Water Spray Jets!?
Old 15-07-2004 | 08:35 AM
B19-TRB's Avatar
B19-TRB
Default Water Spray Jets!?
Plumbed up my water spray system for intercooler yesterday but the jets i got r just not good enough they dont really mist they just pump water out!
any1 now where i can get some 1s that will mist properly!? or will the 1s i got do it with a bigger pump!?
Old 15-07-2004 | 08:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
agricultural suppliers. but they have such a small hole that you need a good pump. what kind are you running?
Old 15-07-2004 | 08:58 AM
zvhturbo's Avatar
zvhturbo
Saxo window washer jets really spray a good mist mate.
Old 15-07-2004 | 09:03 AM
B19-TRB's Avatar
B19-TRB
will look in2 them!
have just emailed aquamist!
Old 15-07-2004 | 09:16 AM
zvhturbo's Avatar
zvhturbo
Buy jets online here
http://www.turbobits.co.uk/eshop/qd000000.html
Click on:
Aquamist water injection
Parts and accessories
Jets
Jets
Old 15-07-2004 | 09:18 AM
B19-TRB's Avatar
B19-TRB
cheers dude!
Old 15-07-2004 | 09:28 AM
B19-TRB's Avatar
B19-TRB
perfect thems the 1s i need! just unsure what size!
Old 15-07-2004 | 09:45 AM
EssexBoyRacer's Avatar
EssexBoyRacer
how do u control the direction of these jets? or does it just have to be facing the intercooler?
Old 15-07-2004 | 09:59 AM
B19-TRB's Avatar
B19-TRB
i think they come with spray patters & u just aim1
thats hwo i have done it so far!
but the jets i am usin aint the best!
also need a bigger pump can u reccomend anythin steve!? as u seem to know a few places for electric stuff! i aint spendin £300 n a erl pump!
Old 15-07-2004 | 10:02 AM
EssexBoyRacer
Garden pond pumps!?! Know it sounds silly but I've heard ppl use em b4!
c6mby's Avatar
c6mby
gte it fitted the weekend then m8?
EssexBoyRacer
so the jets have to be mounted in a position so that they are facing the intercooler?
AlexD's Avatar
AlexD
Post Miester !
I used Saxo washer jets and a Fiesta Water bottle on the cossie wheni had the 4x4 intercooler in it, worked when i could be arsed to fill up the bottle !!....
Al....
Old 15-07-2004 | 10:05 AM
B19-TRB's Avatar
B19-TRB
yes steve!
i got irrigation jets & a normal washer bottle pump & its shite!
will pond pump run 12v!?
Old 15-07-2004 | 10:08 AM
zvhturbo's Avatar
zvhturbo
I Think a normal window washer motor is adequate mate.
Old 15-07-2004 | 10:09 AM
EssexBoyRacer
What a pain in the arse!! how have u done that on u'res?
yeah I think the pond pumps normally run off an AC adatptor so should take 12v quite happily. Gotta be worth a trip down to homebase or wickes or a place that sell fish tanks and take a look at one. They're so laid back in them places u could probably bring it back even after using it if it aint up to the job!
zvhturbo's Avatar
zvhturbo
If not try this ~ £70.
http://rswww.com/cgi-bin/bv/browse/M...tockNo=4463461
Old 15-07-2004 | 10:12 AM
B19-TRB's Avatar
B19-TRB
washer bottle pump aint man enough! i didnt think i would b!
steve i will get some pic for u m8!
Old 15-07-2004 | 10:15 AM
EssexBoyRacer
Old 15-07-2004 | 10:26 AM
EssexBoyRacer
Dunno if something like this would be up to the job?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...313347918&rd=1
Old 15-07-2004 | 10:29 AM
danvisteon's Avatar
danvisteon
try headlamp washer pump as they are a higher pressure, use bmw ones ( try breakers)
Old 15-07-2004 | 12:57 PM
Rossco's Avatar
Rossco
I was messing about with this the other day, i was using a standard washer bottle and two sizes of pipe, one the size of the bottle outlet and the other the same size as a nozzel off a WD40 spray can.
Misted really well and costs peanuts!!! lol
Old 15-07-2004 | 01:07 PM
TILLIO's Avatar
TILLIO
Lewis, failing all that, a wet nos kit "fogger" jet will work quite well
Old 15-07-2004 | 03:14 PM
B19-TRB's Avatar
B19-TRB
its not so much the nozzle i think as i can get them piece of piss think its pressure!
gunna piss aorund wiht a few diff setups & report back!
Old 15-07-2004 | 04:29 PM
turbo.jon's Avatar
turbo.jon
Ive got a mk2 fiesta washer bottle with pump and i got a water spray bottle from diy shop focus took the nozzle off and fitted it to pipe an it work fine an u can also adjust the spray to mist or jets
Old 15-07-2004 | 07:05 PM
Mike Gurney's Avatar
Mike Gurney
save your money - the water spray doesn't do much
i only managed a 6 C drop when i tested one a few years back
fit water inj - if you want to do it properly
Old 15-07-2004 | 07:07 PM
Jon ERST S2's Avatar
Jon ERST S2
hows WI doing it properly? Replacing air with water? It's only used when you can't get a better intercooler or lower charge temps and the loss off power by adding water is less than the gain of lowing the charge temps.
Spray cools the intercooler without putting water in the inlet and losing power.
Old 15-07-2004 | 07:09 PM
lancia delta 6 times WRC's Avatar
Default Re: Water Spray Jets!?
1mm2 water injection jet with sierra washer pump gives a very good spray pattern.
I measured a 5 degree reduction in temps.
Old 15-07-2004 | 10:00 PM
Rossco's Avatar
Rossco
Think the key to having the pressure there is starting in a big pipe then going into a small pipe.
Old 16-07-2004 | 05:10 PM
Ragtop's Avatar
Ragtop
Sure I read the other day, and I quote..
It's better to have cold damp AIR hitting a hot IC, rather than hot air hitting a WET IC... !!!!
In other words, point the nozzles (presuming you're getting a mist) across the FRONT of the IC, not at it... Don't forget that at speed it'll blow straight back anyway..
HTH's..
Luv
Chrisie...
Mark RS
12-10-2015 06:01 AM
DAZZER
30-09-2015 08:43 PM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: Water Spray Jets!?
