Big Turbo Escort Cossie cooling system
Old 24-12-2005, 04:00 PM
TrevCos
TrevCos's Avatar
Default Big Turbo Escort Cossie cooling system
Hi folks, I've been playing around with the cooling system on the Cossie, fitting new standard header tank and Roose silicon hoses, now when I came to fill the water back up again it's not draining down from the header tank. I did the same thing with my small turbo car and had no problems. Anyone got any ideas? All I could think of was an air lock, but it seems very odd. Is there something I need to do to sort it that I don't know about.
Any (sensible) answers greatfully received.
And Merry Christmas to everyone by the way.
Old 24-12-2005, 04:13 PM
Damo V
Damo V's Avatar
start the car, as it feeds the water pump not rad.. could be you havent dropped much water out too..
You obv know the bleed nipple is on the therm houdsing yeah?
Old 24-12-2005, 04:21 PM
TrevCos
TrevCos's Avatar
Damo, there was loads of water came out, a lot of it over me. Yes, found the bleed nipple. Do I need to replace the washer when I've opened that up, or will it be okay just bolted down again?
Old 24-12-2005, 04:23 PM
Damo V
Damo V's Avatar
in theory yes but i havent yet
btw no point opening till warmed up and got cap on
Old 24-12-2005, 04:25 PM
TrevCos
TrevCos's Avatar
Nice one mate, thanks for that, and have a great Christmas.
Damo V
Damo V's Avatar
I should add so long as fans cutt in and heater blows hot all should be ok
ideally front of car higer than back but level at least
Old 24-12-2005, 04:26 PM
TrevCos
TrevCos's Avatar
Nice one. Okay mate, I'll give it a go. Thanks again.
Old 24-12-2005, 04:28 PM
MAD EVO 4
MAD EVO 4's Avatar
At work when we bleed a system we always have the vehicle running on idle, unlock the bleed screws, once fluid comes out tighten up the bleed needles, then turn on ur heater system air con off, put the heater dials onto full hot, in the on face position and with reserc off, then wait for fan to cut in. hope this is to some help.
TrevCos
TrevCos's Avatar
Then I just need to get the twin headlights working, which is being a pain, and we're sorted.
Old 24-12-2005, 04:29 PM
TrevCos
TrevCos's Avatar
Thanks guys. Happy Christmas to you both.
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
Billy_RS
15
05-09-2015 12:04 PM
stickyslick
14
10-08-2015 06:27 PM
Escortdriver1
31-07-2015 02:36 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Big Turbo Escort Cossie cooling system
