Anyone bought an electric garage door system recently?
Looking to get one, seen some nice ones for around £200,
can anyone recommend any, or suggest ones to avoid.
Its for a large double and a bit door.
Ta
Ta
Originally Posted by Tim
both ends my garage have the electric roller type remote etc but are best part of £1000 each ,you after a system that fits to ya door?
I`ve got one on a double door Paul
Tried to adjust it as was not quite closing flush - Fxxxxd it up good & proper & took 1 1/2 hours to get it working again including full strip down so now understand how they work
then found out one of the springs had twisted & was catching on the bracket
took 10 secs to fix & tighted a lock nut
Will find the make for you if you need as is quite a good one - even allows you to phone it to open
the door itself is fiberglass (althought you couldnt tell from the outside), presumably for weight
If you have an ally one it might need changing
155lee
14-08-2015 12:21 PM
