i think i fuked the Zetec turbo on top speed run on the M1
i was giving it beans chasing my mates in a 200sx and a cossie keeping up rearly well (up to 140 cough*)and everything seemed normal untill i stoped for a piss somwhere and when i was cranking it over it sounds like one or more cylenders hant got any compression
once running it drives normaly and power fells about right and it dont smaoke all the time apart from my usualy smokey turbo problem on over run
once cranked up it ticks over normaly and drives normaly
water and oil are ok too
i have a innovate wideband guage installed in my car and wad reading 10.5:1 AFR at 140 mph so was quite rich to say the least!
does it look like i have melted the headgasket between 2 cylenders?
Fucking superstar........
Perhaps you should adjust your topic title to something along the lines of "i think i fuked the Zetec turbo on top speed run on the PRIVATE TEST TRACK NEAR ME HOUSE"
yep
i think its just the decomp plate given up
acrralites from burtons is the answer to why i was using a decomp and never spending a penny there again
it wasnt deting because i made shure it wouldnt
i will whip the head off tomorrow and see
and runnig 13 psi
bit strange how it runs mormally tho ?
and runnig 13 psi
U sound like ur being a little bit of a hypocondriac...... The starter motor itself can cause this..... If it runs fine, u must have compression, but do a test.... Mine's been past 140 loooooooads of times without a hitch touch wood.
im whiping the head off tomorrow
hopfully this aint going to be a melted piston thread
i cant see it rearly as i was running it safe ie retarded and ful loads of juice at 10.5:1 afr
Cameron
14
09-08-2015 06:28 AM
