Problems selecting reverse in the S1..
Old Jul 12, 2004 | 11:47 AM
keithG666's Avatar
keithG666
Default Problems selecting reverse in the S1..
hello peeps (and less )
Whenever the S1 has been left to stand for a while, over night or when i get in it after parking at work, its a real bitch to get into reverse!!!
it'll go in but won't select properly...bring foot off clutch slightly,.....nothing....and then WHAM, it jolts into reverse....it SOMETIMES does it in first but not as much as reverse and it only EVER does it after leaving it for a while!!!
once its driving, etc there are no probs at all and you can select reverse all day long with no probs!!!
whats going on people!?!?!?!?! as it scares people when the thing jolts backwards!!!! PMSL
Old Jul 12, 2004 | 11:54 AM
Martyn's Avatar
Martyn
I suppose its a start if u cant scare em going forward?
On a similar note, one day my orion decided it never wanted to go into reverse again, it was as if the gear didnt exist!
Just hope it doesnt get to that stage
Old Jul 12, 2004 | 12:21 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
try pushing the selector down and into reverse, u checked ure gear oil? might need topped up? gearbox mounts ok? i need to push mine ddown and in all the time
Old Jul 12, 2004 | 01:43 PM
adamS2RST's Avatar
adamS2RST
my old s2 used to be a bit like that, found if i let off the clutch and dipped it agen it would go in ok, without the force of banging it in and jolting back
Old Jul 12, 2004 | 01:45 PM
Clare's Avatar
Clare
a lot of old Fords do this Keith! lol
Whenever you want to select reverse, just put it in 1st before you select reverse, you'll find it's a lot easier.
Cant believe no one has advised you to do this already
Old Jul 12, 2004 | 02:36 PM
keithG666's Avatar
keithG666
this SOMETIMES works babe!!! BUT its starting to do it in 1st also.....
and don't call her old.....you'll hurt her feelings...
Old Jul 12, 2004 | 02:39 PM
Max's Avatar
Max
I always find it easier selecting 5th then Reverse
Old Jul 12, 2004 | 03:02 PM
McPikie's Avatar
McPikie
Pushing down used to work for me on the cab....................... the XR2 just gets RAGGED and GROUND in
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
