erst engine removal
Old Jan 2, 2006 | 02:04 PM
jonesymk2's Avatar
jonesymk2
Default erst engine removal
can the engine b removed without taking the gearbox out with it or will i hav to take the gearbox out aswell
Old Jan 2, 2006 | 02:05 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yes it can
Old Jan 2, 2006 | 02:07 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
If it's got ABS best to leave the box in situ - if not then either way, makes no difference. Whetever's easiest for you.
Ginge !'s Avatar
Ginge !
just finding my feet
yes it can BUT take the bottow pully off or your gonna scratch your inner wing
Old Jan 2, 2006 | 02:13 PM
Eagle's Avatar
Eagle
Super Moderator
yes... easy ...
Old Jan 2, 2006 | 02:46 PM
creedy's Avatar
creedy
yes like they said, easy as pie
Old Jan 2, 2006 | 05:05 PM
ON-UJAH's Avatar
ON-UJAH
I got one out from above but as said remove the pulley and alternator while you are there. It may also be a good idea to undo the lower tracking arm to give you a bit more play to get the spline out of the clutch.
I think it would also be easier to remove the whole front end including struts and driveshafts, by raising the car - then wheel the lot out on a palet. It depends what equipment you have I suppose.
Remove the radiator obviously, or it may get damaged.
Old Jan 2, 2006 | 05:21 PM
John Laverick's Avatar
John Laverick
I've done it from the top before leaving the gearbox in and never again....in my opinion it is MUCH easier to drop the engine and box from below
Old Jan 2, 2006 | 05:25 PM
Ginge !'s Avatar
Ginge !
ive always done it from the top and never had a issue,,,,,,, that also includes mk2 fiesta engine bays
Old Jan 2, 2006 | 05:45 PM
jonesymk2's Avatar
jonesymk2
alternator is already off so thats 1 less thing,will the gearbox hav enough play in the 2 mounts then to get the engine out,will take the bottom pulley off aswell,the rad will b coming out,not really that keen on taking all suspension off car either really cause the car will b going to a mate to hav the engine bay painted,got 2 start looking for another engine aswell now cause the bores in the cylinders hav got marks in them and 1 of them has a bit of a naughty score in it but around the bore not up and down the bore
Old Jan 2, 2006 | 05:46 PM
jonesymk2's Avatar
jonesymk2
SORRY cheers for the help aswell everybody
Old Jan 2, 2006 | 06:12 PM
Ginge !'s Avatar
Ginge !
remembe tu undo the water pipes too btw,,,,,,, includng the one and the back of the head, i ALWAYS forget about that one
Old Jan 2, 2006 | 06:25 PM
jonesymk2's Avatar
jonesymk2
head is already off cause head gasket had gone but forgot about the pipe when me and my mate went to lift the head off
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Ellsa
Aug 9, 2015 07:03 PM
lockie
Jul 31, 2015 10:03 PM
