Why arent we all doing this? ( Stu/Karl/Martin/MAD/Tony ?)
Spotted this picture on another forum:
http://www.corsaturbo.com/forumstuff/curitiba/01.jpg
Exhaust gas comes out of the engine into the first turbo and through an external gate if there is too much for the first turbo to use.
Then it goes onto the second turbo.
Once on boost the first turbo should offer very minimal restriction to the exhaust gas flow to the second one as it will be bypassed by most of the gasses.
The two compressor outlets are then Y pieced together before the plenum, so if either of them makes any boost then the engine gets it.
What is the reason we arent all doing that?
Seems like a very good idea to me TBH, but i know very little about compounding charging other than its not common, so from that i would assume there is a reason not to do it?
DISCUSS:
DISCUSS:
DEYTUKURJERBS
Thats not compound charging in the slightest if its how chip explained it.
More like sequential turbos.
Tony Turbosystems did summat like that for Cossies back in the day.
Shithot car tho! From Brazil! MasterPower Turbos, good stuff
There hasnt even been a post with a picture of a nice simple after market layour that we could all be using and look like it probably works quite well as far as im aware?
Here is picture, but you need to see it full size really i suspect:
[img:1280:960:c96b8288d4]http://www.corsaturbo.com/forumstuff/curitiba/01.jpg[/img:c96b8288d4]
Thing is, im getting my manifold design finalised at the moment, and it would actually be VERY easy for me to do this, like literally not even a grand extra including the turbo and wastegate etc.
So why shouldnt i?
what are the downsides to it?
So why shouldnt i?
DEYTUKURJERBS
[img:1280:960:780432c8de]http://www.corsaturbo.com/forumstuff/curitiba/01.jpg[/img:780432c8de][img:1280:960:780432c8de]http://www.corsaturbo.com/forumstuff/curitiba/02.jpg[/img:780432c8de]
Originally Posted by Rick
Karl and I wrote a fair bit on it - The problem is matching the turbo sizes, very experimental.
Perhaps im over simplifying it in my mind, but i dont see how the turbo size is THAT crucial, i agree for the absolute optimum perofrmance it would probably take a fair bit of experimentation, but for me to just get a useful bit of extra torque at low end surely even a pretty much "finger in the air" guess at turbo size (renault 5 t2 for arguments sake?) would be ok?
Plus i dont mind if i have to try a few turbos to get the right one TBH!
DEYTUKURJERBS
This isnt twin or compound charging, this is a sequential turbo setup, been done loads, just not often on aftermaket applications.
IMO youd be better off twin charging it with a turbo and a supercharger, cheaper and simpler if you know how, and more effective too.
Or compound charge it like Dumped's saff with turbo blowing into turbo.
But all 3 ways are v.v.cool.
Love the way theyve done away with the intercooler by just injecting the nitrous into the compressor outlet too
Originally Posted by digita1dragon
wouldnt that produce more boost than youve set on your actuator?
and if so, whats the point?
As Steve says its not compound charging (where one blower feeds the other)
Thing is, im getting my manifold design finalised at the moment, and it would actually be VERY easy for me to do this...
Originally Posted by fudgeass
i asked this aaaaaaaaaaaaaaaaaages ago with the pic below i seen.
[img:533:800:6752d4888d]http://www.germancarfans.com/news/2040414.009/2040414.009.1L.jpg[/img:6752d4888d]
Yeah but that just isnt as easy to understand as a nice picture of it simply implemented, so half of us probably didnt quite picture it right i suspect!
LOL
Originally Posted by Mongo
chip-3door
Cool idea mate
Could you use a smaller turbo to spool the larger one? Would that get around the exhaust side complexity?
Cool idea mate
its also for the vectra 2.2 dervs lol
pic was just to illustrate how its done really.
ie i wouldnt do it quite like that
chip-3door
Cool idea mate
Cool idea mate
Any, small superchargers are still very big compared to a small turbo, and also they have to be mounted in certain places (ie near the drive belts)
I wanted to supercharge the car originally (instead of a turbo not as well) but there just isnt the space, its SO tight in the bay even N/A that its not an option really for me.
I agree though that may be a good idea on something like my cossie (replica ) though, and wouldnt mind having a go doing so at a later date perhaps.
The problem with a supercharger though is they arent good at providing big torque low in the rev range and then not providing a lot of resistance at the top of the rev range dont forget!
Probably not got enough space in the engine bay of the mini for a supercharger... Infact you'll struggle to get a second turbo in there?
That set up above would fit in my car perfectly
There is just about enough room for a K16 in there on the right manifold mate, and thats probably the turbo i would chose to use as a first attempt as well quite possibly
If not a K16 though i woul only go SMALLER than a K16 not bigger.
I suppose you could fit the bigger turbo above the gear box.. Would you have any problems with the turbo being mounted so far away from the head?
Originally Posted by rsnissan
ahh ok didnt realise it was for the mini
mount the charger out of the bonnet like in mad max
Did think of a "torque bar" across the car and the charger running over the gearbox, but i cant do that if ive got a turbo already sat there!
Space is VERY lmited.
Thats where the turbo is going anyway mate on the new manifold me and Robbie are working out at the moment, thats how im not having to worry about space as much as Rich thinks i will
indeed mongo, but thats VERY off topic.....
So going back to the original question, can someone (rick?) give me a good reason why i shouldnt do it?
If there is any major disadvantage then i wont bother, ive got a bottle of antilag in the car anyway, so its not like i NEED a second charger but if it brings more to the party than it drinks, then i would like to invite it along anyway!
what happens when both turbos are at full boost would the smaller exhaust housing cause a restiriction then?
as you know the exhaust housing on a turbo affects the engines flow charistics etc.
Originally Posted by Karl
Chip,
If you have to ask on an internet formum why you should'nt use a method like above then you don't do it!!!!
It does'nt work by the way.
