T38 TURBO ??????????
does any body on here use a t38 on there cossie ? if so how do they perform,also what cams and c/r are you running
cheeRS stu
cheeRS stu
Hello
I have done several now works very well on the right spec engine https://passionford.com/forum/viewto...797&highlight=
I also have one unit sitting there forsale .
Mark
Mark
Re: T38 TURBO ??????????
cheeRS stu
cheeRS stu
cams -->> BD16
8 injector setup (greens)
495 bhp at the moment, but it needs a bigger throttlebody and maybe a swedish inlet from Mike and a remapp to go higher..
DEYTUKURJERBS
Originally Posted by Stu @ M Developments
STUCOS,
stu would it be easier using t4
cheeRS stu
cheeRS stu
cams -->> BD16
Cosworth pistons (pocketed)
And also .. there are several different specifications for T38 .. as is also with T4...
So depends a lot on trim, turbinewheelsize and A/R etc. what you can achieve ?
JK12
33
26-04-2021 12:09 PM
