 AM
DanRSturbo's Avatar
DanRSturbo
Because once you have found the neighbour's IP address, you simply block that ip address in the router
You could also do the other option, which is what I have done before.
When you connect to someone's network, you have to be on the same workgroup, thus you can browse his shared files / folders. By default, when networking you get a shared documents folder in my computer. All you have to do is put a timed self-extracting file in there, riddled with virus's. Make it look like a windows system file, (just in case he goes in there) and then leave it
Old Jan 19, 2006 | 11:13 AM
DazS1Turbo's Avatar
DazS1Turbo
Easy Tiger
Old Jan 19, 2006 | 11:31 AM
AndyBrew's Avatar
AndyBrew
By far the simplest route is to use MAC address filtering simple as, that way you don't need the overhead of encryption unless you want it of course!
Should be simple enough to configure via your router, from a cmd line type IPCONFIG /ALL then look for the Physical address which is 6 sets of Alpha/Numeric digits you simple add them into your router and your away
This only restricts wirless devices anything plugged in via an ethernet cable works as is.
Old Jan 19, 2006 | 11:34 AM
DaveEscos's Avatar
DaveEscos
Alex
pmsl.. if it was me.. and YOU knocked on my door.. i think i'd just laugh my arse off and shut the door!
Old Jan 19, 2006 | 11:40 AM
AlexF's Avatar
AlexF
Yeah but the look on your face would be worth it Dave....
Billy_RS
16
Oct 11, 2025 09:41 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
slammedorion
21
Aug 6, 2015 11:38 AM
