what makes these valves differant colours?
as said what makes the differant colours on these valves? just to point out that it does run perfect
andy
Re: what makes these valves differant colours?
andy
this pic was took when my head gasket had gone , but thers deff too much oil on the third cylinder, but as said she runs absolutly perfect for over 120,000
andy
andy
hi chris, this was taken when the head gasket went a few months back group A head gasket on now from m.s.d , and new stage 1 organic clutch as fitted by me and since you had it iv sorted a good second hand rad out and thats now fitted , so its flying mate, dont no why that valve is so bad cus to look at it it shouldent run very well, but it does
andy
andy
wonder if stem seal is stiff/leaking which is why occasional m,isfire you had on cold start up causing oil on the valve
cud be i recon as rest of head/piston crowns look spot on
chris, its a little lesson i was learnt by an american mechanic of all people, he did the cam belt on a rover 218sld i had and said to always turn the engine over 3 full cycles by hand after fitting a new cam belt , thus if you feel any resistant to stop and check everything and thats what happend so thank fuck i took notice of him as i can now set the cam belt up prity quick
the only thing i wud like to learn is how to set the venier up
mine runs 7dg advance
andy
andy
muz
16-08-2015 12:57 PM
Red_bull
09-08-2015 08:34 AM
