4WD MT75 to 2WD MT75????
Is a 2WD MT75 box a direct swap for a cosworth 4WD MT75??
Are there any differences in the bell housing? Starter motor position perhaps?
Cheers,
Doug.
Cheers,
Doug.
Re: 4WD MT75 to 2WD MT75????
Cheers,
Doug.
Cheers,
Doug.
Cheers,
Doug.
Cheers,
Doug.
Cheers, just what I'm after.
One last question.
Is the cossie 4WD bell housing different to the othe sierra MT75 bell housings??
Team HOTHOT!
well actually, thinking about it
a 2wd one will bolt on, but where the bolts affix into the sump it will differ to a 4wd version - the rest will be the same - ie, starter, block bolt holes etc etc
So would a regular 2WD MT75 from a DOHC I4 fit a 4x4 Cossie that is being converted to RWD?
From the answers above, it would seem the answer is a definate yes.
Best bit is it shouldn't cost you over 100 quid from a breakers.
Team HOTHOT!
best thing to do is get the shit plate (the plate between the gearbox and engine) from both 2 and 4wd I4 engines and line them up together - see the bolt pattern differences at the sump then
Originally Posted by Graceland
cossie bell housing is the SAME as DOHC bell housing - i have a dohc sierra XR4x4 gearbox in my saff
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
2wd, 4wd, 4x4, bellhousing, casing, conversion, converted, differences, end, ford, gearbox, mt75, rwd
