really confused now....
Old 09-12-2005, 03:33 PM
fordsportjay
fordsportjay's Avatar
Default really confused now....
someone help me before my head explodes!
this escort cosworth is still flooding to death......
ive changed virtually everything now and its still doing it.if i disconnect the injectors the car will eventually fire up and run until the fuel goes,if i reconnect the injectors it just floods and fills up the bores with fuel.ive tried my map sensor off my rs500 and it makes no difference.also changed the blue sensor back to original one-no difference.
whilst having these probs the owner decided to upgrade while it is in the workshop,so it has had light blue injectors and a collins chip fitted which runs with standard map sensor.changed all that and fault still there!
really baffled now,plus i cant get on with my rs500!!!
Old 09-12-2005, 05:07 PM
DaveEscos
DaveEscos's Avatar
fuel pressure reg faliure
Old 09-12-2005, 05:08 PM
fordsportjay
would it cause it to flood like mad?its as if the injectors are open all the time.
Old 09-12-2005, 05:11 PM
DaveEscos
DaveEscos's Avatar
items to check/change.. if you havent already
pressure reg
phase sensor (in dizzy cap)
Water temp sensor (blue one by the dipstick)
ACT (brown sensor in the inlet manifold)
MAp sensor
also try different injectors
maybe worth looking at the fuel pump/relay but im guessing pressure reg isnt shutting off and is flooding your rail/injectors
it can only be one of two things...
a part faliure or a signal faliure to your injectors
Old 09-12-2005, 05:56 PM
fordsportjay
it had the fault with the dark blue injectors in and now we have fitted the light blues in its still the same.ive changed the phase sensor in the dizzy and the blue temp sensor-ive even tried the old one again.the ecu has been re-chipped yesterday by collins to suit the light blues.the only thin i havent changed is the map sensor,but ive tried a standard 2wd one and still the same fault tons of fuel in the cylinders.the wiring loom doesnt look to clever either.just had the pressure reg out but there isnt much to see on it.if i suck on the vaccum pipe bit should i be able to blow through it
Old 09-12-2005, 05:59 PM
DaveEscos
DaveEscos's Avatar
no... you shouldnt
Old 09-12-2005, 06:10 PM
fordsportjay
i cant.it does all seem to point to the fuel pressure or injectors opening too long,but the fault was there before it was re-chipped.is the only pressure reg the one on the fuel rail-there isnt one on the fuel pump assy or anything
Old 09-12-2005, 06:13 PM
Dave Henshall
Dave Henshall's Avatar
see my post in tech q's
tankybaby66
06-02-2016 02:24 PM
locum8
01-10-2015 01:50 PM
lime
25-09-2015 06:56 PM
beller
21-09-2015 04:13 AM
Chopshop85
18-09-2015 06:13 AM
Quick Reply: really confused now....
